Question about Packard Bell 1580509280 Network Adapter
Which 1 to use
Iv recently brought a pb computer it only had land line connection so i brought a network adapter so i could use it with my cable ive noticed another place were my cable lead fits is it useable thanks
  • minivminx Jan 10, 2008
    thank u its got to be a RJ45 as my ethernet cable fits il see if the internet works with it thanks again
    Scholar:
  • 98 Answers
If it is a RJ-45 connector yes you can use it, The landline uses a RJ11. If the cale fits in the connector then it is a RJ45 connector and you can use this connection. If it works with your internet connection take the netwotk card you bought back. Hope this helps.
Posted on Jan 10, 2008
6ya staff
SOURCE:
Emachine wifi
Until recently the old computers could only be wired to the Internet.
Wires are not only messy but also limit the placement of your computer in the house.
But now there is a way of connecting your old computers (even Pentium II) to a wireless network, just like any other brand new devise with a built in Wi-Fi.
Remove all the old Internet connections from your computer, including the telephone line and cables.
Before inserting the Wireless USB adapter in to the USB port insert the CD that came with it.
Do not insert the adapter first.
Follow the instructions on the screen after the CD is installed.
Now insert the Wireless USB adapter into any of the available USB ports.
A window will pop up on the screen and will search for the available network connections.
If there are many available (sometimes your neighbor's) select your connection and click connect.
Enter the network key, if required.
The network key can be obtained from your main hub computer that is connected to your wireless router.
Open your network advisor on your hub computer and click on the tab 'Actions' click the link that says 'Add more computers' and follow the instructions on the screen.
At the end it will give you a 16 digit number that you will have to write down.
This is your network key that you will need to enter in the computer that you are adding to the wireless network.
Jun 25, 2013 | Computers & Internet
My wireless USB adapter is not getting connected to the network, what do I do
prior computers have builtin network adapters that functioned as cable connection either dial up phone lin or ethernet cable connections. Computer of the recent generation have wireless adaptors that derive connective within radius of modems also known as wifi. Observe the computers made models as reference to ascertain whether requires cable connection to network or capable of wireless reception. Computers that are provided network structures by an expert would recognise either as requiring cable or wireless. Depending on the coniditon of computer structures requesting to establish a network structure is acheivable. Refer with a computer networkin technician that would evaluate the devices at the location to ascertain the requisite structures to establish networking telecommunications. For example, refering with an expert ascertains that the computer requires modems to capture the signals or modern devices require a miniature adaptor device attacked to the computer.
Feb 19, 2011 | Linksys Computers & Internet
Ive recently changed the password on my wireless network and now my printer keeps flashing orange which means it wont connect to the wireless. From reading a similar post i saw you recommeded to reset the...
To reset the printer's wireless network adapter:
  1. Press Setup(wrench icon).
  2. Go to Network Setup, press OK.
  3. Go to Reset Network Adapter, press OK.
WiFi light will temporarily turn off then will turn on solid orange. Now, run the printer's Wireless Setup Utility on your computer to configure the printer with the new wireless settings. You will need the USB cable temporarily to successfully configure the printer. Thank you for choosing Lexmark.
Sep 10, 2010 | Lexmark X4650 InkJet Printer
I want to install network adapter
hi! there,internet connection using your lan card or built lan adapter on *********** board if your network to public server e,g In your town telephone w/internet using usb port or broadband wire less no matter where,as long you subcribed there service ready for internet connection,i thing this kind of service once you purchsed and subcribed they are responsible to connect to your computer,but somehow this is your request,external land card when you buy it is already provided w/ cd driver installer and built land adapter on mother board driver was on mother board cd installer.if in the absence of installer you can down load to web site there free and there is you have to purchase take name of mother board you can see on inside pc and on *********** type this website just put .com at end.and select what ever you want.same with external lancard,insert your externai landcard on mother board on white slot.but you have to remove cover for land card back of cpu.check the driver of land card in device maneger.
to open device maneger ,control panel,system properties.connect your usb cable both on land card and modem,wait a minute until installation appear in your screen follow what wiazad
Apr 02, 2009 | Dell OptiPlex GX260 PC Desktop
Good Signal,Good Mbps, Slow Internet Connection?
1. Try to use a different wireless adapter on all available USB ports, if the problem remains then
2. turn off your PC unplug the power cord from the power socket, short the two legs of the power cable then leave it for 5min, then plug it into the power socket again and turn on the PC.
if this didnt work then you have a hardware problem with the USB ports.
let me know how it works out.
Nov 30, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Good Signal, Good Speed, Slow Internet?
Try plugging the computer straight to the router.If all is well the adapter may need a firmware or driver update.Or your adapter may be experiencing some type of heat problem or failingRICHARDM69
Nov 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys WUSB54GC 802.11g/b can find access point but not internet
do one thing remove the prefered networks from the list of prefered network sand after that connect to the network
u will be able to go online after that ....
Nov 15, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
I had a home network set up between 2 Dell Dimensions computers Computer 1.) which as the broadband modem and Netgear Router on it "this computer is a windows xp". Computer 2.) with the Belkin...
Assuming you can't get it to run from the desktop icon, as long as the driver is installed which it should be, you don't need Belkin software to run your connection.
the easiest way in Vista is to go to control panel>network and sharing centre and see if network discovery is ticked green.
If not on top left of window is connect to a network, then see if your wireless connection is listed, if so click connect, if not at the bottom of the window, click set up a connection or network and follow the wizard.
Sep 10, 2008 | Belkin Computers & Internet
Recently had a Belkin Wireless system install at home that keeps dropping the line in my room so want to use ASDL cable to connect to my computer what is the best modem card to get to do this
Your ISP should provide you with an external modem that would be connected to your phone line, then you would connect the modem to one of the wired connections on the back of the router, or directly to the back of your computer.
However, if you insist on an internal modem, I would suggest either a U.S. Robotics or Encore brand.
Apr 20, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Help!
go to start>run, then type ipconfig /flushdns and press enter. If no luck then go to control panel>network connections, then click on your network adapter sometimes called local area connection unless it's wireless and right click>properties, click on the tcp/ip line and click properties and check the obtain ip address is ticked and select ok. Try again and if that doesnt work go back to network connections, right click on your network connection and select uninstal, then restart the notebook and it will reinstall itself for you to try again.
Aug 07, 2007 | IBM ThinkPad A20 2628 Notebook
Packard Bell 1580509280 Network Adapter Logo
95 people viewed this question
Top Packard Bell Computers & Internet Experts
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
