Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
My plantronics bluetooth won't charge. It lights up red when I first plug it in but the light only stays on for a min or two.
SOURCE: charging plantronics 520/521
The red light will stay ON while charging and will go OFF when charged. Charging does not take long. Since you have no manual, you turn the headset on by pressing down or toward your head and holding the button down. If it's in your ear already, you'll hear a four-note upward pitch sequence to indicate it's powered on. If it's out of your ear, you'll see a red light, followed by a blue flashing light.
Set your phone into Bluetooth mode and make sure in the menus that Bluetooth is "discoverable" or some such lingo to search for the headset. The pairing code for this headset is 0000 (zeros not O's), so when you set your phone up to pair with the headset and the phone wants a pairing code, enter 0000. After the pairing is completed and Bluetooth is activated on your phone, you should hear a high pitched single tone to indicate the headset is in range and communicating with your phone. If you separate from your phone over about 30 feet or if communication is interrupted with your phone for some reason, there will be a lower pitch single tone, indicating loss of communication. After pairing, you should not have to go through the code sequences or setup again unless your phone is completely reset. You should be able to set your phone to Bluetooth, turn your headset on and hear the four-note sequence, followed by a single high note.
Push the switch up or away from your mouth to step the volume up. Likewise, push the switch down or toward your mouth to lower the volume. I've never turned it down, it's always a little low in volume to me even at max.
Push down or toward your head BRIEFLY to answer or hang up the call. Depending on your phone, you can also activate dialing or voice command by using this same brief push. There is a brief delay between pushing the button and being able to talk on most phones, so you might listen for a volume or noise change before talking.
To turn the headset off, push down or toward your head and hold the button down. You will hear a four-note downward pitch sequence to indicate power-down. If you're looking at the headset, you will see a steady red LED, then it will go off. By the way, a flashing red LED indicates need to recharge. A flashing blue LED indicates the unit is operating correctly.
Remember, battery consumption on your phone is greater with Bluetooth turned on, whether you use the headset or not. Bluetooth units constantly stay in touch with their partners, much like your phone stays in touch with the cell towers. So watch your phone's battery indicator a little more closely until you get used to your talk patterns and general use. Depending on your situation, your phone may not use much more battery than before.
Standby (inactive but ON) time on the headset is very good, and battery shelf life (power OFF) has been good also. These headsets are extremely useful in a car or if you are busy with your hands during calls. Just remember to use your head (pardon the pun) and not take or make calls while doing something dangerous. You wouldn't do that with your corded home phone, would you? The vote is still out, but they do tend to look a little nerdy when worn constantly in public. I hope you get as much benefit from your Bluetooth headset as I have from mine. I thought they were completely Nerdsville before, but I'm a convert now. Good luck.
Mark in Oklahoma
Posted on Aug 28, 2008
  • 7 Answers
SOURCE: Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Posted on Feb 04, 2008
SOURCE: Plantronics Bluetooth Headset P590
my headset doest charge too. i tried the desktop stand...and the AC adaptor....but no power comming through. i cant say that my power isnt working coz when i tried the universal adaptor...that was charging fine. i have got a P590. PLZ HELP.....thankxxxxxxx
Posted on Jun 17, 2008
SOURCE: My plantronics explorer 230 won't turn on.
hold down both buttons together for about 20 seconds... blue light should come on and work properly again...
NAES
Posted on Apr 15, 2009
pincode
Posted on Oct 30, 2009
My 220 won't turn on. Red light stays on when charging but when unplugged won't do anything
The link below on page 7 has the sequence for turning on your headset (Explorer 230 and 220 work the same). If you're still having problems, then it needs to replaced.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Oct 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My plantronics explorer 240 its dead, when i to charge the red light flashing, but dont charge.
If your headset is not charging, then the battery has breathed its
last breath. Now's the time to take a look at what's new on the
attached link for Plantronics bluetooth headsets.
Plantronics Bluetooth Headsets
Sep 15, 2011 | Plantronics Explorer 240 Bluetooth Headset
Hello. My Plantronics 210. My headphones won't come on. I had this problem before, I took it back to the store. They said there wasn't anything wrong but now it's doing the same thing. The red...
I would try deleting the headset from your phone. Do a re pair or subscribe to your phone. I am sending you a Plantronic user guide for the Explorer 220.
Jun 28, 2011 | Plantronics Explorer 220 Bluetooth Headset...
THE CHARGING LIGHT DOESN'T COME ON. I CHARGE IT DAILY BUT WENT ON A TRIP FOR 5 DAYS AND WHEN I RETURNED THE LIGHT WON'T COME ON...RED OR BLUE.
Per Plantronics: The Voyager Pro is not a moisture resistant headset. So if you have worn the headset during work outs or outside in excessive heat it could cause it to fail.The only solution is to have the headset replaced if still under Plantronics one year warranty.
May 23, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics explorer 260 won't turn on. Also when I go to charge it the charging light stays on for about a few min. and then shuts off but i still can not turn it on. Please help
Here are a few steps to review before coming to the realization that your battery could be wasted. Give them a try and see if it helps any.
1) While your headset is charging, the indicator glows red. When your
headset is fully charged, the indicator turns off.
2) Turn off the headset: Press and hold the call control button until the indicator glows red. You will hear descending tones. When power is off, indicator stays off.
3) Turn on the headset: Press and hold the call control button until the indicator glows blue. You will hear ascending tones.
Feb 24, 2011 | Plantronics Explorer 232 Bluetooth Headset
Need guide/manual for Plantronics 222 Blue Tooth
first question,i have anplantronics explorer 242 when i plug it iun to charge it the light ired then after a few min. it turns blue,how do i know when its fully charged? will the lights go off?
Dec 16, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
1,501 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
