Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Can't get lid back on Saniplus mascerating system.
Almost impossible to put lid back on with seal. I lubricated gasket with soapy water but can't get an edge started. What's the method/ step I'm missing?
  • Anonymous Mar 13, 2014
    leaking from top of lid where discharge elbow goes through lid on saniplus system
    Sergeant:
  • 399 Answers
Hi use grease on the seal it will hold it in position also before doing this soak your seal in very hot water it makes it a lot more plyable to fit
Posted on Nov 17, 2009
Testimonial: "Haven't tried it yet but it makes sense. Saniflo also suggested using C-clamps. I'll update after trying."
Installation of lid seal
Typically the lid seal has an opening all around the center and it must face up and fit inside the lid, once is fitted inside the lid cover, lubricate the bottom of the lid seal with soapy water and place it on top of the pump casing. Then apply pressure at the side tabs to snap the lid back in place, note that you may have to use a big C-Clamp to be able to put the lid back on.
May 21, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
I can't get the lid back on because of the seal. Can you help?
The lid seal has an opening all around the seal. Make sure the opening faces up inside the lid, there is a groove inside the lid where the lid seal sits in place. Once is placed correctly on the lid, lubricate the lid seal with soapy water and then place on top of the pump casing and just put pressure on the side tabs so it snaps in place. Note that sometimes is required to use a C-Clamp to put the lid back on.
Aug 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
When I flush my mascerating toilet, the tank behind the toilet floods over. How do I fix this?
I assume you are referring to the holding tank and not the pump case.
The bowl float system on the couple SaniPlus toilets I have seen are similar to standard toilets. This will be a plastic float that slides up and down the water inlet tube. It will be attached to a shut off lever at the top of the tube by a metal rod. The float and rod are attached to each other by a "V" shaped clip. To adjust the shut off level you need to slide this clip up/down the rod.
If you remove the top of the tank and flush you should be able to see this working when flushing. Try shutting off the water flow by moving the shut off lever by hand. Use the water shut off at the inlet line leading into the tank to start and stop the water before it over flows if the lever does not work.
If the lever does not stop the flow then you have a problem with the water inlet mechanism and it may need to be replaced.
If your inlet mechanism is different from what I described please respond back with the model number of your SaniPlus.
Hope this helps.
Jun 22, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
How can I minimise the smell of my macerator
Possible causes and solutions:
  1. Poor Ventilation, make sure macerator is properly vent. From top of lid there is a separate 1 1/2" ventilation pipe make sure it's installed and pipe/fittings are undamaged, fittings are all tight and secure. Vent is free of debris.
  2. Leaking Seals. Inspect lid Gasket for damage and deterioration, Replace with new gasket if damaged or deteriorated.
  3. Check all connection to ensure tightness, Lid tightly, Pan Gasket, hose/pipe fittings tight and secure.
I hope this helps in solving your problem, please rate the helpfulness of the answer. Good Luck and have a great week. Jeff
Mar 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Sanipro xr massirato the problem is the pump is not pumping on makes a stuck sound, how do we clear out the massrator?.
You must remove the lid to gain access to the blades. Make sure you unplug the unit first. When reinstalling the lid place a little soap water around the gasket to help with the seal. thanks for using FIXYA. Jeff
Mar 11, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
How do u open the pump to get in it
depending on how old it is....isolate power, remove discharge elbow, with flat head screwdriver GENTLY ease lid up and away from the securing lugs at each end. To refit... rubber seal fits to lid and using a rubber mallet gently hammer the lid back on to the tank.
Feb 24, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
How do I get the lid back on the toilet?
lightly grease the rubber seal first this will help you slide it into position thats the hard bit now you can fit the lid remenbering to tighten corner to corner so that you get an even pull down
Nov 17, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
I disconnected my system to tile the floor then reattached everything but there was a leak in the outflow line. I found the top was loose and when I opened it the gasket was laying inside. Does the gasket...
the grove in the gasket fits over the rib on the underside of the lid and stays in place.. the lid then pushes into place. If the gasket is dry it will not fit well. Use silicone grease to lubricate. if none soap may do the job
Oct 12, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Water leaking out of breather
I have a question, I have a saniplus no problems hooking it up filled the tank and then flushed it..On the discharge end I had a small about of water puddling up at the pressed in rubber fitting. Every clamp was tight not sure what the reason is any ideas. I thought about silcone around the rubbber seal between the lid.
Sep 08, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
864 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
