Question about Canon PIXMA MP530 All-In-One InkJet Printer
When i print the fonts seem to be different sizes and vertical lines are not straight...
    Champion:
  • 206 Answers
You should re-calibrate your printer
Posted on Nov 17, 2009
How do I make the print biiger on my e-reader?
Your eReader offers several different sizes of text for most books. You can adjust the text size, fonts, line spacing, and justification to make reading easier on your eyes.
  1. While reading, tap the middle of your page to bring up the Reading Menu.
  2. Tap the Aa Text icon.
  3. Adjust your font settings:
    • Tap the dropdown menu beside Font Face to select from a list of available fonts.
    • Drag the slider beside Font Sizes to change the size of the text.
    • Drag the slider beside Line Spacing to increase or decrease the space between the lines of type.
    • Drag the slider beside Margins to make the margins bigger or smaller.
    • Tap your choice of justification.
kobo com help Changing text and font options on your eReader
Jun 15, 2016 | Kobo eReader
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
Tekan tournament
Alternate Mokujin sounds
To hear different hit sounds for Mokujin, hold DOWN on the D-Pad or joystick before a match in which you are controlling him. Mokujin will now sound like a block of wood when damaged.
Arcade History Dip Switches
While at the Press Start screen for any of the Arcade History games, hold the select button and you will be given a list of dip switches. You can use these for such things as changing number of rounds or unlocking hidden characters, such as Baek in Tekken 2.
Choose Victory Animation
After winning a round and you see the replay showing, pressing each button( [X], [O], etc...) will result in a different victory animation. This also works when the opponent wins.
Play in 'Devil' mode in 'Devil Within' mini-game
This allows the player to play as Jin in permernent Devil mode without having his life bar drained out. The devil bar will be considered as his laser bar. The downside of this code is that it kills of you opponents faster thus unable to reach a higher combo rate.
Note: You must clear Devil Within under Medium difficulty. Then start a new Devil Within or Stage Select.
FOR THE BEST VISIT THIS SITE:
http://tinyurl.com/ydeuw6k
Nov 11, 2009 | Video Game Consoles & Games
Font size issue
Are you trying to print a two-line label?
If there are two lines of text, they are printed in size 1, regardeless the size you set.
Here is the procedure, described in the manual you can download from here:
http://welcome.solutions.brother.com/BSC/public/files/dlf/docp000113/pt1180ug01usen.pdf
Note:
• If there are two lines of text, they are printed with the SIZE1 setting applied,
regardless of the selected size setting.
• To quit the following procedure at any time without making any changes, press [BS/Clear] key.
1 Press [Function].
2 Press [<] and [>] until SIZE is displayed, and then press [Function] or [Backspace]. The current size setting appears in the display.
3 Press [<] and [>] and until the desired size setting is displayed.
4 Press [Function] (or [Backspace] ) to apply the selected size setting to the text.
Aug 06, 2009 | Brother P-Touch 1180 Label Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
Printing settings
Hi,I have a doubt, whether the perview is good and only the print out is bad or both are bad.
Anyway i am giving solutions for both.
The Statement or Report Looks Fine When Previewed, but Looks Bad When Printed If the appearance of the statement or report when printed differs from its appearance when previewed, this may indicate a problem with the printer driver (such as corruption of the driver files). Make sure you are using the most current version of the correct printer driver for the operating system on your computer. For example, a printer driver for an OkiData MicroLine 390 for Windows 98 may not work well at all when printing from Windows XP.
  1. If you need to check for a different printer driver, begin by checking the installation disk or CD-ROM that was provided with your printer.
  2. If you can't find the driver you need on the installation media provided by your printer's manufacturer, check the CD-ROM from which your operating system was installed (i.e., your Windows CD-ROM).
  3. If you can't find the driver you need on your Windows CD-ROM, or if you need to try an updated version of the driver you are currently using, check your printer manufacturer's Web site.my.okidata.com/pp-ML521.nsf/openingdrivermenu?OpenFrameSet
The Statement or Report Looks Bad Whether Previewed or Printed There are many factors that can contribute to undesirable printed output, such as margins, fonts, and custom paper sizes. Use the following steps to troubleshoot this problem.
  • Try using a different font size. See if there is a separate font size available for the same font family (e.g., 15 cpi vs.10 cpi).
  • Try adjusting the page margins and printer offset adjustments in the Page Setup window.
  • Check the printer driver properties to determine if a custom paper size is specified. If not, you may need to specify one. For example, when printing checks that have only one stub, you may need to set up a custom paper size of 8.5 inches wide by 7 inches tall. Conversely, if a custom paper size is incorrectly selected, printed output of reports and statements may be adversely affected.
  • In the Advanced Printing Features window, select the Optimize for Print to File check box and clear all other options and check boxes.
  • Try temporarily renaming the STI.INI file and restarting the Tabs3 or PracticeMaster program. The STI.INI file holds all of the printer settings. If this helps, you may have to recreate the margins, font selections, and other settings used for printing since that information is stored in the STI.INI file. If this does not help, delete the new STI.INI file and rename the original file back to STI.INI.
  • Is the printer configured to emulate another type of printer? Consult the printer's manual and/or the printer manufacturer's Web site to determine if the printer is able to emulate another type of printer such as an IBM Proprinter. If you have tried all of the internal fonts available in the printer's current configuration, it may be beneficial to configure the printer to emulate a different type of printer and then install the corresponding printer driver. Then you can test each of the internal fonts available in the new driver.
  • Once your printing issue has been resolved, check the printed output to ensure that lines are not wrapping or breaking when they should not. Make sure the margins all appear correct.
  • When you are satisfied that the printed output is completely correct, be sure to look at a preview of the same print job, to ensure that the preview is legible. For some printer drivers and fonts, it may be necessary to make a second installation of the printer that uses TrueType fonts. This second installation would then be selected whenever you need to preview reports or statements, and the original installation would be used for the actual printing.
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | OKI MICROLINE 521 Matrix Printer
Printing issues
hi
it seems that cleaninig is required to the printing roller. it would be slight difficult to open it and clean for you.
you should get it serviced by some professional.
Sep 01, 2008 | HP LaserJet 1020 Printer
Font size
The font and size are determined by the print wheel. If you want a different font or size, you must change print wheels. It is very easy to do.... Open the top cover and pull back gently on the print hammer (sometimes has orange arrows) The print wheel is directl;y in front of the hammer and gently pull it straight up. When replacing the print wheel just remember to pull the hammer back slightly so the wheel can clear.
Sep 25, 2007 | Lexmark Wheelwriter 3500 Typewriter
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
old marine
old marine
