Question about Canon FAX-L200 Plain Paper Laser
Paper jammed.visible when front opened.paper past roller about 5 cms. Will not pull through
  • 45 Answers
You have paaper in the fusing roller.
Pull out the cartridge and loose 2 screws to take off the plastic fusing protection.
Turn the whell, and the paper get off... i hope.
Else, take off the fuser and release the springs to take off the paper.
Posted on Nov 17, 2009
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
Tip
Paper Jam Error on HP Printer
Paper Jam is the most common issue in all the HP Printers ( Officjet, Photosmart, Deskjet Printers )
What Causes a Paper Jam ?
  • Paper thickness.
  • Room temperature OR due to Dust in atmosphere or the room.
  • Paper pulled out in a hurry and paper pieces stuck in Rollers or Carriage
  • Could be Hardware Failure
NEVER PULL THE PAPER STUCK IN THE PRINTER FROM FRONT SIDE OF THE PRINTER ( unless the paper is 3/4th visible in front view if you open the printer front panel door )
Follow the instructions below to resolve Paper Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges.
  5. Check for any paper pieces, if so, remove them.
  6. Take a lint free cloth. Little bit Damp ( use water )
  7. Clean the Rear rollers pushing it upwards and close the door.
  8. Close the front access door.
  9. Connect the power cord and power on the printer.
  10. It should be ready to print/copy/scan/fax.
To clean the duplexer ( 2 - sided printing device ) remove the duplexer and clean the rollers you find inside.
If the above steps do not solve your problem, you printer needs repair. Contact HP. ( 1-800-474-6836 )
If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer.
Find the Video below for paper jam cleaning
Regards,
Ron
Your rating will help us improve the service we provide
on May 20, 2011 | Office Equipment & Supplies
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
Paper jam
Have you tryed replacing replacing the pick up rollers? Also make sure that the paper guides are snug against the paper.
Jul 06, 2013 | Brother MFC-7820N Printer
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
I have a paper jam on my very old canon fax machine...Canon Super G3. The paper is held up in the rollers and has torn...how can I release the rollers so that I can get the torn piece of paper...
To remove the paper jam, follow the procedure---
1. Open the front cover.
2. Remove the cartridge.
3. Open the face up cover and push down the green paper release levers on both sides of the face up paper output.
4. Hold sides of the jammed paper and carefully move it inward then gently pull out.
5. Remove if any paper bits present near the rollers.
6. Don?t pull the paper upwards but straight between the rollers.
Please check page#62 for details in the manual---
Canon Super G3 Fax
Apr 01, 2011 | Canon Office Equipment & Supplies
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
Paper Jam
from fixya knowledge base I found this solution
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Let know if working and don't forget to rate solution
Jan 11, 2009 | Brother HL-2040 Laser Printer
Canon FAX-L200 Plain Paper Laser Logo
76 people viewed this question
old marine
old marine
