Question about Acer Aspire™ T180 PC Desktop
Acer t180 bios set up
Hi all
  1. i got a new acert180 ua381b i wanted to memory upgrade it. when i verified the mother board specs found 800 mhz was ok i got 2 ddr pc2 6400 800 mhz wich is the standard, but i got hit. The machine had installed ddr2 pc2 5300 (2 512 modules) so no big deal i instaled in the new modules to the machine, auto detected new hardware now i don t have a way to see if the bios has the correc speed for the memory ,cant reach that in the bios.
  2. bye the way ddr2 pc2 5300 are uninstalled .. so there is no conflic in speeds
  3. machine hang out some time
  4. bios ifo BIOS Version/Date Phoenix Technologies, LTD R01-B3, 2/7/2007
  5. SMBIOS Version 2.3
    What can i do newbie tech..
  • Warriorking Jan 10, 2008
    Specifications
    Product
    Aspire T180
    Language
    English
    Model
    Aspire T180 Specifications
    Specifications
    Processor
    AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
    Cache
    depending on the CPU
    Memory
    256MB DDR2 533/667/800 SDRAM expandable to 4GB
    BIOS
    Flash BIOS
    Supported Protocols
    ACPI 2.0, APM 1.2, SMBIOS 2.3, WFM 2.0, ASD 1.03, PXE boot ROM, PCI 2.3, DMI 2.0, WOL, Bootable CD-ROM 1.0, USB 1.1~USB 2.0, E-IDE (up to PIO mode-4), ANSI ATA 3.0, ATAPI
    System Chipset
    nVidia MCP61S + MCP61P
    I/O Controller Hub
    ITE8726
    Expansion Slots
    1 PCI-Express x16 slot
    2 PCI v2.3 slots
    Audio
    Integrated nVidia MCP61 with AC97, ALC888 codec supporting 16 bit PCM format for 7.1 Channel High Definition Audio codecs with UAA (Universal Audio Architecture)
  • xbear0911 Aug 06, 2008
    I am looking to upgrade the processor of my acer T180 from AMD Athlon 64 to a AMD Athlon X2 5000+ or 5200+ Dual Cores to get better performance.
    Question: Do I need to update my Phoenix Tec ver R01-B3, 2/7/2007 Bios? .... and if I do, how do I perform the update?
    Thanks!
    noonan.a
  • 2,427 Answers
Hmm you might need to flash the bios or reset the bios follow these instructions.
TO RESET BIOS
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
THATS IT BIOS RESET
Posted on Jan 10, 2008
Option #2 worked for me yaaaa!!!!!! This board has been dormant for over a year and has come back to life. aswesome, cheers!
Posted on Sep 26, 2009
I want a dual core processor upgrade
You listed this under PC Laptop? It's a Desktop? Have you ever done a CPU upgrade? You are limited to what will work with your machine, Mobo and other components. Your Mobo is, of course, AMD compatible, so if you read the specs: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireX1200/AspireX1200sp2.shtml The AMD Athlon X2 dual-core is best option. Memory is a easy option to increase speed a bit. Remember, with a 32bit OS the most memory it can use is 3.80 GB's More or Less. With a 64bit OS use more. I have done many CPU upgrades, you may not get the Speed/ processing increase you expect. After all, the components work in conjunction with one another. Do your research on Socket type, Pins, Power requirments, etc., etc.Check, Verify, then re-Check and re-Verify. Use this little freeware program to assist you, it list Spec info in detail, SPECCY at: http://www.filehippo.com/download_speccy/.
Jan 12, 2013 | Acer Aspire Computers & Internet
Ast180-ua381b buy which replacement motherboard
If you want to rep[lace teh motherboard ..you have no limits ..basically the only thing that limit your choice ...are the devices from teh old board you planing to use on the new one ..
So ..if you are planing to use the CPU ..you have to get a board with the same socket..but I would not recommend it unless you have a fast cpu ..and you know it is working ..
So ..if you are not limited by the cpu socket ..the only thing to look is to have buses for your hard drive and disk drive ..(so if you have the hdd on sata ..you need at least one ide bus for the dvd drive ..and the most important to have slots for the memory you have ..If your ram memory is on ddr2 ..pay attention for the frequencies ..It may not support ddr2 on 800 if you get a board that only uses on 533 or 667 ..but will work the otehr way around..If you have ddr2 on 533 will work on a board that works with 6667 and 800 mhz ..
the rest is not that important and will work ...be sure you have at least a 300W power supply ..or even larger if you are planing on using a fast video card ..
..So ..like I said ..the CPU socket ..and the ram memory used are the only limits ..real ones..the others..are usually supported well on any board with same slots ..
Dec 31, 2011 | Acer ASPIRE T180-UA381B DESKTOP PC
I wanted to get my acer aspire T180-UA381B upgraded, and I know very little about computers, how much and what kind of ram should i put in to make it run fast
Based on your memory specs below the maximum RAM that you can install in your computer is 1GB
DDR2 SDRAM and you can get 1GB RAM for like $15 -$ 20. 1 GB DDR2 SDRAM is what you need to buy.
Your Memory Specs:
Installed Cache Memory: 256.0 KB
[close] Installed RAM: 512.0 MB RAM, or Random Access Memory, is the place in a computerwhere the operating system, application programs and data in current use arekept so that they can be quickly reached by the computer's processor. Theamount of RAM you have affects how quickly you will experience your computerworking.
[close] Installed Video Memory: 512.0 MB
[close] Max Supported RAM: 1.0 GB
[close] Number of Memory Slots: 4 x 240 Pin DIMMs
[close] RAM Technology: DDR2 SDRAM
Feb 11, 2011 | Acer ASPIRE T180-UA381B DESKTOP PC
What is the maximum Ram supported bu Intel 1.86
Your system has a maximum capacity of 2 GB of SDRAM - 266.0 MHz
Jan 05, 2010 | HP Pavilion dv1000 Notebook
No boot after putting 2 Gb additional in Mb
try to reset cmos after putting 2 -1 gb rams(pulout power cord,and change clear cmos jumper to clear for 10 secs,or just remove motherboard battery for 30 secs,post mb info if no luck with cmos clear
Jun 12, 2009 | Acer Aspire™ T180 PC Desktop
I have recently upgraded the ram and cpu in my acer t180 desktop. since then i have 2 problems firstly and this is the most serious problem when the pc is left idleing it freezes and i have no option but...
Ok first of all perform a Microsoft update, when its done i suggest you download a system cleaner, java and the latest Abobe flash player.
Get Ccleaner here, use the cleaner and the registry cleaner and back up to the registry and restart your PC >>>
http://www.filehippo.com/download_ccleaner/
Flash player here >>>
http://get.adobe.com/flashplayer/
java here >>>
http://www.java.com/en/download/index.jsp
remember to restart your PC after using Ccleaner.
post back if its still the same.
Good luck and thanks for using FixYa!!
Mar 15, 2009 | Acer Aspire T180 PC Desktop
Memory Upgrade
I believe the max you can go with per slot is 1gb.
This is copied from the Acer site:
Up to 4 GB of DDR2 533/667/800 MHz SDRAM
http://www.memoryx.net/acerxtd1024.html
Jan 31, 2009 | Acer Aspire™ T180 PC Desktop
ACER 180 (AMD 64 3800+) upgrade
any amd 64 will work. bios should be ok if you stay with just the amd 64 if this is a aspire t180 then you might want to go to a 64x2 which you will have to flash the bios. hope this helps
roduct
Aspire T180 Language
English Model
Aspire T180 Specifications Specifications
Processor
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Acer Aspire T-180 Memory Upgrade question
Hello, You might be able to add 2GB more. 1GB per slot. You need to get the model # off your motherboard and verify what the maximum amount of memory it will support. 1GB per slot would be 4GB total but some Operating systems will only support 3GB. So some might be wasted if that is the case. You would need to use the same memory type. So if existing is PC2-4300, use the same. Hope this helps.
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
3,473 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
