Question about NEC NP60 Projector
Suddenly stops showing the picture
NEC NP60 projector. Suddenly stops showing the picture on the screen. The light is still there- slight shadow of a frame, but can't see any written, etc. 1st time- later fine after restart., 2nd time came in middle when was working fine.
-using with MAC laptop
  • 2,236 Answers
Losing signal. go into the menu and reset the settings to factory default. check your cables, too.
Posted on Nov 17, 2009
  • NEC Master
  • 3,866 Answers
The cause is a sudden overheat but when restarted its fine then it goes again this intermittant issue is with the lamp beleave that or not i found replacing the lamp solved the issue perm.
Thanks and please leave postive feedback..
My NEC projector MT1065 display colors okie, but with black (or dark) image, the screen display a greenish wash in the center of screen. This happen just the same with new lamp. It appears as if the...
It sounds like the polarizer filters are starting to ware due to heat build up, if you remove the lid and the main booard, there is a white plastic mesh cover over the lcd panels, you can remove this and adjust the polarizers for the red, green and blue lcds to adjust the black level, there are 3 hex bolts holding a plastic frames which in turn hold the pre polarizer filters, buy slightly loosening the bolt you can slide the plastic frames left or right to adjust the levels, buy you should mark the position before you start. this may not solve the problem but may help to improve it, unfortunately these projectors require special software to make electrical adjustments which is hard to get hold of.
Aug 17, 2011 | NEC MultiSync MT1065 Multimedia Projector
Help statius orange light 6 times lamp error try again in a minute. Still not working???!!! Help
Is the lamp and cooling pump covers on properly. It is saying that there is a lamp failure. Do you hear the high voltage trying to start the lamp when it turns on
Jun 30, 2011 | NEC NP60 Projector
The picture is slitly green tinted on the screen ?
Apr 29, 2011 | NEC MultiSync MT1065 Multimedia Projector
A shadow appears on the rigth side of the frame when in wide screen.
if this is a DLP projector, the light tunnel needs to be adjusted or it if partially collasped.
May 19, 2010 | Office Equipment & Supplies
Slight shadow on right side of screen
this is image banding. the light tunnel needs to be adjusted, or replaced if it is collasped.
Apr 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
Red coured picture Nec MT850
I don't think it's globe related, I'd be getting a quote on the electronics.
Mar 23, 2009 | NEC MT850, MT1050, MT1055, MT1056...
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Infocus 70+
We have had similar issue w/ multiple LP70+ projectors. The units get to be 1-2 years old and suddenly the right vertical edge of the display is distorted. There is usually a shadowed vertical bar that clouds about 3-5% of the horizontal space from the right edge.
What's the cause?
Nov 13, 2007 | InFocus LP70+ Multimedia Projector
NEC NP60 Projector Logo
200 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
