Question about Canon imageRUNNER 4570 Copier
The Film is curshed again & again
Sir,
I am Hemant Tailor from Udiapur city in Rajasthan.
I Purchase 4570 copier machine from ahemdabad. but problems in machine in the fixing unit.
The film is crushed again to agian.
Please give me solution of this problems.
Contact No. 9829925139
    Problem Solver:
  • 14 Answers
Frist you can remove your fixing unit then remove the flim,clean the filament,collers & change the film.
Posted on Nov 17, 2009
Canon ir 4570 paper jaming in heater section what can i do
check your outlet delivery guide or whether your fuser film rotation
Nov 05, 2014 | Canon ImageRunner 4570 | IR4570 |
E000001-0002 ir 4570
This is problem with the Fixing assembly, the sub-thermistor has detected a temp of over 295 degrees C . First reset the copier by getting into service mode. Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, ERR, Then Ok. Power down copier then wait a few seconds then power up again. If the error continues or reappears again you may have to replace the fixing film assembly in the fuser. Good Luck.
Jun 21, 2011 | Office Equipment & Supplies
E000-001-002 please help solution regarding this code
This a fixing assembly tempature error. First reset the copier by getting into service mode. Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, ERR, Then Ok. Power down copier then wait a few seconds then power up again. If the error continues then the fixing film will have to be replaced.
Jun 21, 2011 | Canon imageRUNNER 4570 Copier
I change fixing film still problem e000000-0001 what can I do? canon Ir 4570
you may have forgotten to tight connector screw of heating element.check it if it is ok then check the continuity of heater element with multimeter, if it is not showing continuity replace it.
Mar 02, 2011 | Canon imageRUNNER 4570 Copier
From where can i get genuine canon ir 4570 fuser film
Hello
The genuine parts is available to authorized Cannon Service Center or you can buy online from here http://www.precisionroller.com/fixing-film-assemblies---units-for-canon-imagerunner-4570/details_35006.html
Hope this helps
Jan 26, 2011 | Office Equipment & Supplies
My copier machine ir 4570 always damaged film when it out of 30000 -40000 copies i were explaned the copier expert he called me to bring orignal greec but not avalibal in nepal. what can i do ?
Please explain more about what you are tring to do? Are you asking why is the fuser film only lasting 30k to 40k copies? If so, it depends on what kind of paper you run in the copier. Also, it is not designed to last for ever. I think I've answered your question?
Oct 09, 2010 | Canon imageRUNNER 4570 Copier
Error E000000-0001
You have to reset the error in service mode . To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
Thank you!
May 18, 2010 | Canon imageRUNNER 4570 Copier
Peaper crushing and jaming
try to change paper to 80 gms,is it our problem solve?
Feb 15, 2010 | Canon imageRUNNER 4570 Copier
Canon 4570 E00000
You need to reset the code by clearing the error memory phone me on 07764303923 i am in england and will tell you how to do this
May 06, 2008 | Canon imageRUNNER 4570 Copier
Canon imageRUNNER 4570 Copier Logo
93 people viewed this question
old marine
old marine
