Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Canon IR220. When switch on power, thr front light illuminates for a spli second and then switches off. The copier is dead. Tried swapping components (power supply, main board) from a second working IR2200 copier with no result. What next????
  • 1,219 Answers
On some older models that would happend when you have fixing trouble. Check the fixing circuits, fixing unit,...
Posted on Jun 14, 2010
How do i bim and brighten dash light 2002 buick lesabre
bim or DIM ? the dimmer switch ! Interior Lamps
The interior lamps consists of two groups, lamps that can not be dimmed and lamps that can be dimmed. This first group consists of lamps that may not be dimmed. This includes those lamps that may be manually turned on by placing the interior lamp switch to the DOME position, or by opening a door or a compartment:
• Door courtesy lamps
• Footwell courtesy lamps
• Instrument panel (I/P) compartment lamp
• Overhead console courtesy lamps
• Reading courtesy lamps
• Rear compartment courtesy lamp
• Roof rail courtesy lamps
• Sunshade vanity mirror lamps
Interior Lamps Dimming
This group of interior lighting includes lamps which may be dimmed. This group uses a combination of class 2 controlled illumination and incandescent lamps:
• Air temperature switch
• Cigar lighter lamp
• Door switches
• Driver information center (DIC) switch
• Headlamp switch
• Head-up display (HUD) switch
• Heated seat switches
• HVAC control assembly
• Instrument panel cluster (IPC)
• Memory function switch
• Radio
• Steering wheel controls
• Window switches
For the interior lighting to be dimmed the following conditions must be met:
• A low light level has been detected by the dash integration module (DIM)
• Headlamp switch is placed in to the PARK or HEAD position
• Ignition switch is placed in the ON position
Then all class 2 displays and all incandescent back lighting will be illuminated to the level set by the instrument panel (I/P) dimmer switch. When the I/P dimmer switch is moved from MIN to MAX, all class 2 displays and all incandescent back lighting respond from minimum intensity to maximum brightness.
The DIM supplies battery positive voltage to the coil side of the PRK LP relay in the rear fuse block.
When the I/P dimmer switch is moved from MIN to MAX, then the instrument panel module (IPM), W/CJ2, or climate control panel (CCP), W/C67, applies a message to the class 2 communication circuit to the DIM. The DIM then applies a ground to the park lamp relay control circuit. This energizes the PRK LAMP relay and allows battery positive voltage to be applied through the DIMR fuse to the DIM. The DIM then illuminates the following incandescent lamps through the incandescent dimming output circuit:
• DIC Switch
• Headlamp switch
• HUD switch
• IPC
• Radio
The DIM also applies a message to the following class 2 controlled illumination components:
• Drivers door module (DDM)
• IPC
• Radio
The DDM will then send a message through the simple bus interface (SBI) to the RH front door module (RFDM). The door modules will then illuminate the following components through the incandescent dimming output circuit:
• Heated seat switches (W/KA1)
• Memory function switch (W/A45)
• Power door lock switches
• Power window switches
The ground for these components are provided from the DDM and RFDM.
The following components are grounded at G200:
• Headlamp switch
• IPC
• Radio
The following components are grounded at G201:
• DIC Switch
• HUD switch
Mar 13, 2017 | 2002 Buick LeSabre
Why aren't lights for center console on the shifter working?
Could have a wiring problem , a wiring pin backed out of a connector ! If you don't know about automotive electrical an wiring diagrams an electrical wiring trouble shooting I suggest you take it to a ASE certified repair shop .
Instrument Cluster and Panel Illumination The instrument cluster and panel illumination is used to provide backlighting to the instrument panel, switches, and control components when the headlamp switch is in either the PARKING LAMPS ON or HEADLAMPS ON position. The level of intensity is adjustable by pushing the instrument panel dimmer switch either up to increase intensity or down to decrease intensity.
The dimmable backlighting components are:
  • Instrument cluster
  • Hazard switch
  • Rear defroster switch
  • Message center switches
  • Parking aid switch (if equipped)
  • Transmission range selector
  • Fog lamp switch
The non-dimmable backlighting components are:
  • Driver front door lock and power window control switch
  • Passenger front door lock and power window control switch
  • Driver rear door power window control switch
  • Passenger rear door power window control switch
Principles of Operation
The instrument cluster sends a signal to the instrument panel dimmer switch. The instrument cluster provides a variable pulse width modulated (PWM) signal to the dimmable backlighting components in accordance with the position of the instrument panel dimmer switch.
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
    Visual Inspection Chart Mechanical Electrical
    • Instrument panel dimmer switch
    • Smart junction box (SJB) fuse(s):
      • 7 (10A)
      • 15 (30A)
    • Circuitry
    • Illumination bulbs
    • SJB
    1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
    1. NOTE: Make sure to use the latest scan tool release software.
      If the cause is not visually evident, connect the scan tool to the data link connector (DLC).
    1. NOTE: The vehicle communication module (VCM) LED prove-out confirms power and ground from the DLC are provided to the VCM.
      If the scan tool does not communicate with the VCM:
      • Check the VCM connection to the vehicle.
      • Check the scan tool connection to the VCM.
      • Refer to Section 418-00 , No Power To The Scan Tool, to diagnose no communication with the scan tool.
    1. If the scan tool does not communicate with the vehicle:
      • Verify the ignition key is in the ON position.
      • Verify the scan tool operation with a known good vehicle.
      • Refer to Section 418-00 to diagnose no response from the powertrain control module (PCM).
    1. Carry out the network test.
      • If the scan tool responds with no communication for one or more modules, refer to Section 418-00 .
      • If the network test passes, retrieve and record the continuous memory DTCs.
    1. Clear the continuous DTCs and carry out the self-test diagnostics for the instrument cluster.
    1. If the DTCs retrieved are related to the concern, go to the Instrument Cluster Diagnostic Trouble Code (DTC) Index. For all other DTCs, refer to Section 419-10 .
    1. If no DTCs related to the concern are retrieved, GO to Symptom Chart .
Symptom Chart Condition Possible Sources Action
  • One or more module-controlled illumination source(s) is inoperative
  • Circuitry
  • Inoperative illumination source component
  • Go To Pinpoint Test A .
A2 CHECK VOLTAGE TO THE INOPERATIVE ILLUMINATION SOURCE
  • Key in OFF position.
  • Disconnect: Inoperative Illumination Source Connector.
  • Key in ON position.
  • Place the headlamp switch in the PARKING LAMPS ON position.
  • Measure the voltage between the inoperative illumination source, harness side and ground according to the following table:
    Illumination Source Connector- Pin Circuit Rear window defrost switch C2340-3 19 (LB/RD) Hazard flasher switch C2039-8 19 (LB/RD) Parking aid disable switch C2339-3 19 (LB/RD) Message center INFO switch C269a-3 19 (LB/RD) Message center SET switch C269b-3 19 (LB/RD) Transmission range selector C2096-4 19 (LB/RD) Fog lamp switch C2341-3 19 (LB/RD)
  • Is the voltage greater than 10 volts?
Feb 02, 2016 | 2008 Mercury Mariner
How do I fix a Canon pixma ip6600D printer?
ALARM LIGHT which always glows - RAM error (logic board is dead)
Apr 02, 2015 | Canon Pixma iP6600D InkJet Photo Printer
I Only need to replace the power window switch display light
are you refering to thr illumination to the switch itself ?this is an integral part of a switch and cant usually be repaired , if the switch is operating window ok i'd leave as it is as a new switch will be quite expensive
Apr 03, 2014 | 2005 Chrysler PT Cruiser
Subaru outback wagon tail light not working off
There are several components of your 1997 Subaru Outback that can cause your tail lights to stop functioning correctly. To help pinpoint the cause of the problem, it would be very helpful to also check your front marker lights. If the marker lights are working, then we know that the problem is not the headlamp switch or the tail and illumination relay (located in the fuse and relay box).
The components to check are:
> Fuse #23 (20 Amp) in the Main Fuse Box.
> Fuse #5 (10 Amp) in the Fuse and Relay Box
> Tail And Illumination Relay
> Headlamp Switch
May 06, 2012 | 1997 Subaru Outback
2004 crown vic interior lights stay on
Don't think you have a door ajar switch problem , more then like the lighting control module is the culprit . Does the door ajar light on the instrument cluster stay lit ?
The interior lighting can be separated into two distinct modes of operation: the courtesy lighting and the demand lighting. The lighting control module (LCM) controls all of the interior lighting in the vehicle, as described in the following text.
The front dome lamps, rear reading lamps, and instrument panel courtesy lamps, can be illuminated either by opening any of the vehicle doors (courtesy lamp function) or by depressing the headlamp switch (demand lamp function).
When any door is open, the door ajar switch grounds an input to the LCM which then sends power to the courtesy lamps. The voltage sent to the courtesy lamps gradually increases from 0 volts to 12 volts within 500 ms (± 50 ms), to achieve the theater lighting effect. When the door(s) are closed the door ajar switch(es) break(s) the ground to the LCM input which then gradually reduces the power from 12 volts to 0 volts within 5 seconds. (± .5 second).
When the headlamp switch is depressed it grounds an input to the LCM which in turn sends 12 volts to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps. When the headlamp switch is depressed a second time, it breaks the ground to the LCM input which then ceases to send power to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps.
The battery saver will disrupt power to the courtesy lamps after 10 minutes, the demand lamps after 30 minutes, and the headlamps after 10 minutes. Turning the ignition switch to the RUN or ACC position will terminate the battery saver feature by disabling the interrupt timers and reinstate power to the lamps.
Do you know what DTC'S are ? diagnostic trouble codes !
LCM Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1322 Driver Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test F . B1442 Door Handle Switch Circuit Failure LCM Go To Pinpoint Test G . B1445 Door Handle Switch Circuit Short to Ground LCM Go To Pinpoint Test G . B1563 Door Ajar Circuit Failure LCM Go To Pinpoint Test C . B1566 Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test H . B1685 Lamp Dome Input Circuit Failure LCM Go To Pinpoint Test I . B1687 Lamp Dome Input Circuit Short to Battery LCM Go To Pinpoint Test I . - All Other DTCs LCM REFER to Section 419-10 .
PINPOINT TEST C: THE COURTESY LAMPS STAY ON CONTINUOUSLY CONDITIONS DETAILS/RESULTS/ACTIONS C1 CHECK THE SYSTEM OPERATION Open and close each door, making sure that each door is completely closed.
  • Are the courtesy lamps still illuminated after the 25 second time-out period?
Yes GO to C2 .
No The system is operating correctly. C2 TEST DOME LAMP SWITCH Depress the dome lamp switch.
  • Are the courtesy lamps still illuminated?
Yes DEPRESS the dome lamp switch a second time. GO to C3 .
No The system is operating correctly. C3 CHECK THE LIGHTING CONTROL MODULE
LCM C2145a
Yes REPAIR circuit 53 (BK/LB). REPEAT the self-test. CLEAR the DTCs.
No INSTALL a new LCM. REFER to Section 419-10 . REPEAT the self-test. CLEAR the DTCs.
Apr 16, 2017 | 2004 Ford Crown Victoria
Wrt54g diag light stays on and unit wont start working.
It is probably dead, but there are a couple of things you can try:
1] Power the router and hold the RESET button for 30 seconds, then remove the power and try again.
2] Visit this site (it has very clear instructions on how to physically restore the firmware.... http://www.freewebs.com/wrt54grevival/wrt54grevial.htm.html#beginner
Mar 13, 2009 | Linksys Wireless-G WRT54G Router
Canon np6030 copier
Does the machine start and switch itself off? Some errors cause this to occur to prevent further damage. Try switching it on with the front door open, this will prevent the fixing heater circuitry from initialising. You will then need to find the error code. The ones that cause it to switch off never appear on screen, only viewable thru service mode. Push a straightened paper-clip into the hole below the right hand meter inside the front of the machine, press << and >> to get to *1* DISPLAY, find ERROR and let me know. Hope this helps...
Aug 29, 2007 | Canon imageCLASS D761 Copier
Computers & Internet Logo
324 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
