Intermittent problem on turn-on sometime it starts /all lights light up and stay on. Do I need to change the interface board or can I clean the board up with electronic spray clearner to clean contacts
    Genius:
  • Washing Mach... Master
  • 1,460 Answers
Could be loose connections on the plug or faulty mains switch on machine, if switches are at fault advise new switch rather than clean contact/
Posted on Nov 17, 2009
When starting wipers came on and stay on no matter of position of control, washer fluid over head dome light won't turn on, rear washer and whiper won't work.
Wipers won't turn off......sometimes! - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Diesel > 6.7L Power Stroke Diesel
Feb 3, 2014 - Starting around 25,000 miles my wipers stayed on the slowest intermittent setting even when ... They only two that come to mind is the switch inside the cab or the wiper motor control board. ... The wipers do not park at the correctposition ... It doesn't really matter what steps need to be taken to fix the issue.
Window washer fluid put in window washer won't work now.
www.cargurus.com > Questions > Kia > Sorento
CarGurusAug 31, 2015 - Window washer fluid put in window washer won't work now. ... 4 answers. wipers working, not the washer though, pulled pump, intake screen clean. 2011 Kia Sorento Base ... Interior lights do not work when door is opened 7 answers. At first the back seat overhead light stopped working. Kia said it would ...
Nov 26, 2015 | 2011 Dodge Durango RT
Light panel fully lit stopping program selection and start does a electronic part need replacing
I would suspect the user interface panel.
Most dishwashers can be tested thusly:
Turn off power to the dishwasher at the circuit breaker box. Take apart the Dishwasher door and unhook the cable from the User Interface panel to the main control board. Then, turn the power back on and close the dishwasher door so it latches. The drain pump should go on. If it doesn't the main board is bad. If it does, it's the user interface panel.
Oct 15, 2014 | Beko DW602 600 mm Silver Built-In...
Canon EOS Rebel XSI got wet yesterday at SeaWorld. When we try to turn it on, a blue light comes on, sometimes intermittently, and sometimes stays on when we turn off the camera. The camera never turns...
If it was saltwater then it may have been shorted one or more of the circuit boards out. You can try removing the covers and cleaning the exposed circuit boards with a Q-tip soaked in WD-40 (don't spray on the boards) Cleaning any obvious corrosion will sometimes solve the problem. However, if there is corrosion in the flex connectors then boards may have to be replaced.
Sep 15, 2013 | Canon EOS 30D Body Only Digital Camera
2005 Volvo S60 - signal lights intermittently stop working due to key ?
2005 s60 message check stop light. Just replaced all bulbs but still getting this message
Jul 21, 2012 | 2001 Volvo S60
The air bag dash light stays on 2004santafe
Struggled with this problem on our 2005 Santa Fe since new. Wife weighs around 125. Light is sometimes on and sometimes off. Received a recall pertaining to this problem within a year of purchase. Recall called for resetting the algorithm that runs when the engine is started--at least that is what the service rep said.
Returned a 2nd time when this did not correct the intermittent problem. They said everything was working properly. They pointed out that the owner's manual calls for all passengers to be seated before" the engine is started, since that is when the sensing algorithm runs. This is certainly bad design logic. We all have passengers unboard and board while the engine is running. We surely do not turn the engine off each time these boarding events occur.
However, being a professional engineer, I conducted my own test. Sure enough, each time I noticed the light being "off" when my wife was in the passenger seat I pulled over to the side of the road, turned the engine off and restarted. The light went out every time!
Intermittent problems with safety systems are, in my opinion, the worst kind. Given this is integral to the design, I firmly believe the design is faulty. And worse, there is nothing Hyundai service reps can do to remedy the problem.
Best regards,
TF
Jun 02, 2011 | 2004 Hyundai Santa Fe
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Unsure of problem
check to see if the problem is overheating by storing it in a plastic bag in a refrigerator for 1/2 hour then power it up immediately. Don't let it stay out without power or let it dry as moisture will condense on it. If it stays on longer after cooling something is causing overheating., if not the problem is probably an intermittant short. If you can open it up and spray the components individually with freeze spray, this may isolate the problem. Sometimes pc boards warp under temperature changes and cause intermittant problems, sometimes it's a semiconductor.
Nov 30, 2007 | Sony Playstation 3 (PS3) Console
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
