Question about Sony Televison & Video
My DVD player / recorder keeps kicking out the discs I put in. It won't even read them. the screen says close and the tray comes back out almost immediatly. Now it's gotten so bad that the tray won't come out all the way and the machine just keeps pulling it in and then kicking it out. I found that it does this with or without a disc. what do I do?
    Scholar:
  • 53 Answers
How old is your DVD recorder/player?
It sounds like it needs a service!
The usual problem with DVD players/recorders not reading discs is that the laser output is starting to fail - and consequently the laser light emitted is insufficient for the system to "read" through the minute "holes" in the disc.
It's possible to have the laser replaced, but this would cost you at least £50, depending on where you live.
Initially, you could try buying (or borrowing) a laser cleaning disc. These cost around £3 to £5 depending on where you buy & live, and have a small brush on the lower side of the disc. Insert this into your player and run the disc for a couple of minutes. If there are any dust particles that have been blocking the light output from your laser head, then this may remove it and might solve the problem.
If this fails, then it seems likely that the laser head is not producing enough output and would have to be replaced with a new one.
Also, you could try playing a CD on your DVD player as these discs contain far less information than a video disc (DVD) and the laser head may be able to cope with this.
If the CD plays ok, then you will know that the reason why it won't play DVD's is the light output has started to fade due to the age or excess use of your system.
Posted on Nov 17, 2009
  • dachshock Dec 03, 2010
    Dont forget the easy solutions. Most CD and DVD players use rubber belts to open/close the drawer. They get greasy, stretched, cracked. Belts are available from many suppliers or repair shops. I use MCM electronics. (mcmelectronics.com) These belts are about 2 to 3 inches in circumference. Cost: abou $2. I see this problem frequently
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
I have an RC100H that keeps opening the DVD/CD tray as if it does not read the disc. Even if I have no disc in it the tray opns and stops. The only way to keep the DVD Tray closed it to hit the close...
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | LG RC199H DVD Recorder/VCR
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
Dvd tray will not stay closed even with no dvd in tray
try wen u press the close button with a dvd inside just keep your finger pressed against it until the dvd starts to read then it will come on and your disk day will stay closed
Jan 25, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
LG DVD REcorder disc tray will not open
Most likely the tension band that is attached to the mechanical parts of motor and the tray detached. you'll need to disconnect the power and unscrew the cover open and put the band back in place.
May 21, 2009 | LG DR787T DVD Recorder
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. stacy_sunshine_t@yahoo.com if anyone can help.
Sep 17, 2007 | Panasonic DMRES15 DVD Recorder
Televison & Video Logo
229 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
