Question about Dell Inspiron 8500 ATI 32MB Video Card - 8X411 Graphic Card
My video card got too hot and is now cooked. Symptoms were that the graphics would fail after a short while, now there is nothing - not even with a remote monitor.
  • Austin Evans
    Austin Evans May 11, 2010
    And what exactly is your question?
  • joecoolvette
    joecoolvette May 11, 2010
    Thank you for posting this information. Is there a problem involved that we may help you with?
    Champion:
  • 206 Answers
The problem started when your cooling system stopped working correctly. You should have been to the service before it happened. Most probably, your graphic card is dead
Posted on Nov 17, 2009
I'm thinking it might be the video or graphics card on my desk top ive tried several different monitors and nothing no error message no windows logo all the ports and cables are fine nothings broken
if it has a separate monitor connection on the mother board at the back, pull the graphic card and connect to the monitor to that connection
If it is a graphic card , the mother board card will run the monitor so replace the graphic card
if you do not have a plug in graphic card and that is how you have it set up take it in for a proper diagnosis as it may be the mother board is failing
Mar 18, 2017 | Graphics Computers & Internet
15'' lcd energystar monitor problems
Try another monitor to verify the Graphics Card, if you have a graphics card, then another monitor cable. check for bent pins in the connectors, eliminate the hardware by changing each component/cable one by one. It may be the Graphics Card/Adapter is gone. Clean the inside of machine, overheating due to dust will cook components, GPU's get quite hot. Try some Electronic Contact cleaner spray on the Graphics Card connections, if applicable. Unplug before reseating the Graphics Card or cleaning, take precautions in ESD before handling a Component. If your Graphics is integrated, you can purchase a aftermarket PCIe x16 Graphics Card quite reasonably, : http://www.google.com/webhp?source=search_app#q=ati+amd+pcie+x16+graphics+card&hl=en&sa=X&tbs=vw:l,p_ord:p&tbm=shop&ei=ze05Uf25KJDO9ASIyYHYDw&ved=0CF8Quw0oAg&bav=on.2,or.r_qf.&bvm=bv.43287494,d.eWU&fp=bc2048b0dd90d6d4&biw=854&bih=580
Mar 06, 2013 | E-Machines T5048 (7136) PC Desktop
Travelmate 280 doesn't boot
I don't have a schematic but I have serviced enough that the video graphics card is often source of trouble, the solders gets hot causing all kinds of symptoms from no video to erratic operation of the motherboard, to fix this you must reflow using specialized equipment. It requires the removal of the card in order to address this. Hp boards had all kinds of trouble with their video cards getting to hot, and a number of other brands have been affected, look up reballing and reflowing on youtube.
Jun 09, 2012 | Acer Computers & Internet
Display is fuzzy with barcode like images across the screen at regular intervals.
Video corruption caused by a failed video memory chip. There's nothing that can be done to save it, the card is dead, replace it.
Jan 08, 2011 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
Nothing shows up in the monitor even the cpu on
Install a new graphics card and plug your monitor into that new video card. Do u get video output? If not, the problem is the system board.If u do, the problem was the graphics card.
Mar 15, 2010 | ASUS P4S533-MX Motherboard
The fan on the ati radeon hd 2400xt video card runs constantly, any ideas of how I can get it to stop
you don't wanna stop that fan. the chip in your video and is very similar to your processor on your motherboard. it runs very hot, hot enough to even melt your card. if it's running constantly maybe your computer is in a very warm spot or your working the video card too hard. either way let the fan run or you'll severely damage your ard.
Feb 26, 2010 | Lenovo ATI RADEON HD 2400 XT - Graphics...
I have an about 2 year old M9047C HP PC. The
Really there is no way to check a video card for problems unless 1.) You have another PC that will support the same connections (PCI-E, PCI, AGP, etc) as the video card you have. 2.) The display still works to where you can run some software that will test the card for problems.
According to HP's website, I looked up your PC, you may have a graphics card installed in the PCI-Express X16 slot. If so, and your motherboard still has the Intel graphics built in, you can remove your video card.
You stated that your motherboard has another video port and you tried using it but no go. This is because HP has stated that if you have a card installed as well as on-board graphics (this means there are two video ports on the back of PC not including HDMI) then they can not work at the same time. So, try removing the graphics card installed in the expansion slot and use the one attached or built on to the motherboard.
Still, if all else fails and that does not work, graphics cards can be replaced with your type from $80-$400 dollars. Just depends if you want a mfr. replacement or boosted performance!
If you do get the built-in graphics to work, then your know it was your video card most likely. They are known to go out quite easily in some cases. PCs and PC components are rated to last a certain amount of hours before that fail, sometimes you surpass this time greatly and sometimes they fail short of this. It happens, I have gone through at least 3 graphics cards in the past 4 years because I am cosntantly puching them to max hahaha!!!
Hope that helps and happy computing. Let me know if you have any further questions.
Oct 14, 2009 | HP Computers & Internet
My graphic destroyed
your video card has failed, you will need to reinstall your drivers or possibly even replace it.
Dec 09, 2008 | MSI (MS8936340) (64 MB) Graphic Card
Computer beeps 3 time when turned on.
normally 3 beeps (might be one long and two short) means it's the video card, try another slot if possible.
If no other slot is available, then clean the contacts off the graphics card with a #2 pencil eraser, taking care not to touch the contacts afterward, and then re-insert the card.
if still nothing, try another video card.
Jun 22, 2008 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
Alun Cox
