Scanner How do I work the scanner on my machine?
  • 4 more comments
  • ahmed saad Feb 09, 2008
    my copier e-studio 161 cant scan & the software dosnt include any thing about
  • maisonnana Feb 10, 2008
    i forgot how to get my scanner working and it used to show up when i clicked on scanners and printers
  • Anonymous Feb 14, 2008
    need to know how to use scanner
  • mirio Mar 08, 2008
    my machine does nothing when I push the scan button... help!
  • Anonymous Mar 11, 2008
    Can not make pictures smaller on e-nail
  • Anonymous Jul 31, 2008
    cannot scan
    Problem Solver:
  • 12 Answers
Nana,
It could be helpful to have your printer/scanner make and model as well as what kind of machine you've got there and what it's running for software (Windows XP, Vista, is it a Mac).
Posted on Jan 11, 2008
My printer, scanner is a HP Officejet J5780 All-in-One. My computer is a dell and I have Windows XP. Thanks for your help.
6ya staff
SOURCE:
Usb port open error
Does it work on other POS machine? That is to verify any hardware issue with the scanner. If it works, does other scanner works on this POS machine? Sometimes unplug and replug some USB cable in or some of the cable in between the POS and scanner will make it work. If those do not work, try to check the server for POS connection and see whether they can see that POS system. Use your store control application to reset that POS machine before you refresh the software or operating system on that.
Sep 11, 2012 | Datalogic Magellan 1100i Barcode Scanner...
I installed a printer on my PC and the scanner does not work. Should i install the scanner aswell?
Do you have the combo printer that comes with scanner and printer in one machine? If you do, then one installation should work the device as the computer will recognize it as one. If that's what you have, and the scanner still doesn't work, return the machine and ask for a new one.
If you have separate scanner and printer machines, then you should have two installation discs as each should have its own. You will need to install the scanner if this is the case.
Hope this helps.
Aug 30, 2011 | Office Equipment & Supplies
When start machine then display shows call for sevice F14
F14 Scanner unit FROM error
Was the main PWA replaced?
YES
Download the scanner total count value into the main PWA in the setting mode (08-388).
NO
Was the scanner unit or scanner control PWA replaced?
YES
Download the scanner total counter value of the main PWA into the scanner control PWA in the setting mode (08-389).
NO
1. Check if each connector between the scanner control PWA (CN6) and the main PWA (CN8)
is disconnected.
2. Check if each connector pin is removed or the harness is broken.
3. Check if any conductor pattern on the scanner control and main PWA is open- or shortcircuited.
4. Replace the scanner control PWA.
5. Replace the main PWA.
Nov 17, 2010 | Toshiba E-Studio167 Copier
Plz tell me the flatbed scanner or pass through scanner is same type or different?
They are different.
A flatbed scanner works like the usual scanners you see - you put a document on a flat surface area and have it covered. Canon Lide is an example.
A pass through scanner works like the usual fax machine system wherein you will have the document to be scanned feed, and as it passes though the imaging part of the machine, it's digital copy is generated.
There are machines that works as both - Brother 185c and Samsung SCX4521F are examples of both flatbed and pass through scanners.
Jul 31, 2010 | Kodak i1220 Pass-Through Scanner
Hp 6110 scanner making noise i can do any thing else because of that scanner light doesn't move, move little on scanner glass then come back on right hand side and keep making noise some time i can see...
If you cleaned the scanner glass before the problem began, it sounds like you messed up the homing strip underneath the glass. The scanner is trying and trying to find its home position and it can't. There is no way to disable the scanner to use the other functions. This is the downside to All-in-One machines. If one function (most commonly the scanner) stops working the entire machine won't work. I own a Cartridge World ink refilling store and I always caution people against buying all-in-one machines for this reason. It sounds like you'll need to buy a new printer, unless your printer is magically still under warranty you could call HP and ask what they can do for you. They'll probably just recommend you buy a new machine anyway.
Feb 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Keep getting error message to unlock scanner.....says it can be unlocked from the bottom of the scanner, but I don't see it.
My one touch 5800 USB scanner worked great on XP for over a year and then started giving me the unlock the scanner message. I tried different power supplies, reloading software and moving it to a machine running 98SE and nothing improved. I left the cover open and noticed that the lamp was fairly bright at the sides but very dim in the center. I replaced the lamp with one from an old parallel port scanner which was in good shape and it now works perfectly on 98SE. I have not connected it to a XP machine yet.
Aug 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
I need driver for acer scanner szw 3300 u for vista
just install the win98se in ur machine and than ugrade the machin with winxp ur scanner will start working
Jun 16, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Ricoh MP4000B
hi
a rijas working in dubai
my Gestetner MP 4000B nw its showing waste toner bottil is full please advice me how to solve dis problem
Feb 18, 2009 | Office Equipment & Supplies
5316 SCANNER DRIVER
the sharp 5316 does not work as a scanner
sorry for that
Feb 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
Coppier Problem
The trouble is that the scanner assembly can't find its "home" station. Here is the most common solution. There is a reflective white stipe under the scanner glass that the scanner looks for. If the stripe is dirty, or if the scanner mirrors are dirty, the scanner won't sense its location, and cause a "scanner error". A qualified technician should be able to clean the assembly. The other option is to replace the scanner assembly. I hope this helps.
Feb 27, 2007 | HP LaserJet 3330MFP All-In-One Printer
269 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
