Question about Lexmark X3480 All-In-One Printer
I am trying to print and it saying Cartridge Error, Error 1203. The cartridge is new so not sure what problem is
  • 4,041 Answers
Hello Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
My printer says cartridge error 1203
The 1203 cartridge error indicates either a communication problem between one of your cartridges and the printer or a short in one of the cartridges. Please follow the steps below to fix this problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power source to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 24, 2011 | Lexmark C533DN InkJet Printer
Hi my name is Hector,on my 2.5 inch display it say cartridge erro error #1203. I checked my users guide it dosnt say anything about error numbers.
Error 1203 is a very interesting error code. Here is what I found out about error 1203
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a problem and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
or try this other option:
Dell All-in-One Printer Cartridge Error 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape. I believe this will work on Lexmark printers.
Jan 06, 2010 | Dell 966 All-In-One InkJet Printer
I have a lexmark 5470 model and have a 1203 error.
or
Jul 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
The ink is printing out fine, but in cartridge warning window says they are empty, and then stopped printing saying to remove cartridges. Now printer has error of 1203 and won't work. It won't shut off,...
Try to remove the Ink Cartridge while printer is on then install it back after a minute. If you still getting the same error, possible the Ink Cartridge or Printer is faulty.
Jun 16, 2009 | Dell 924 All-in-One InkJet Printer
Error 1203
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
My printer says error 1203 catridge error...can you help me with this...I can not find my owners manual?
May 18, 2009 | Lexmark C533DN InkJet Printer
My printer dont want to print
Apr 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Finding error messages
Yes ok try and try.
or
Oct 08, 2008 | Dell 962 Photo All-In-One InkJet Printer
Error Message 1203??
These steps are for a Lexmark 4200, but I suspect they will work for your printer as well:
Cartridge Error: 1203
Your print cartridge has a short.
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, see More troubleshooting options, or replace your cartridges.
Source: http://www.lexmark.com/publications/pdfs/4200/eng/trouble.html
Aug 04, 2008 | Lexmark P4350 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark X3480 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
