Question about HP f2105 21" LCD Monitor
How do you take apart an HP w1907 monitor? I have one that the picture only stays on for a split second at power up and then goes blank. I suspect a filter capacitor but can't take it apart to check.
  • Ken Chu Nov 18, 2009
    This worked great. I got it apart but the caps look fine. There were no signs of bulging and I tried resoldering some of the components but no luck. How did you make out with yours?
    Problem Solver:
  • 5 Answers
Haha, been there. This ones a little tricky. Hope you have strong fingers. start by removing the base. There are 3 screws. First pull the base plate off. Then remove 2 screws. Next remove the little rubber insert in the center of the base bracket. You will need a long phillips to get to the 3rd screw. Slide out the base bracket. Flip the panel over and stare at the lcd with the buttons side on the top. Grab a small flat head screw driver. Look at an angle in each of the corners between the inner black lcd trim and the silver outside trim. There is a ****. Shove the flathead in there and pry outward toward the silver trim while lifting on the black inner trim vertically. The trick is to flex the black trim toward the silver and then pull up. There are 6 plastic snaps on the top and bottom, and 4 snaps on the left and right. If you've taken laptop screens apart, you'll feel the similarity.
Once you pry the black trim off the front. Disconnect the LCD Menu button assembly and power button. Then flip over the LCD and lift off the back shell. Looking at the back, remove the 2 connectors for the speakers. Use a small flathead to pry the 4 Inverter power connectors. These 4 connectors have a clip on them and are usually hard to pull out using the wire. Once thoses 6 connectors are removed, remove the 2 phillips screws holding the AC power plug to the case. Also remove the 4 3/16 posts for the VGA and DVI ports. Next remove 4 screws, 2 screws from each side of the LCD assembly. Hold the panel face down with the aluminum tape in the bottom left. Lift the shield and guide the 6 wires through the cage. While opening, look inside and disconnect the flat ribbon cable as soon as you can. Put the LCD to the side. Remove 2 screws from the Video processing board, and 5 screws from the power supply. Note: 1 of the 5 screws is longer. Rotate/slide the power PCB away from the cage to clear the speaker and AC plug, Then rotate towards the Video board. Disaconnect 1 plug. The OTHER plug is SOLDERED and must be disconnected from the video processing board.
There you have it. It stumped me for about a half hour. No pry marks. Barely noticed the 2 slits in between the trims. Well, good luck. Happy Soldering.
PS: I opened mine because I assumed it had bad capacitors. It only powers on for a short short period of time.
Posted on Nov 17, 2009
Testimonial: "The instructions were very clear and step by step. Once apart, I couldn't see any signs of bulging caps so I tried resoldering some of the connection"
    Novelist:
  • 242 Answers
It could be a filter cap, but more than likely you have a bad light tube (skinny light bulb behind the LCD assembly). See if you have two tubes once you get in to see if the lamps are black on their ends... The black means that the tubes are burnt and is shorting out the high voltage power supply be being "carbonized" at the proximal end of the tube. This is most common reason for the short "on and back off" situation. The filter caps can be the issue too though, so if they look normal (not bulging into a basketball shape), check your fluorescent bulbs located on the photo-multiplier section of the screen (part that resembles a big flat block of clear plastic. The light bulbs look like a very long toothpick that is white with wires on each end of it... It is glass and fragile too. These are usually "taped" to the photomultiplier block with an either silver or black tape to keep the light from escaping from the end of the block.
To get into the case (was that your question to begin with?).. you need a plastic putty knife to pry the front and rear case loose by unlatching the latches which you can not see. Go from the back to the front to catch each latch one at a time, and do not pull on the case halves to pull apart as this will more than likely break the latches off. Putting back together is simply snapping the halves back together.. it is much easier to put together than to take apart, so be sure all is good before snapping back together.
Let me know if that helps.
Posted on Dec 01, 2014
There is no **** anywhere. Photos would be appreciated.
Posted on Oct 30, 2014
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
Bought it in 2008, now it comes on for 90 seconds then goes out. Probably a bad inverter or power supply board. Are parts available for this monitor?
Is it the screen that goes blank or the power of the monitor? is the power led button on?
If the power led button is on, and it is the screen that goes off, this indicates that the picture board of your monitor is malfunctioning and will need to be replaced.
But if it is that everything goes off, it means the inverter is bad and will need to be replaced.
For the parts, yes, Being HP is even advantage, because virtually,most service centers do have the parts
Just walk to any hp service or any service center within your vicinity to get them.
Take care
Apr 25, 2010 | HP w1907 LCD Monitor
Computer screen goes blank after a couple of seconds
the back light of my hp w1907 will only come on for a second than go back off?? the rest of the monitor is working can see the image if you shine a light on the screen ..any help??
Comments: Oct 26, 2009 - so this monitor was not in warranty so i took it apart i found a wire broken off one of the backlight bulbs, ( be very carefull the bulbs all four of them and the lcd screen are very very fragile ) so i soldered the wire back on and put it back together and rechecked it it has been working like new
Nov 24, 2009 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
I turn my monitor on and it lights up then goes blank.
sounds like you have a backlight problem, the wires are known to burn off the ends of the bulbs of the back light..if you try to repair it yourself be careful the lcd screen and bulbs are frigile.. there is 4 bulbs two on the top and two on the bottom of the screen ,, keep every thing in order when taking apart
Aug 01, 2009 | HP w1907 LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
HP f2105 21" LCD Monitor Logo
3,367 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
