Question about Apple iTunes
After trying to install I get the following
After trying to install I get the following message: The feature you are trying to use is on a network resource that is unavailable.
3 Suggested Answers
dvdcdlaser
  • 1285 Answers
SOURCE: when attempting to install itunes I get a message
are you admin on this computer?.........you may not have enough privilege
http://www.apple.com/itunes/download/
Posted on Jun 06, 2010
  • 495 Answers
SOURCE: says network resource is unavailable
Hi davyboy29,
I believe this is what you are looking for: http://discussions.apple.com/thread.jspa?threadID=1474384 -- Windows Installer CleanUp Utility almost always resolved this issue :)
Posted on Nov 14, 2010
2006 lincoln navigator instrument cluster not working
The thing to would be to hook up a factory or up scale scan tool to see if it will communicate . Your probably unfamiliar with control module communication on automobiles ! There is a microprocessor inside the instrument cluster ! Your best bet is to take to a qualified repair shop ,there is nothing you can do . If it needs to be replaced (which is highly likely ) info in the cluster needs to be down loaded to the scan tool ,then loaded into new one .The it needs to be programmed .
When installing a new instrument cluster, it is necessary to upload the module configuration to the diagnostic tool. Following installation of the instrument cluster, download the module configuration from the diagnostic tool into the new instrument cluster. For additional information, refer to Section 418-01 . The following items are configurable:
The Expedition and Navigator instrument clusters are configurable, hybrid electronic clusters (HEC) that contain a microprocessor, gauges, indicator lamps, and internal circuitry. The instrument cluster is non-repairable with the exception of the warning indicator bulbs and the instrument cluster lens. The instrument cluster uses hardwired circuitry, and the controller area network (CAN) to transmit and receive data from the vehicles other modules. For additional information regarding the communication networks, refer to Section 418-00 .
It is very important to understand:
  • where the input originates.
  • all the information necessary in order for a feature to operate.
  • which module(s) receive(s) the input or command message.
  • does the module which received the input control the output of the feature, or does it output a message over the communication network to another module.
  • which module controls the output of the feature.
Jul 27, 2016 | Lincoln Cars & Trucks
How to connects yhe psp to the internet
  • 1
    On the lower left-hand side of your PSP, you will notice a little silver slider. Slide the switch up and this will turn on the WiFi feature on the PSP. Of course, you do need a home WiFi setup for this to work. Your battery also needs to be full. Even if your battery is low and your unit is plugged in to an outlet, the firmware upgrade may not work.
  • 2
    With a fully charged device, go to your PSP's home screen and choose "Network Update."
  • 3
    This screen will ask you for your WLAN settings. Choose "Scan" and let the PSP detect the network automatically. Choose the right one and keep all of your settings in the default stage. Press the "X" button and the PSP will save the configuration as your new access profile.
  • 4
    Choose it again and when your PSP connects to the network, and if there is an update available, you will automaically see the following message: "Network Update has found a later version. To download, insert a Memory Stick with at least 14MB of free space and press the X button."
  • 5
    Press the "X" button and you should see the message: "Downloading." IMPORTANT - Do not turn off your PSP or remove the memory card during this time!
  • 6
    When the download is finished, you will see the following message: "Download completed. The update is now available on your Memory Stick. To install now, press the x button. To install later, go to [Game]." Press the "X" button to install the new firmware. You may see a few other screens detailing new features to be included in the upgrade, but eventually you will see "Installing."
  • 7
    During the installation, again, do not turn it off or remove the memory card. Once installation is finished, the PSP will tell you to press "X" to restart the PSP. When it powers back up, the new firmware will be in place
  • Read more: How to Upgrade Your PSP Firmware ' eHow.com http://www.ehow.com/how_2288266_upgrade-psp-firmware.html#ixzz1XnkoKCiw
    Sep 13, 2011 | Sony PlayStation Portable (PSP) Console
    PSP GAMES
    1. Step 1 On the lower left-hand side of your PSP, you will notice a little silver slider. Slide the switch up and this will turn on the WiFi feature on the PSP. Of course, you do need a home WiFi setup for this to work. Your battery also needs to be full. Even if your battery is low and your unit is plugged in to an outlet, the firmware upgrade may not work.
    2. Step 2 With a fully charged device, go to your PSP's home screen and choose "Network Update."
    3. Step 3 This screen will ask you for your WLAN settings. Choose "Scan" and let the PSP detect the network automatically. Choose the right one and keep all of your settings in the default stage. Press the "X" button and the PSP will save the configuration as your new access profile.
    4. Step 4 Choose it again and when your PSP connects to the network, and if there is an update available, you will automaically see the following message: "Network Update has found a later version. To download, insert a Memory Stick with at least 14MB of free space and press the X button."
    5. Step 5 Press the "X" button and you should see the message: "Downloading." IMPORTANT - Do not turn off your PSP or remove the memory card during this time!
    6. Step 6 When the download is finished, you will see the following message: "Download completed. The update is now available on your Memory Stick. To install now, press the x button. To install later, go to [Game]." Press the "X" button to install the new firmware. You may see a few other screens detailing new features to be included in the upgrade, but eventually you will see "Installing."
    7. Step 7 During the installation, again, do not turn it off or remove the memory card. Once installation is finished, the PSP will tell you to press "X" to restart the PSP. When it powers back up, the new firmware will be in place.
    May 31, 2010 | Rockstar Games Grand Theft Auto: Liberty...
    HP 2727nf MFP software cannot be install through network
    Are you installing SOFTWARE over network (i.e. from remote server) or you're installing your MFP over network? The latest means that you're installing software on your machine from CD/DVD/Image/etc and trying to connect to your MFP over network.
    May 06, 2010 | HP Laserjet M2727nf Multifunction Printer
    Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
    The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
    If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
    1. Click Start, click Run, type ncpa.cpl, and then click OK.
    2. Click Network Connections.
    3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
    4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
    To start the Wireless Zero Configuration service, follow these steps:
    1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
    2. Double-click Wireless Zero Configuration.
    3. In the Startup type list, click Automatic, and then click Apply.
    4. In the Service status area, click Start, and then click OK.
    If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
    Feb 26, 2010 | Acer Aspire One PC Notebook
    Had Oil Changed...Now I Can't SEE my INFORMATION DISPLAY!
    • The message center display is blank
    • Instrument cluster.
    • INSTALL a new instrument cluster. REFER to Section 413-01 .
    see owners manual for information
    Principles of Operation
    The message center is a vacuum fluorescent display, part of the instrument cluster. The message center electronic functions use both hardwired, standard corporate protocol (SCP), and UART based protocal (UBP) communication networks to transmit and receive information. As a technician it is very important to understand:
    • where the input (command) originates from.
    • all the information (messages) necessary in order for a feature to operate.
    • does the module which receieved the input (message) control the input of the feature, or does it output a message over the SCP communication network to another module?
    The message center provides the following features:
    • information displays
    • setup displays
    • warning messages
    • system check messages
    The message center information can be selected through a set of three bottons:
    • INFO
    • SETUP
    • RESET
    Jan 08, 2009 | 2002 Mercury Mountaineer
    Since installing the latest version of messenger whenever i turn my pc on a message comes up on my computer saying the following. Photo gallery The feature that you are trying to use in on a network...
    Hi
    Try to uninstall the new messenger and then reinstall it. and if you don´t whant the photogallery installed you can uncheck it in the begining of the messenger installation. If you want it installed you can install it after the Messenger installation is done and working.
    Aug 13, 2008 | Computers & Internet
    Apple iTunes Logo
    35 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
