Question about Dell Inspiron 3800 Celeron 500MHZ Processor (CPU) - 569KW
I have three seperate physical hard disks (c:, d: and f:), and windows xp is installed on c: and d: . when i boot up there is a screen asking me to choose which to boot from. I currently only use the one on the D drive. When i tried to physically remove the old C: drive from the computer, it would not boot. how do i fix this? I want my computer to have only the D and F drives.
  • 2,418 Answers
Depends on how your comp. is set up. You will need to make sure your D Hard drive is set for master not slave, remove the C drive and going into the BIOS make sure the drive is set up prop. there, and then try a reboot with the D drive now as the C drive. If changing the Master/slave sw on the drive does not work. Leave the system as is set up now and download a program called EasyBCD by NeroSmart set this program to your boot preference and then you can remove the C drive. Using the new boot loader to boot into the D drive.
Posted on Nov 17, 2009
    Champion:
  • 206 Answers
Try by removing the C HDD from the BOOT OPTIONS in BIOS settings. It is possible that even after you take it out it asks for it to boot, so you first must shut it down in BIOS, and then try to boot from the D
  • Dell Master
  • 3,866 Answers
Okay you will need to put a boot record on the other drives see the boot record is on C to boot from D and so forth so what you can do is this from command prompt type is "sys mbr", if that does not work you will need to remount the drive using a disk manger software like spinright, and so forth or simply creating a bootable partition under disk admiistration under the control panel.
I hope this does help.
Thanks for using fixya.com please do leave postive ratings for your free answer today.
Have black screen. Error PXE E53 help
Check the physical connection for your hard drive. Sometimes they get loose. With the computer off and the battery removed, remove he hard drive and then replace it. Try to boot again.
If this fails to help, you may have a hard drive failure and need to replace it.
Feb 17, 2015 | Dell Computers & Internet
Why when i power up i get a ,, missing operating syst
This issue may occur if one or more of the following conditions are true:
  • The basic input/output system (BIOS) does not detect the hard disk.
  • The hard disk is damaged.
  • Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Check your BIOS or System Setup to see if it detects your hard disk drive.
If it does see your hard disk drive then follow these instructions to fix your master boot record (MBR)
windows XP XP Repair or Fix Master Boot Record Using Recovery Console
windows 7
Step one: Turn your computer on, booting from either your Windows 7 Installation DVD or Windows 7 System Recovery Disc. Remember, you may need to change the boot order inside your BIOS to have the your DVD drive boot first.
Step two: After the installation or recovery disc loads, if prompted, select your language settings and then continue. If you are using the installation DVD, when prompted by the following screen select Repair your computer.
Step three: The computer will take a moment now to scan itself for any Windows installations, after which you will likely be given a choice to select which installation you wish to repair. Select the appropriate Windows installation from the list and then continue. If by chance a problem is detected in one of your Windows installations at this initial stage, the system may also ask you if it can try to repair the problem automatically. It is up to you if you wish to let the system try to repair itself, but otherwise just select No. Step four: Once you have reached the System Recovery Options screen, as shown below, you will be faced with a list of choices that can aid you in repairing a damaged Windows 7operating systemicon1.png. If you wish to try the Startup Repair option first, it is often successful in automatically fixing many different start up issues, but in this article we will be using the Command Prompt option to resolve our problems manually. So, click Command Prompt to continue. Step five: Now sitting at the command prompt, enter the following command and then press enter:
bootrec.exe /FixMbr
While the above command does fix the MBR, and sometimes that is enough, there still might be an error with the system partition's boot sector and Boot Configuration Data (BCD). This might occur if you have tried to install another operating system alongside Windows 7, such as Windows XP. To write a new boot sector, try the following command: bootrec.exe /FixBoot
hope that helps
Aug 11, 2014 | Computers & Internet
I had vista on my computer and XP on a different hard drive..... now when i boot my computer up it asks me what to boot with (even though Vista hard drive is no longer plugged in) how do i get it to just...
go to bios setup, press del at first screen and you will go to bios setup, search boot device and chose first boot device is hard drive that installed xp, and do not select the hard disk that vista is installed at second or third boot device
i hope this helpful
thank you for using fixya
Feb 16, 2011 | Microsoft Windows XP Professional SP2
Hi Iam vijay I HAVE A PROBLEM WITH MY COMPUTER My system was infected with virus so i had to format it. i inserted a hiren boot cd and formatted c drive then i restarted my system to boot from cd i got...
The Hiren CD is a tool and you correctly formatted your hard disk, but Hiren CD does not install Windows on your hard disk. You need the Windows installation CD and the Windows installation product code to install a fresh installation on your hard disk.
The Windows version that was installed on your computer and the installation product code is on a Windows label that should be attached to the back of your computer.
If you don't have a Windows installation CD then contact Compaq/HP for a copy.
Sep 21, 2010 | Compaq Presario 5000 PC Desktop
On turning on my computer I get the HP screen with three options at the bottom Boot menu Startup menu System recovery When choosing the boot menu or startup menu the computer fails to bring up these...
The hard disk inside the computer had failed and must be replaced.
Since your system had an recovery partition and not a separate recovery disk you must contact HP and order a separate recovery disk. If you have a friend with the exact model of c then you can use its disk, but only if its the EXACT same model.
 This is a very big problem - and at least a basic knowledge of hardware is required to replace the failed hard disk. And some software experience is also needed to reinstall.
Aug 10, 2010 | Computers & Internet
Unable to remove a hard drive
It is the way you partitioned the hard disk. Usually drive c: is the main drive that carries the windows (Xp), the d: & f: is just like a storage drive.
You need to reinstall the windows to re-partition your drive, but I am afraid your will loose all your files while partitioning.
But if you cannot do it, maybe you should give it to some one that can help you out.
Take care.
Nov 17, 2009 | Maxtor Hard Drive
NTLDR missing on changing harddisk connection
put the xp bootable disk in computer and boot from it, choose repair option. it will slove your problem.
Feb 24, 2009 | Microsoft Windows XP Professional With...
How to install windows xp
Enter BIOS Set CD rom drive to first bootInsert your CD reboot
folow the on screen instructions be patient, it may take up to an hour,  and then two houers to install drivers,
-> if you want me to find the drivers for you, plz state your computer name and model.
regards /Teis
Jan 11, 2009 | Microsoft Streets and Trips 2008 for PC
I put a used e210882 socket 478 motherboard into my computer. which is a emachine. when i start booting the computer ask me what file to download windows xp into. what file should i send it to.
It is probably asking you to insert an XP disk, as Windows XP will need to install the new drivers for your new motherboard.  It will also give you the option to select a folder (this is what you are seeing) already on your hard drive that would contain the proper drivers for that motherboard.  Chances are this folder does not contain the proper drivers.  You will need an XP disk to install these drivers.  Boot with the XP disk in, and chances are Windows will take care of everything else.  If you do not have the XP disk you used to originally install Windows on that machine, then you can use a seperate PC to get the drivers required.  You will need to visit the website of the manufacturer (I believe emachines is your new mobo?) and download the drivers.  Then save them to disk.  When booting into your new system, make sure this new disk (you made from other pc) is in the drive, and then select that drive when it asks you for the folder you are talking about.  This will then install the proper drivers and you will be up and running shortly.  Hope this helps :)
Dec 31, 2008 | Dell (E210882) Motherboard
Unable to install windows xp
> Make sure that hard disk is detecting in C-mos setup.
> If it detecting in C-mos setup than Make sure that all parttion will
be in NTFS or FAT not Ext2 or Ext3
> This problem is Directely Associated with your hard disk
Dec 03, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
99 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
