Question about HP LaserJet P3005dn Printer
I am experiencing lots of horizontal lines, changed the toner but still getting them?
    Genius:
  • 1,089 Answers
Measurements. What is the distance between the horizontal lines?
43.6mm = transfer roller
47mm = toner cartridge
62mm = pressure roller(fuser)
76mm = fuser
Posted on Feb 23, 2010
  • 330 Answers
Clean inside of the printer and transfer roller , drum unit and shake the PU unit and check .........
Posted on Nov 17, 2009
2 Suggested Answers
  • 21 Answers
SOURCE: We have put a new toner in but still we are
Check the fuser. If it is the fuser, you should be seeing 3 dark lines on the fuser film. Here is the picture about how the film looks like:
Changing the film usually solve the problem. However changing the film itself is difficult. You have to remove and basically disasseble the fuser, and change the film. However it is fairly cheap and if you decide you would like to save some money, here is the link available in ebay:
http://cgi.ebay.com/Fuser-Film-Sleeve-HP-LaserJet-P3005-RM1-3740-/250558576965?cmd=ViewItem&pt=BI_Toner&hash=item3a56747945
Or, simply search for 'P3005 Fuser Film' and you will find a lot.
Other than that, you can change the entire fuser. Please note that fuser for P3005 is not consumer installable part. You still have to take out some parts in order to change the fuser.
The parts are available from many parts supplier. Simply google 'P3005 fuser'. Usually around $100 for a refurbished fuser.
You can also recycle your old fuser and get some moeny! (about $15-$25 per fuser).
Posted on May 09, 2010
I experienced horizontal white lines copy on my fs1135 mfp could anyone had an idea? . pls. help me with this experts
This normally means you have issues with your laser or developer. I would try changing developer first.
Feb 03, 2015 | Kyocera Mita FS1135MFP Black Toner...
Tip
When u print if u r getting the Horizontal or vertical line then follow these...
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
on Aug 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
I get a white line through but it is not telling me to change toner?
This can occur if you receive a lot of faxes that may have a vertical block or a lot of text or pictures etc. in the same location on the page. The toner can be used in that particular area of the page and a white line results.
Remove the toner cartridge from the fax, keep it horizontal. Shake it side to side whilst keeping the cartridge horizontal. This redistributes the toner inside the cartridge. Replace the toner cartridge in the fax.
Hope this helps.
Feb 09, 2010 | Brother IntelliFax-2820 Laser Fax
We have put a new toner in but still we are experiencing lots of horizontal lines??
Nov 17, 2009 | HP LaserJet P3005n Printer
Dark Horizontal Lines on Faxes
on the drum unit that you put your toner inn, There is a blue or green slide lever move the slide back and fourth 10-15 times. If you have some van air blow that area out ( F.Y.I. if you do this some toner will fly out ) if this does not take care of it the drum unit my be bad,
do a 1/2 print test. copier something with a lot of print. open front cover when the paper is 1/2 way through the machine remove drum. Look art the paper and the green drum if the marks are on the paper & drum then the drum is bad. If not the fuser asm is bad, the part that gits hot when melting the toner on the paper,
Jan 29, 2009 | Brother IntelliFax-2820 Laser Fax
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
Horizontal Lines
try another toner and see if it changes. if it does not then you may need a fuser,
Oct 16, 2008 | HP LaserJet 2300 Printer
HP LaserJet P3005dn Printer Logo
534 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
