Question about Sebo Automatic X1 Bagged Upright Vacuum
Can you help me change the Sensor in my Sebo Auto X-1
  • Philip Gaut May 11, 2010
    Do you still need help with this?
    President:
  • 389 Answers
Do you still need help with this, or has the moment passed? If you still want help, please state why you think the sensor needs changing.
Posted on Dec 26, 2009
Body of sebo x4 automatic not rising or falling
This could be due to the brush roller being worn.
If the brush roller is worn, then the height sensor makes the vacuum head go down fully. There still isn't enough resistance to the brush, but there is nowhere else for the height adjustment to go, so it just stays there. If you look at the cleaning head from the side you should be able to see that it is fully down.
The brush roller light is supposed to come on, but in my experience, it might not.
Feb 28, 2016 | Sebo Automatic X4 9570AM White/Gray, 10...
My sebo cleaner keeps almost cutting out but comes back on again after a couple of seconds. I.ve checked for blockages and changed the bag and filters.
Sounds like a bad sensor or a possible loose connection electrically. If you are very handy with tools you could try taking things apaet but a dyson is expensive nso I would leave it to the pro's and take it to the local used vacuum shop. They give the best advice in these situations.
Oct 07, 2010 | Sebo Vacuums
How to change belt on sebo the big drivebelt
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment. (This is the policy of Sebo America, if you're in the UK please check Sebo UK"s policy).
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Aug 09, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Full bag clog light
1.If your sebo is less than five years old, you have a reciept, and are not using it commercially, in most cases this machine will still be under factory warranty. To locate
an authorized sebo dealer simply call sebo or use the dealer locator on their website.
2. If it is no longer under warranty:
First i would pick up something small such as a balled up gum wrapper and make sure it makes it to the bag, more often than not something is not checked, and its still plugged. Heres how i'd check for plugs.
  • Pull the wand out and remove it from the hose by pressing the button on the wand look through the wand
  • Remove the hose from the machine by pinching the hose clamp and pulling the hose out (it simply presses back in when you are done)
  • press on the large button below the bag compartment on the front. (its often a different color and presses difficultly) lift the bag compartment and handle off the powerhead. (replace by simply pressing the bag compartment back onto the head)
  • look down the powerhead and inspect the other areas of the bag compartment.
  • open the orange/gray door on the bottom of the powerhead and look through checking for debris.
Simply go back up through the steps to reassemble.
If your test makes it into the bag just fine and you are not plugged, the tall filter inside the bag compartment would be my next suggestion and since you changed this it should not be a problem. This leaves few possible problems. Circut board error/Sensor error would be my next step. Essentally its one in the same, but there is no great way to test them without simply replacing parts. (an expensive proposition) The local sebo dealer will more than likely have a working used board they pop in and out to check for problems. Some dealers may let you use these others will require you either buy the parts or pay for labor.
*Bad boards in sebo/windsor products are extremely rare, my bet is always on a plugged filter or plug in general. Be sure to look carefully something as small as a toothpick surrounded by carpet fuzz can set them off.
Best of Luck
Jun 05, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Need Sebo x-1 parts
Hi
contact them direct they will help you out
SEBO America, LLC
7472 S. Tucson Way, Suite 190
Centennial, CO 80112
or look here
http://www.sebo-vacuums.com/frameset.htm?dir=Support
Please leave feedback for me
Thanks
Rob
Feb 12, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
I need to know how to repalce the drive belt in a Sebo upright cl
Thanks to its automatic height-adjust feature, the Sebo X4 has two drive belts, one from the motor to the height-adjust sensor, and another from that sensor to the brush roller. To access them,first remove the base from the handle, undo the four recessed screws on the underside of the base, then turn it over and lift off the cover. You will then see the belts. The rest should be obvious (it's a while since I've done one of these, but I think you may have to loosen the screws holding the height-adjust sensor before you can slip the belt off).
I hope this helps. Any further problem, just re-post here and I'll do my best. Good luck!
Feb 01, 2009 | Sebo Air belt K3 Bagged Canister Vacuum
Windsor sensor sr12
There is a downloadable manual from http://www.windsorind.com/ go to documents, and note it is in alphabetical order -- so page through to "sensor" or you can search on the word "sensor" (don't include SR12). Also excellent training video on youtube http://www.youtube.com/watch?v=ikhtNFEKpeg.
I think, but not validated yet, that the Sensor SR12 (residential model) has been discontinued as I found it listed in their manuals under the discontinued section as well.
Jan 28, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Sebo Automatic X1 Bagged Upright Vacuum Logo
97 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
