Question about Apple MacBook Air with 13.3" Display
Switches itself off after 30 seconds
My Mac was running very slow (kept getting multi colour timer for everything) so I decided to switch it off then back on. During switch off it 'hung'. I pressed the Control-Alt-Del equiv. It switched off, but now when I try to switch it on I get the grey screeen, apple symbol, timer then after approx 30 seconds it just switches itself off. Have I killed it? Please help...
  • Apple Expert
  • 481 Answers
The MacBook Air is not known to be susceptible to the bad capacitor issue, which concerned capacitors that Apple used four and five years ago.
You are not seeing a kernel panic, because you have not reported the gray overlay screen with a message in multiple languages.
I would recommend against reloading your system or having your logic board replaced without attempting several much less invasive potential solutions.
The first potential solution I would pursue is to reset the power manager on your MacBook Air. From a powered-down state, connect the AC power cable, then while holding down (left) shift-control-option, press the power button once. Wait five seconds, then press the power button to start the computer.
If that doesn't fix the problem, try the following:
Disconnect all external peripherals. Make sure you are not running your computer on a soft surface (overheating).
If the sleep indicator light briefly illuminates just before the system shuts down, you will need to have a technician check the thermal sensor connection to the logic board.
Using the original system discs and an external USB optical drive, run the Apple System Hardware Diagnostic on your MacBook Air. If error codes are reported, take them in to a technician.
There are other tests that can be done and logs that can be checked by a technician. If your computer continues to give you this trouble despite trying the above steps, you might do best to bring it in.
Posted on Nov 18, 2009
    Champion:
  • 206 Answers
You haven't killed it, you have crashed your system. Go through the web, search for the reinstall codes for your system. The thing is that every MAC has it's own codes (based on the which system you used) that can reinstall your system, without loosing any of your data. During the new installation it asks you if you want to save all the data you had, and then you can start using your MacBook from the begining
Posted on Nov 17, 2009
  • Apple Master
  • 3,866 Answers
Okay this is indeed ar hard ware failure on this MAC the logic board will need to be replaced or repaired most causes of mac's frezing are bad capcitors on the logic boards if you can indentify and replace that you will have a working machine again trust me I worked on the Emac capacitor issues and I feel this is the same issue most where with the onboard video card making the system hacking its called a kernal panic and that is why you system is doing currently what I call a kernal panic you will need to replace the logic board at this point.
Thanks and please leave postive feedback and ratings for your free answer today.
Macbook pro slow since upgrading to mountain lion
Just go to apple store and let them reinstall everything for you. its free and hassle free.=) Warranty or without warranty.
May 02, 2014 | Computers & Internet
How do you fix GE dishwasher that stops as soon as you reach plate warmer cycle?
It's the timer. Assuming you checked everything properly then it's your time. But check all connections disconnect power for 30 seconds then try running it. But the only thing left is the timer. I hope this helps the picture is of a different timer then you have but its a timer none the less
Mar 24, 2014 | Dishwashers
Trouble wiring timer
If these lights are on 2 way switch you are going to have to figure out which wire runs to your outside lights. If you aren't familiar with 2 way switches here's a link to a site that will help:
http://2wayswitch.com/2-way-switch-wiring-diagram/
If you look at the diagrams on this site, you will see that ONE of the switches has a wire that runs to the light. I don't know which switch this is in your case.
You also need to decide if you want to be able to override the timer with the switches. Also, please confirm that the switches are 2 way (meaning that you can always turn on the lights from either switch). Sorry I couldn't explain more but I need to know whether the timer has complete control over the lights or if you want the switches to override the timer.
It might be a little trickier than you might think. Good luck and be careful.
Mar 13, 2010 | Woods Industries 59377 Indoor Digital...
Electric washing machine
to make sure of the time that the device will switch on/off or cycle
in use the armature rotates approximately 1 rev/hour, slowed down by a multi stage gearbox, & multiplied in force by the same factor
the switches are 1/2 ounce pressure,
there is no difficulty with timer motor being able to move the switches
do not file them 'smooth' it causes difficulty with program shifts
(have done it, once, only once, never again)
Sep 21, 2008 | Kenmore 24032\24036 Top Load Washer
P-tac unit shutting off
Start the unit and check unit data ( suction pressure, discharge pressure, current reading voltage reading, check if no icing at compressor suction pipe and evaporator coil) if everything is normal. check the fallowing.
- check for out of range pressure switches. By pass pressure switches and start the unit if the unit continue to run check which of the pressure switch is open while the unit is running.
- check for defective timer and magnetic contactor or control rely.
- if the unit installed with freeze up sensor then check it also.
- Or the control by itself.
Nov 09, 2007 | Kenwood KW85 Air Conditioner
Kvm switch won't stay on second computer, switches back
You might try disabling any power saving schemes in use on either computer. The KVM (I believe) gets its power through the ports and one computer may be shutting down power.
Aug 31, 2007 | Belkin F1DL102P 2-port KVM Switch
TV Akai CT29X4AV
Have tried checking if the Power Plug is fitting tightly in the Power socket? Could be that it is loose?
May 27, 2007 | Akai CTS2550 25" TV
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Apple MacBook Air with 13.3" Display Logo
238 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
