Question about Toshiba Satellite L10 Notebook
My Toshiba Equium L10 - 200 notebook has suddenley stopped working. When it's plugged in to the mains there are no lights on and then when I press the power button, the light closest to it flashes once, the fan starts up and that's as far as it goes, I know it's not the power supply or the battery as I have spares of both, Any ideas?
    President:
  • Toshiba Master
  • 2,017 Answers
Just remove the battery and switch it on main power and check.if it is work then connect the battery and conncet the power cord and leave it for 15 minutes and then switch on the power button.
Posted on Nov 17, 2009
  • jd_line28 Oct 01, 2010
    HI. It could be that there is a problem with your power connection in your laptop. The Toshiba A30 has a problem that sound very much like this and it could be the same route cause. In the A30 there is a problem with the power connection on the motherboard, basically where you plug the power unit in. On the A30 it can be fixed by soldering a new power connection in place (or even the same part). The only real problem is that the laptop has to be dismantled to solder the part in place. The part should only cost about £3 pounds to buy and it used to be available on ebay for that price.
5 Suggested Answers
  • 42 Answers
SOURCE: cant find recover disk for toshiba equium l10-300
Most likely you wont be able to find an OEM disk your best bet would be to download a windows install cd and reformat your pc. your product code should be on the bottem of your pc
Posted on Oct 28, 2009
  • 567 Answers
SOURCE: where will i get a motherboard for toshiba equium
Hi there how are you? and welcome i would like to help you find the motherboard you are looking for, but it seem to be a very difficult task i have search everywhere i know but could not find it but it would be great if you double check the model number for your laptop and let me know. you can visit www.ebay.com and you can find anything you want on that website
thank you
if my expertise are helpful to you kindly give me your vote
hbristol173
Posted on Mar 29, 2010
  • 201 Answers
Go on the internet or contact Toshiba. Hope this helps!?
Please rate solution - Thanks
Posted on May 17, 2010
CreativeTECH
  • 1719 Answers
SOURCE: Toshiba laptop screen very dim.
Toshiba Equium L10-300 has LCD Display. The screen displays becomes dark/ dim if there is no back light.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florescent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either of the parts may be faulty or in some rare cases both. The issue can be identified only after opening the LCD Screen.
So, my advice is that you get it properly checked by any professional for replacement of Inverter or CCFL.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Posted on Jul 13, 2011
Where can I find manual for Toshiba Equium A200-15i?
Toshiba has the user manual as a zipped pdf in their archives. http://www.toshiba.co.uk/innovation/download_manuals.jsp?service=UK (use the drop down menus to select Archived files, Equium notebook, series A, A200). The direct link to the A200 PSAE0 is here: http://support1.toshiba-tro.de/tedd-files2/0/userman-en-20071025135106.zip . You will need to extract the file from the archive and then open it with Adobe Reader or a similar program.
I hope this helps.
May 20, 2014 | Computers & Internet
My Toshiba Equium A200-196 will not switch on - power light is on and it's plugged into mains but pressing the on/off switch, nothing happens!
hello
try this: remove your battery and plug directly to the main power w/out battery. second remove thebattery press and hold the power button for ten seconds and put the battery back and power on your laptop.
thank you
Mar 11, 2011 | Toshiba Computers & Internet
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
May 05, 2010 | Toshiba Equium 100 PC Desktop
My Toshiba Equium laptop won't just turn on. When I press the power button it blinks for a few seconds and then turn off.
Is the power plug plugged in. Make sure its plugged in, and leave it in for 2 hrs and then try and power on.
If you need more help just post.
Feb 07, 2010 | Toshiba Satellite A60 Notebook
The built in mouse on my toshiba equium has stopped working i had plugged in a mouse to help any ideas please
try removing it in the device manager, and add new hardware so it automatically detects again
Dec 09, 2009 | Toshiba Satellite A135-S4527 Notebook
I cannot change my main display on my toshiba equium from portrait to landscape please help me everything is working backwards!
in the right hand of ur desktop screen, u find graphic option.
U jst adjust 4m here, to display portrail to landscape.
Nov 14, 2009 | Toshiba Equium 100 PC Desktop
Touchpad on toshiba equium A200-1VO laptop not working
you have lost your driver for the cursor .
go to :
  • www.toshiba.com/taecdpd/support/drivers.shtml
  • this should have all the drivers required for your PC .
    give it a try and let me know how you go
    Sep 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
    I need to reboot my toshiba equium l10-300 laptop with no cd
    Try starting in safe mode. Hold down oth the control and F8 kays and press power. Do not release Contro & F8 until it starts to beep. Then it shoud start in safe mode. If the computer will not start in safe mode you have a hardware problem. If it starts in safe mode, you have a Windows problem that re-installing Windows will solve that (to a point). Without the Original CD and install code, you have two options. Buy a new OS or.......pirate it. I do not recommend the last.
    May 28, 2009 | Toshiba Satellite L10 Notebook
    Toshiba notebook equium A210 (not listed here) touchpad frozen. cursor not moving? help please?
    try re-starting the computer; if that does not work install an external moue and try navigating withthat. If that works it is that the touchpad has been damaged; or the drivers arecorrupt
    May 13, 2008 | Toshiba Satellite A135-S4527 Notebook
    Toshiba Satellite L10 Notebook Logo
    275 people viewed this question
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
