Question about Maxtor Hard Drive
Unable to remove a hard drive
I have three seperate physical hard disks (c:, d: and f:), and windows xp is installed on c: and d: . when i boot up there is a screen asking me to choose which to boot from. I currently only use the one on the D drive. When i tried to physically remove the old C: drive from the computer, it would not boot. how do i fix this? I want my computer to have only the D and F drives.
    Problem Solver:
  • 13 Answers
Go into the set-up screen when you start up ( usually F8 or F11) before the windows logo appears and change your boot disk to D. Put C down as the very last option. Let me know if it works otherwise we can try something else
Posted on Nov 17, 2009
  • 32,281 Answers
The fix.
Move the D and F drives to the 1st disk controller and set the jumper on the first drive as Master and the other as Slave. This mean the old D drive will become the new C drive and the other drive will become the D drive.
Then run FDISK to partition the C drive as the primary DOS partition and the D drive as an extended DOS partition.
You will then need to install Windows on the new C drive with the device drivers and your programs etc.
  • 6,993 Answers
It is the way you partitioned the hard disk. Usually drive c: is the main drive that carries the windows (Xp), the d: & f: is just like a storage drive.
You need to reinstall the windows to re-partition your drive, but I am afraid your will loose all your files while partitioning.
But if you cannot do it, maybe you should give it to some one that can help you out.
Take care.
Have black screen. Error PXE E53 help
Check the physical connection for your hard drive. Sometimes they get loose. With the computer off and the battery removed, remove he hard drive and then replace it. Try to boot again.
If this fails to help, you may have a hard drive failure and need to replace it.
Feb 17, 2015 | Dell Computers & Internet
Why when i power up i get a ,, missing operating syst
This issue may occur if one or more of the following conditions are true:
  • The basic input/output system (BIOS) does not detect the hard disk.
  • The hard disk is damaged.
  • Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Check your BIOS or System Setup to see if it detects your hard disk drive.
If it does see your hard disk drive then follow these instructions to fix your master boot record (MBR)
windows XP XP Repair or Fix Master Boot Record Using Recovery Console
windows 7
Step one: Turn your computer on, booting from either your Windows 7 Installation DVD or Windows 7 System Recovery Disc. Remember, you may need to change the boot order inside your BIOS to have the your DVD drive boot first.
Step two: After the installation or recovery disc loads, if prompted, select your language settings and then continue. If you are using the installation DVD, when prompted by the following screen select Repair your computer.
Step three: The computer will take a moment now to scan itself for any Windows installations, after which you will likely be given a choice to select which installation you wish to repair. Select the appropriate Windows installation from the list and then continue. If by chance a problem is detected in one of your Windows installations at this initial stage, the system may also ask you if it can try to repair the problem automatically. It is up to you if you wish to let the system try to repair itself, but otherwise just select No. Step four: Once you have reached the System Recovery Options screen, as shown below, you will be faced with a list of choices that can aid you in repairing a damaged Windows 7operating systemicon1.png. If you wish to try the Startup Repair option first, it is often successful in automatically fixing many different start up issues, but in this article we will be using the Command Prompt option to resolve our problems manually. So, click Command Prompt to continue. Step five: Now sitting at the command prompt, enter the following command and then press enter:
bootrec.exe /FixMbr
While the above command does fix the MBR, and sometimes that is enough, there still might be an error with the system partition's boot sector and Boot Configuration Data (BCD). This might occur if you have tried to install another operating system alongside Windows 7, such as Windows XP. To write a new boot sector, try the following command: bootrec.exe /FixBoot
hope that helps
Aug 11, 2014 | Computers & Internet
Hard Disk drive do not appear in Disk Management & Device Manager
to fix the problem you must open your laptop check the hardware inside of your laptop hardisk thats the problem try to unplug cables of hardisk to plug again or replace new hardware hardisk if not solve the problem
Jun 18, 2010 | Lenovo 3000 Y410 Notebook
I have three seperate physical hard disks (c:, d: and f:), and windows xp is installed on c: and d: . when i boot up there is a screen asking me to choose which to boot from. I currently only use the one...
okay you will need to put a boot record on the other drives see the boot record is on C to boot from D and so forth so what you can do is this from command prompt type is "sys mbr", if that does not work you will need to remount the drive using a disk manger software like spinright, and so forth or simply creating a bootable partition under disk admiistration under the control panel.
I hope this does help.
Thanks for using fixya.com please do leave postive ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 17, 2009 | Dell Inspiron 3800 Celeron 500MHZ...
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
I cannot boot up my computer, it says a disk read error, press Ctrl+Alt+Del.
I hope it's simply a diskette in the diskette drive...
Otherwise, your hard drive may be bad.
If you moved the computer, the power or data cable may have come loose.
Open the case and check the cables. If you find an "extra" power cable in the case, swap that power cable with the one in the hard drive.
Sep 09, 2009 | Acer Computers & Internet
I am unable to fromat my IBM machine,its not
your bios maybe infected with a virus. first try removing the cmos battery in your ibm machine for 1 minute and put it back. next, make sure that the hard disk is working and is not corrupted try making a new partition in a different pc. Paste all the files from the windows xp installer to your newly made partition. next put the hard disk into your ibm pc. and wait till it boots into your hard drive and the setup will begin. make another partition for your windows xp system and install it to that directory. if you cannot boot into your hard disk, there may be a problem with your ide cables. try checking the cables from your ibm pc connected to your hard disk.pm me if you still have problems and questions.. heres my email jmizpahadonai777@gmail.com
Thank you
Aug 07, 2009 | Computers & Internet
NTLDR missing on changing harddisk connection
put the xp bootable disk in computer and boot from it, choose repair option. it will slove your problem.
Feb 24, 2009 | Microsoft Windows XP Professional With...
Formating hard disk
IF the old PC motherboard will recognize the drive while booting up, Windows 98 will also see the drive after boot-up. You may have to reformat the drive into smaller partitions.
All you have to do is physically install the drive in your old computer and attempt to boot. After the computer boots up, if the drive does not show up shut down and put the drive back in your old computer. Use the manufacturer's partitioning software available on their website to change the drive from one 250 Gb partitions to five 50 Gb partitions.
Feb 15, 2009 | LaCie (300728U) 250 GB Hard Drive
Do i need to change my harddisk?
It sounds like UBUNTU formated your hard drive where xp does not reconized the drive. When you go into BIOS setting, do you see your hard listed? If so, you should be able to put a clean install of XP to the drive. When you start the install, you must select REFORMAT drive and install XP. If this still fails, you may need to fdisk your drive first using DOS command and reinstall XP. Let us know if you incounter any more problems after doing this. Good Luck.
Feb 08, 2009 | HP Pavilion dv6000z Notebook
Maxtor Hard Drive Logo
78 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
