Question about Bosch Dishwashers
Wash programs do not complete, seems to drain continually after washing completes
There is a leak from somewhwre so water collect inside tray activate safety switch.
Posted on Nov 17, 2009
Water drains but spin will not spin
This can be due to problems in the program cycle as it seems to over ride the program.
This can also be due to fault in the program controller unit , please try this with a separate program, also clean the drain , check the connections to the controller, check for fault in the level sensor.
Jan 01, 2013 | Washing Machines
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
I have a Whirlpool 1200 Spin AWM 1201 Washing Machine. There is a funny smell coming from it like suage. Also sometimes there is water on the floor after its use. We have checked the pipe going outside and...
The smell is a build up of bacteria which can be flushed out to help/ The leakage could be a few things a hose , pump or door boot seal ,a small rip in this you need to check further....
Feb 22, 2011 | Whirlpool Washing Machines
Machine washes and doesnt complete its programme
You need to know if there is a delay in the water inlet valve that slows the program and finally result in the poor completion.
So while the program is initiated, observe the program to move along, check the inlet valve voltage, check the flow, once the water level is up , the motor must activate and turn. After the set time the wash stops and the water drains, check the drain valve/pump- if not clean and reset.
If there is a shut down during these times then the program controller unit is also a suspect.
Feb 15, 2011 | Hotpoint BWM12 Front Load Washer
Water doesn't seem to completely drain out at the end of wash. I am finding water standing in washer after clothes are removed.
I would look at the water inlet valve. Sometimes if one of the solenoids is defective it can let some water leak back into the tub if it isn't closing completely. It's not that the water isn't draining completely, it's that additional water is being allowed in. This is a common reason for water being found in the tub after spinning. The solenoids can be checked for continuity using a multimeter. No continuity would indicate a faulty solenoid. See the photo for reference. Hope this helped and best wishes.
Aug 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Programs do not complete!
check if it heating - no heat will prevent completion of program
Apr 10, 2007 | Zanussi ZWD1680W Front Load Washer / Dryer
Dishwashers Logo
52 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
