Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
Red picture with vertical lines
I have not used my sony pd170 for a while and when I switched it on it shows a Red picture with vertical lines. You cant see any picture but does go darker when you put a hand over the lens.
  • 72 Answers
CCD CONNECTOR MUST BE LOOSE.
Posted on Mar 24, 2010
My dsr pd170 lcd view screen is viewing in negative imaging. it seems to be filming fine, but the image quality slowly degrades while filming. Since we work at a camp and film things like talent shows...
dear
first tell me when u close the lcd pannel , then is the view finder working fine , if not then
view finder cable is broken . u cant fix it your self as u need to open the camcorder .you must not be having the proper tools for that.
and regarding the lcd part , if the display is fine for a while ..and then
while using it it goes fade , shows grey colour or lines in it . then its lcd problem ...ur lcd need to be replaced .
Jul 25, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
I have a sony pd170. On the lcd screen appears "CP" What does it mean?
I am one of the lead technicians at superb broadcast equipments. We are a repairshop that specializes in only Sony camcorders.
Theproblem that you are experiencing with your Sony PD170 sounds that its just normal settings u just press the button on your handle where the red light blinks when we are recodring, when you will press that button the option would blink in your lcd screen ,then turn that off .and then CP i.e, coustom preset option would disappers from the lcd.
Jun 09, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Red vertical lines and horizontal flashing lines on viewing screen plus fuzzy picture.
Its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
With sound but no video only raster with vertical lines
The resistor (r9335) on the blue crt base board is open and burned thats why the 200v is missing. replacing the resistor will solve the problem. cheers!
Apr 08, 2009 | Sony KP-FX532M91 TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony cybershot touch screen camera
maybe..it's have a picture tube problem..i think that you should go in a proffesional to fix your camera..that's only my opinion..thanks
May 20, 2008 | Sony Cybershot S650 Digital Camera
Sony DSR-PD170 - playback problem
problem is caused by a defective image sensor block.  check with Sony; you may be covered under warranty.
Oct 12, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
96 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
