Question about Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius washing machine wont go into a spin cycle I have checked that nothing is blocking the drain outlet. Can you help please?
    Genius:
  • Hotpoint Master
  • 1,466 Answers
Could be worn motor brushes if about 4 years old...cost of parts about £15 GBP...
Posted on Nov 17, 2009
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
I have a hotpoint WF250 1500 spin. It wont drain. i cleared filter but still not drain when restarted. What would problem be? i cannot find the user manual.
Could be a blocked pump or outlet hose, remove the hose and lay it down to floor level to drain off water, then remove lower rear cover of washer, and remove the hose from the pump, see if it nis blocked, couls also be a faulty pump.
Nov 30, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing machine won't spin
check the pressure switch the unit wont spin unless it knows all the water is out of the unit
May 28, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
379 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
