Question about Samsung SCX 4521F All-In-One Laser Printer
Somebody just faxed me some papers, the fax says " Memory Received" but not printing anything.
    President:
  • Samsung Master
  • 2,022 Answers
The job is still in printer memory make sure there is toner is working and the paper are it system try.also see the error massage on display .
Posted on Nov 17, 2009
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
Brother 8360p has faxes in memory but will not print them. All the faxes ar going into the memory now. It has paper and toner, check by making a copy. the menu 2 5 4 fax command doesn't do anything,...
I have seen a few Brother faxes do this. I fixed them by turning off the power, holding down the clear/stop button and keep holding it down while you turn the power back on. Keep holding it for a few seconds then release. This will clear what ever is in the memory that is locking up the memory print. Note: you will lose any received faxes in memory by using this procedure.
This may help you restore your fax to a operation condition.
Good Luck and Thank You for using Fixya.
Aug 19, 2010 | Brother FAX-8360P Plain Paper Laser
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Error 322 - see printer message
The fixing assembly (The hot rollers) of the printer is faulty. This need to be replaced by a service technician.
Faxes are received in memory because they cannot be printed.
Nov 11, 2009 | Canon FAX-L350 Plain Paper Laser
Memory received but i am not able to received fax
Please change the toner and feed the papers. It will print all the faxes recd in memory.
Nov 05, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Fax Spam
I couldn't find anything specific to delete the memory without actually printing it,
here's a copy of the manual if you need it:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FHD331%20Plain%20Paper%20Fax.pdf
May 26, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
How do you print on legal paper from memory?
You have sent a fax? Or you have received a fax.
If you have sent it, it's gone and can't be printed.
If you have received it, then you obviously have to put legal paper in the tray, and program the paper size in your system settings to tell the machine it is Legal paper in the tray. However, once again, if it has already printed the fax (likely on 2 pages) then it's gone from memory and can't be re-printed.
May 11, 2009 | Canon FAXPHONE L80 Laser
Received fax in memory but not printing
I just checked this out as I had the same problem. It seems that the machine is programmed to stop printing faxes when the Toner is "out". Even though the toner is not completely out. I was positive that the note on the screen was false since I could print out documents and copies (I am not using Samsung original Toner). But the fax will refuse to print.  I fixed this by changing the toner (again with a non-Samsung toner) and it is printing all the faxes in memory.  It is stupid that they haven't set up a menu item to force it to print all the faxes in memory but voila, that seems to be the fix. I guess this is a way for them to control that we only use Samsung toner.
Dec 12, 2008 | Samsung SCX 4521F All-In-One Laser Printer
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
Samsung SCX 4521F All-In-One Laser Printer Logo
81 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
