I have a Dell inspiron 910, will not boot up says operating system not found, when i run dell utiliities disk it comes up with error code 0f00:0244 msg disk_0-block 11599896 cant read replace disk or remove write protection, i have tried to re install my os but when i come to delete the previous partition it tells me cant delete this partition, can anyone help me with this problem. Regards Kev
  • 32,281 Answers
You have a faulty hard disk. Replace it with a new one and then install Windows on the new hard disk.
Posted on Nov 17, 2009
    President:
  • 2,017 Answers
1st you try with the command chkdsk /r/f. but i think the detail which you mention it shows there is physical damage in the hard disk and you drive is not accessible i advise you to install the new hard drive .becoause this drive will give you problem in future. So pls go for new hard disk.
Testimonial: "Hi Everyone thanks for the help, i did try the chkdsk/r/f. no access to SSD,purchased new SSD installed no problems thank you for all your help."
    Champion:
  • 206 Answers
You have dead blocks on your primary partition, and that is what stops you from deleting it. Don't try to delete it, just when asked to chose the partition, choose it, afterwords you'll be asked how to format it (quick or normal). If it doesn't let you format the drive like this, it is most likely that your HDD has just too many bad sectors, and that you can't recover it
4 Suggested Answers
  • 7 Answers
SOURCE: Communication Error DELL 926 AIO Printer
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Posted on Dec 24, 2008
Found on another forum. For 926 this worked great.
1. Go to Control Panel - Printers : Delete 926 printer
2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
4. Now restart your computer
5. Reinstall 926 Software.
This worked terrific for me.
Posted on Feb 05, 2009
SOURCE: I have DELL color laser printer 2130cn error msg load SSF ??
Its not a printer problem more of the paper source of that document is selected as SSF. So in most programs go FILE>PAGE SETUP. Select the paper tab and make sure the correct tray settings is selected. I.E "Default tray" instead of "SSF". cLICK "Default" at the bottom to make this the standard document settings and the problem shouldn't crop up again.
Posted on Oct 20, 2009
What's wrong with the hard drive?
Sounds like the HDD has either firmware issues or just faulty.
May 09, 2016 | Dell Inspiron Mini 9 Laptop
Hello,,, I got a Dell Inspiron 910 Mini Laptop. As I boot it up there is a stop message and a driver comes up. And then NO OPERATING SYSTEM FOUND. What must I do? Help me Please...
would indicate that the operating system is not detected. try to restore or reinstall your OS, if this does not work, try to remove and reconnect the hard drive of the system which I believe is an SSD type. You can also try to run diagnostics by trying FN power button to turn it on or tap F12 when system is restarting and select Diagnostics from the One Time Boot Menu. It is possible that the SSD drive needs to be replaced
Sep 16, 2010 | Dell Inspiron 9100 Notebook
My dell inspiron will not boot it says no bootable device found
Hi, try pressing the ESC key during bootup, this will allow you to boot in safe mode, from where you can reset your operating system to a time before the problem started.
If this dosn't help come back to me for help on re installing operating system.
Aug 01, 2010 | Dell Inspiron 1525 Laptop
Error Code 0146
Found in Dell solutions:
http://en.community.dell.com/forums/p/19314740/19628095.aspx?c=us&l=en&cs=&s=gen
Apr 04, 2010 | Dell Inspiron 1526 Laptop
Dell inspiron 910 operating system not found
Windows seems to be corrupt - vital windows files missing. Load the Operating System CD and see if u can run the system file checker to replace files that are missing.... OR, save data externally and restore the system.
Mar 13, 2010 | Microsoft Windows XP Home Edition
Dell mini inspiron 9 - operating system not found
On my Dell Insprion Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Oct 14, 2009 | Dell Inspiron Mini 9 Notebook
My dell laptop gives me a error code of 0146 amd keeps rebooting
Error Code 0146 refers to failure to find or load NTLDR files, needed to run your operating system. Place your Restore disk in the DVD drive, power up the computer, hold down the F12 key till boot screen shows up. Boot from DVD and run Repair to restore these files.
Sep 25, 2009 | Dell Inspiron 1525 Notebook
2,183 people viewed this question
jasbo
jasbo
