Question about Dell Vostro 1710 Laptop
CD ROM has disk but this will not eject - there is no little pin hole on the vostro 1710 anywhere, nor does hitting eject from the Bios screen work....
  • dsmith32 Nov 17, 2009
    Rulds2008
    Thanks for trying but there really isn't a pin hole anywhere on my laptop...honestly..... the bacxk has tweo removable covers - would it be inside.....
  • Dell Master
  • 3,866 Answers
Cd-rom will need to be extracted from unit the pinhole is lickly on the back of the unit most are. good luck please do leave postive feedback ether way for your free answer today.
Posted on Nov 17, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Nov 17, 2009
    Yes indeed that is what I meant, I am a Dell Expert to know that these drivers when the do not eject have ether a stuck disk or a bad ejector motor the unit will need to be opened to eject from inside, Thanks for your reply.
  • 77 Answers
You have to replace your cd rom drive
Posted on Dec 24, 2009
    Sergeant:
    Champion:
  • 202 Answers
Fistly you change your drive eject gear or you use pin to eject drive.
A small hole given on the face pannel of drive, you inter pin in hole & puss it. your drive eject.
How do you eject a cd from an alienware 14
you should be able to see a very small pin hole on the cd rom itself.
Get a paper clip and unfold it, insert the longest end into the hole until it hits something and give it a push.
You can also go to the cd\dvd rom and right click- eject
Jul 22, 2014 | Alienware PC Systems Alienware M14X 140...
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
Can not insert CD into Drive
You can flip the laptop over, find the screw(s) holding the drive in the bay, remove the screws and the drive, and then either attempt repairing the drive (highly likely not to be worth the time), or breaking down and buying a replacement that does have a tray. Old laptop parts can be quite expensive, but CD-ROM drives in laptops old and new are often quite widely compatible among many makes and models.
Apr 18, 2014 | Dell Vostro 1710 Laptop
CD can not be inserted into the CD drive of laptop.
did you try to eject it thru the software ? Go to your (My Computer) and open up to see the Drive. Right Click and Eject. If that don't work you can manually put a paperclip in and Pull out the drive. When all else fails remove the screw that is holding the drive in the laptop and pull it out to inspect it for damage
CD drive wont let me insert CD
Loading mechanism fault. In most cases, the CD ROM might be replaced. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
How do I eject cd tray on latitude E4310 ?
don't know of that labtop but hit start, hit computer, right click on cd drive hit eject.
Jan 17, 2013 | Dell Latitude E4310 Laptop Computer (Intel...
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
I have cd that won't eject. it is a "green" cd and is thinner that standard cd-roms. I have a Dell Vostro 1510 and am using Windows Vista premium.
There is usually a little hole in the dvd draw facia that you can push a thin object like a paper clip into. this manually opens the draw
Jul 10, 2010 | Dell Vostro 1510 Laptop
Dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
May 24, 2010 | Dell Vostro 1510 Laptop
CD ROM is in the 1710 but system does not recognise disk and now will not eject. I have tried from the BIOS screen but no luck....
First get the cd out. On the side where the cd tray is there should be a little pin hole. Stick a pin in gently and that should release the cd tray and eject the cd. Then try updateing your cd rom drivers, uninstall and reinstall....
Nov 16, 2009 | Dell Vostro 1710 Laptop
Dell Vostro 1710 Laptop Logo
2,059 people viewed this question
Alun Cox
