Question about Audiovox Vehicle Parts & Accessories
Turn off the passive arming of my car alarm
I want to turn off the passive arming of my car alarm
  • Israel Adame
    Israel Adame May 11, 2010
    I would need to know the model number of the alram in order to get you the right directions.
2 Suggested Answers
logosc75
  • 625 Answers
SOURCE: Hi. I have a Viper
Open door, turn ignition on then off. Press aand hold programming button until you hear one chirp. After you hear the chirp, release programming button, press and release button one then press and hold. You will hear one chirp. While holding the programming button, press lock button on remote to change option. One chirp is active arming(what you currently have), Two chirps is passive arming without locks, Three chirps is passive arming with locks. Turn ignition on to exit programming. Test system.
Posted on Jun 20, 2011
I have a 2004 Nissan Merano and sometimes when I turn my alarm off and go to start it, it will not start and the red car with the key on it flashes please help!!!
Well, ill assume that since you have an l.e.d. your alarm is aftermarket. My guess is your alarm is in "passive arming mode". That means its arming. Itself. Some alarm dont fully arm in that mode, usually just the starter kill and led engages. That mode (sometimes happens) and can be changed via your remote. Hope that helps.
Mar 01, 2015 | 2004 Nissan Murano
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Feb 11, 2013 | Dodge Stratus Cars & Trucks
Car alarm goes off 30 seconds after disarm and open a door
Apparently the alarm is set to passive arming and, once you disarm it, it immediately begins the arming process and it is not registering the door being open. I'm going to go out on a limb and say that the alarm door trigger is wired to the dome light and the dome light is turned off; an issue that occurs with GM vehicles that have a dome light override switch. What's the year, make and model of the vehicle?
Sep 02, 2012 | AviStart 4400 2-Way Security / Remote...
How do I uninstall an Audivox 6 tone mini siren from my 2004 Honda Accord. I didn't install this item and now it is always arming itself locking me out of the vehicle!
The siren is merely the part of the alarm that gives you an audible alert when you arm, disarm the alarm. It also alerts you to intrusion and tampering. The siren does not arm itself and lock you out.
Locate your valet switch and turn the ignition on, press and hold the valet switch, count to five and release. the unit will be in valet at this point. Locate the model number and report back for the instructions to disable the passive arming.
Aug 12, 2012 | As9903 Mini Six Tone Siren For Car Alarm
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
Hi. I have a Viper 5701 alarm in my car. Arm and disarm goes very well with the control unit. But I cannot programming to pasive arming, always have to use de button in remote control to works. Is ther a...
Jun 13, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I work for a garage and we have a 1998 mystique that wont start we were wondering if there was some sort of anti-theft systeme that we dont know about and also we would like to have the were abouts of the...
Starting System
The function of the starting system is to crank the engine at a speed fast enough to allow the engine to start. Heavy cables, connectors and switches are used in the system because of the large currents required.
The starting system consists of a gear reduced starter motor, battery, remote control switch (ignition switch) and relay.
Vehicles equipped with automatic transaxle have a transmission range sensor attached to the circuit which prevents operation of the starter motor unless NEUTRAL or PARK are selected.
Vehicles equipped with a manual transaxle have a start inhibit switch in the starter control circuit, which prevents operation of the starter motor unless the clutch pedal is in the applied position.
The anti - theft protection system provides protection from unauthorized entry into the passenger compartment.
The system is controlled by an anti - theft alarm control. When armed, unauthorized entry into the vehicle is detected by lamp switches.
Once triggered, the system flashes the headlamps, the parking lamps, the alarm indicator, and sounds the horn. In addition, the starter circuit is disabled to prevent starting the vehicle until the system is disarmed.
System Arming
The system will be armed by the remote entry transmitter when the following input sequence is followed:
  1. Turn the ignition switch off and remove the key.
  1. Close all doors (unlocked).
  1. Press the LOCK button on a transmitter to lock doors. Alarm warning lamp will turn on.
  1. Wait for the anti - theft warning lamp to turn off.
The system will also be armed when the following input sequence is followed:
  1. Open a door. Alarm warning lamp will flash.
  1. Lock doors with power door switches. Alarm warning lamp will now glow steadily.
  1. Close all doors.
Opening any door will activate the alarm after the alarm is armed.
Disarming an Untriggered System
The system can be disarmed by performing one of the following procedures.
  • Driver or RH front door is unlocked with a key.
  • Driver door is unlocked by pressing the UNLOCK button of a remote entry transmitter.
  • If remaining in the vehicle, turn the ignition switch to ON or ACC position.
System Triggering
The armed alarm system will be triggered if any door is opened without using a key or a remote entry transmitter to unlock the door first.
Disarming a Triggered System
Carry out either of the following steps will disarm the triggered alarm system.
Two minutes and 45 seconds after the system has been triggered, the horns and exterior lamps will shut off automatically. The system will then reset to an armed state and will trigger again if another intrusion occurs.
Passive Anti-Theft System (PATS)
The Passive Anti-Theft System (PATS), known as SecuriLock, is fully passive in operation and requires no special procedures by the driver to arm or disarm the system. It is invisible to normal scrutiny and is operated by a transponder within the key body. This communicates with the module through a transceiver mounted around the ignition switch lock barrel.
The PATS functionality is incorporated within the powertrain control module.
PATS keys contain an electronic device inside, and are physically larger than a non-PATS key.
The transponder code reading is carried out when the key is inserted into the ignition lock barrel, and turned from position 0' to position II' or III' to crank the engine. If the PCM receives the correct code signal, the engine will start. Should the code received not be recognized, the engine will not crank as the PATS is still armed and the engine immobilized.
Anti-Theft Indicator
Whenever the ignition is switched on the anti-theft indicator will remain on for three seconds while the system carries out an initial ignition key-read.
The anti-theft indicator will flash rapidly for three seconds to indicate the PATS has immobilized the vehicle.
For additional information on the PATS fault codes, refer to the Diagnosis and Testing section.
Aug 12, 2010 | 1998 Mercury Mystique
How do i reset my alarm on a 97 jeep Grand
Here is excerpt from the 1998 Jeep Grand Cherokee Service Manual ... i know you posted under 1997 JGC but this information may be helpful ... by "reset alarm" i believe you meant disarming the alarm?
Arming
Passive arming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is exited with the key removed from the ignition switch, the headlamps are turned off, and the doors are locked using power lock switch. The power lock switch will not function if the key is in the ignition switch or the headlamps are on with the driver’s door open. The VTSS will not arm if either front door or the liftgate are locked using the key in the lock cylinder.
Active arming of the VTSS occurs when the Remote Keyless Entry (RKE) transmitter is used to lock the vehicle, even if the doors and/or the liftgate are open when the RKE transmitter Lock button is depressed. However, the VTSS arming will not be complete until all the doors and the liftgate are closed.
Following successful passive or active VTSS arming, the VTSS set lamp on the top of the instrument panel will flash rapidly for about 15 seconds after the illuminated entry system times out. This indicates that the VTSS arming is in progress. If the light stays on steadily during the arming, it indicates that the hood switch is closed (the hood is open). The VTSS will still arm if the hood is open, but the engine compartment will not be protected. Once the 15 second arming function is complete, the set lamp will flash at a slower rate to indicate that the VTSS is armed. Disarming Passive disarming of the Vehicle Theft Security Sytem (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter. Once the alarm has been activated (horn sounding, exterior lights flashing, and the the engine no-run feature), either disarming method will also deactivate the alarm. Depressing the Panic button on the RKE transmitter will also disarm the VTSS, but the horm will sound and teh exterior lamps will flash for about three minutes as a part of the Panic feature function. ..." And as an additional note, if you have the courtesy interior lights set at 30 seconds like i do, you have to wait until lights go out (with alarm still sounding) before you can disarm the alarm via passive disarm method... what a pain when you don't have the actual RKE handy... Good Luck!
Feb 14, 2010 | 1997 Jeep Grand Cherokee
How can I reset my Factory Alarm on my Jeep it wont run
Alarm Module Reset Procedure
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the lift gate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Jan 28, 2009 | 1999 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
771 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
