Question about Electrolux Vacuums
I vacuumed a sock and it started to smell like it was burning. i removed the sock from the brush head. now it still sucks, but the brush doesn't roll anymore. any ideas how to fix it?
    Scholar:
  • 70 Answers
Change your belt.
Posted on Nov 17, 2009
How to restart brush head after clog. See details.
Check the belt that drives the brush head, you most likely burned it up and you need to replace it.
Dec 27, 2016 | Vacuums
What is causing the beater bar brush to spin extremely fast?
HI, it's Jim from Crucial Vacuum!
First thing is to be sure to unplug your vacuum. Once you begin smelling a burning smell it's essential to stop vacuuming immediately.
One of two things may be happing here:
1) Your brush roll may need replacing. It's possible that the sides where it attaches to the vacuum have been worn down with age. The bristles falling off is a clear indicator that it's time to replace the brush roll. Also, look for debris, or hair that's wrapped around the brush. Remove all of this with either a razor, or a scissor.
2) Check your vacuums belt. Is it wrapped around the brush roll at all, or is too loose? If so, this means there's no tension around your brush roll and it could be causing your vacuum to overwork the motor and overheat, hence the smell.
Clean this area out and then replace the brush roll and belt. You should be seeing a noticeable difference in both your vacuums suction, and a lack in the burning smell.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 30, 2015 | Vacuums
Why is my DC24 not working
You may have an object caught between the belt and brush roll.
Remove brush roll cover and see if that is the case.
Regards,
Dennis.
Aug 23, 2014 | Dyson DC24 All Floors Upright Cleaner...
Vax troubleshooting
Burning smell from a vacuum usually comes from the belt....check
for any objects caught between the belt and the brush roll. Is the
surface selector at the correct setting?
Aug 16, 2014 | Vacuums
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Dirt Devil R088100. Cloth Was Sucked Into Hole Below Dirt Holder
Brad, Hopefully it is the belt that you smell burning. I would start by removing the underneath side of the vacuum head. Normally just a few screws that are meant to be remove for general maintanence and circumstances such as this. After removing the screws this should reveal the dirty side of life to you. You may need to remove the roller brush, and inspect the ends to make sure the brush rolls freely while holding the ends. If not the ends may need to be cleaned of hair and strings: ends should pop of and a shaft runs through the middle connecting them. Clean and replace. Move on up the path the dirt travels. The neck where the head and vacuum come together is the next jamming point, if this is where the cloth is lodged chances are the motor may have over heated due to clogging. Your vacuum may have a automatic shut off. You will need to contact Dirt Devil to see if there is a reset for the motor. There are propellers / fan blades at the end of the neck just before the motor housing. This is most likely where the clothe has logged itself causing the brushes on the electric motor to emit the burning smell, if you can remove all obstructions and the unit still does not turn on, check with dirt devil about the reset, Hope this helps.
May 25, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Vax mach 5 burning smell and revving loud
The revving/burning is because the belt is burning off and the power head motor is running without load...
Flip the carpet power head upside down on the rug and look for visible screws and screwdriver release slots on the bottom plate of the head.
When you remove the burned belt determine the cause. Will the brush roll freely or is it jammed with hair and fiber?. Clean the burned rubber from the motor shaft before replacing the broken belt, available at a vac specialty shop.
Sep 04, 2009 | Vacuums
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Fantom Lighting Power Head
The red light tells you that that there is a clog, either in the hose or down by the brush roll. The smell if it is rubber smelling, then it is the belt and maybe the brush roll. If it is an electrical smell, then probably the motor. But parts for these are always available, they went bankrupt several years ago and aren't in business anymore.
Mar 24, 2008 | Fantom Vacums Lighting Canister Vacuum
Vacuums Logo
74 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
