Question about JVC Televison & Video
I have a JVC AV28WR4EKS 28" TV. The picture is very dark although I have adjusted the brightness and contrast settings to maximum. How can I adjust it ?
techman
  • 3130 Answers
SOURCE: dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Posted on Mar 20, 2007
TVtechmaniac
  • 140 Answers
SOURCE: The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Posted on Aug 30, 2007
  • 93 Answers
SOURCE: Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Posted on Oct 19, 2007
fanicate
  • 60 Answers
SOURCE: How do I fix contrast and brightness on 36" toshiba tv?
you can bring more brightness by removing cover on your tv and then you will see ther 2 button ther in back of your tv one is FoCUs and other is G2 rotate the G2 button till you see more brightness on your screen put the cover back and that is if you dont know to do that go to one authorised service
Posted on Dec 10, 2008
  • 700 Answers
SOURCE: I have a JVC 27'' AV-27530 TV that the picture is very dark
An aging FBT if it still can be adjust using screen adjustment on FBT that will be a small tweak.
But if you are inexperienced with this, asked someone who knows how to do it to fix it for you.
Posted on Apr 08, 2009
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
Picture adjust
Put it in the custom mode.Put the contrast to the max.Everythings else in half in the middle.
Colors maybe less.Now u have the desire adjustment?
Aug 19, 2009 | Televison & Video
JVC TV THE PICTURE IS DARK EVERYTHING ELSE WORKS GREAT
there so many things which can cause that to happen an these are thwe following,
i a tube has to be tested
ii a line transformer
iii vedio amplifier
this tests can be done in w/shop where other tvs are of the same.
Mar 27, 2009 | Televison & Video
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
Oct 19, 2008 | JVC AV-27530 27" TV
Darks too dark
Oct 15, 2007 | Toshiba 32AF43 32" TV
Aug 30, 2007 | Televison & Video
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Televison & Video Logo
99 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
