Question about Lofra MXGC96AMF/CV Dual Fuel (Electric and Gas) Kitchen Range
Hi, I have a Lofra Model 51440401 MG 96 GG/Cn.
I need the door hinges and springs for the oven door as it just flops open. Do you know where I can get them from and how much ??
  • 4 Answers
Have the hinges and springs definitely gone? I only ask because Lofra oven doors have a reasonably awkward fitting method. If you don't get the anti rotation hooks sorted out correctly. There is a manual online that may help. http://www.lofra.it/manuali/manualeITA_ING.pdf you would need to check page 44 of this pdf file to just see what I mean. Other than that I have not seen these as spares anywhere, So I apologise if I have wasted your time.
Posted on Nov 18, 2009
  • cfresser Jan 19, 2011
    Dear Mr. Appliance, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
    Please write to consumerservice@lofra.it or call 39 049 9904811.
    Kind regards,
    Carlos Fleischfresser
    Lofra Sud America
Cannot put the oven door back on
Hi Elspeth:
Don't know what make or model you are dealing with, but from personal experience, here's what I dealt with.
- Oven door is mounted on spring loaded hinges. That's what keeps it in the closed position.
- To remove the door, it has to be fully opened, then lifted from close to the hinges, and slid out.
- To put the door back on, the hinges have to be in the "door open" position. Since they are spring loaded this can be tricky getting them into position.
- It's easier with a helper, one on each side....... slide the hinge legs into the slots. You'll need to lift the door slightly towards the closed position to allow the hinge legs to engage in the secure or latched position.
Hope this helps.
Cheers.
Dec 06, 2015 | Ovens
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
We have a Lofra dual fuel cooker 5 years old which needs a new rubber door seal on the gas oven but cannot find anywhere to obtain this part. Can you help? Pip Bedford
Hi I also had difficulty in obtaining a Lofra oven door seal but after searching and searching the internet I obtained an email address and now the problem has been solved. I received my oven door seal from the Italian Lofra company direct this morning. I dealt with a lady named Donatella and I found her very helpful. She can be contacted on donatella.talpo@lofra.it just give her the make of your cooker and she will let you know if she has one mine cost around £14. Good luck Suzie :)
May 03, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Hi I have a Lofra Maxima Model no: MXD96AMFEP and need the Oven Selector Switch and Oven Door Hinges - can anyone help please am deperate!
Hi Gemma, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
Please write to consumerservice@lofra.it or call +39 049 9904811.
Kind regards,
Lofra Sud America
Jan 18, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
I need door hinges for my lofra cooker, the door wont shut
i had this problem - wouldnt seal properly at the top, i though the hinges were bent, but could tn find replacements anywhere..
ive just taken the door off, and swapped the hinges to the opposite sides, and it seems to have done the trick!
Dec 11, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Hi, We have a Lofra oven. The door no longer
Sorry,
you are screwed I am in the same position. Tonight I am going to the store where I bought it with a baseball bat and intend to smash the owners legs.
Oct 13, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
I need to clean between glass plate and oven door on my Zanussi electric cooker. I have drips where I've wiped the door over, also there is dust in between. Model ZBF 360W, Serial 61705615, Prod. No....
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Sep 29, 2009 | Ovens
Lofra five burner gas cooker, oven door not closing properly,
It sounds like you need to check the fixing screws of the oven,failing this replace the hinges.
I hope this helps.
Jul 07, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Lofra MXGC96AMF/CV Dual Fuel (Electric and Gas) Kitchen Range Logo
592 people viewed this question
Top Lofra Kitchen Ranges Experts
Paul Carew
ray gallant
David Ellis Rhea
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
