Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60" Phillips Magnavox
My PM 60" rear projection use to expand and contract until it got warm, but now no picture or sound. Do anyone have a solution? What part need to be replaced?
  • 579 Answers
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Posted on Jan 10, 2008
My picture shrank and loss picture
Common problem and a fairly easy DIY tv repair. Goto the site Tv Repair Kits and get their "video shrinking and expanding" fix for your model.
Jan 09, 2013 | Philips Magnavox 9P6034C 60" Rear...
Picture shrinks , pulseates, color off until warms up
This is a very common problems with this model. Goto www.TvRepairKits.com and get there shrinking and expanding kit for your philip magnavox model.
Apr 05, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magnavox rear projectio9p6031c103 The picture quality is terrible
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Hope this helps,
Dec 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
60'' phillips pro
Easy fix....Goto www.TvRepairKits.com and get a chip kit.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 9P6040-C101-60" Rear Projection Television
You can get a repair kit for the shrinking/expanding on www.magnavoxhelp.com. This is a common problem with this model.
Sep 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Projection TV - Model 9P5511C
Common problem with the model. Check the site www.TvRepairKits.com. They have a fix for the shrinking and expanding screen problem.
Sep 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sound but no picture 60in phillips television
I beleive you can get a chip to fix this problem from www.magnavoxhelp.com.
Aug 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
PHILLIPS 60 IN
Shrinking and expanding or no audio/video is fairly common problem.Goto www.magnavoxhelp.com to see if they have a  repair kit.
Jul 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Warming up
Hello All,
The symptoms you all mentioned are signs of a HV regulation problem. This could be caused by the IHVT (Integrated High Voltage Transformer) or the HOT (Horizontal Output Transistor) array. I would suggest that you all have a qualified TV technician troubleshoot your TV sets and affect repairs on them.
I hope this helps,
Thank you,
Shuttle83
Nov 26, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
