Question about HP LaserJet 3000 Printer
Showing close front cover.buts its already close
  • nadeem175 Nov 17, 2009
    i did the same.but still 10.92.03 cartridges not engaged message coming and close front door.also
    President:
  • HP Master
  • 2,017 Answers
May be it is not close properly remove the alll the paper and try to close it .switch off the printer and switch it on.
Posted on Nov 17, 2009
Front cover is on alarm even the front cover is already closed. how can i reset the alarm.
Hello, Did the technician ask about any error codes in display?
For Example the number 2 from the center picture on display ( the picture of machine) or by pressing and holding the * (star) key on number pad show 2 numbers with the second being 817 in the red number area?
When the door is closed there is a one inch thin piece that gets inserted into a slot that activates a switch proving the door is closed..
There several resets you can try - holding down reset while powering on machine, Holding down just the "print position" left and right arrow keys (not the center) . and powering on equipment then typing "94" and then press start key. Note press clear if any numbers show up before hand.
If no results the part on door has broken or the switch is out of position to activate correctly,
Please tell any codes and we can go from there. TY
Jan 29, 2015 | Riso RZ220 MASTER UNIT - ONE ROLL PACK
Open the top cover and insert a toner cartridge. message shows when i try to print but top cover already closed properly
check on the left hand side of where the top cover opens , in the inside there is a clip along with a senor
check that it si not stuck . if that doesn't work, open the top cover hold in the cancel button or the bigger play button ( differs printer to printer ) or both for approx 10 - 20 seconds , you will see all the lights flash remove the toner , re-insert the toner & close the top cover . This will reset the drum unit & the printer status. Alternativly switch the printer off ( with top cover closed ) hold in one or both buttons and turn it on for approx 10 - 20 seconds again , you will again see all the lights flash, Your printer will reset its status And clear its page count .
also try open the back cover close the front then the back , press cancel or play button twice there after.
( this is a common diagnostic procedure with small laser printers )\
Please post back if this doent solve the issue
Thanx
May 27, 2011 | Canon LASER SHOT LBP-2900 Printer
Front door already closed m/c please closed front door
hai,
check front cover left side clay plate position. its make a full pressure in the main door switch. if proper it is ok.
check front cover switch mechanisum and wires connection also.
best of luck
May 31, 2010 | Canon imageRUNNER 400S Copier
It says close back cover but back cover is already closed
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Apr 19, 2010 | Brother MFC 7420 All-In-One Laser Printer
Can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
Brother MFC-7220 says close back cover but it's already closed
May 13, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC 8840D still says change drum soon
press clear/back button
press 1 and when the lcd shows accepted, close the front cover.
thanks adi
Apr 27, 2009 | Brother MFC 8840D All-In-One Laser Printer
"Close the front cover" sign even the door is closed already
On Canon copiers the close front door can be caused by other doors besides the front door.Try the fuser door an the left and the vertical transport door.Good Luck
Mar 27, 2009 | Canon imageRUNNER 400S Copier
1) fax problems 2)change drum (already did but nd to chng count?
1. Open the front cover, and then press Clear/Back.
2. Press 1 and when the LCD shows Accepted, and close the front cover pressing firmly on each side until they click into place.
Feb 19, 2009 | Brother MFC-8840D All-In-One Laser Printer
HP LaserJet 3000 Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
