Question about Panasonic Toughbook W5 Notebook
I have got panasonic cf-w5 if connect to projector and press the function and f3 there is no display from projecor
5 Suggested Answers
  • 47 Answers
SOURCE: Function key problem with compaq nx6120
-Click on run from start menu
-Type gpedit.msc
-User Configuration
-Administrative templates\Windows Components\Windows Explorer
-Double click "Turn off Windows +X hotkeys"
- Try the different settings (i.e. not configured, disabled, etc) to see if any of these solve the problem
Posted on May 10, 2008
Combchris
  • 64 Answers
SOURCE: Setup problem OS For panasonic CF-F8
Try booting with a free iso cd for partioning like gparted or Linpart and see if it is seeing the driver if so you prob just need to install third part sata drivers! what os, XP you most all the time need the sata drivers to install!
Posted on Nov 17, 2009
  • 10406 Answers
SOURCE: I used the FN + Mute button on my panasonic cf-w5
Double-click the "volume control" icon, to open the "sound mixer" control. Move all the sliders to "maximum", and remove any "mute" check-boxes.
Do you have a "FN + something" key to increase the volume?
Posted on Jan 07, 2010
bahratt
  • 561 Answers
SOURCE: I have 5 Dell 4310 WX projecors and I would like
I believe the Dell logo is hard-coded for the Startup, but you can change the Wallpaper form the Dell logo, to an image of your choice:
From the Setup Menu, or Others Menu, you can go into:
SCREEN SETTINGS—Select and press checkmark to activate screen settings. The screen
settings menu consists of the following options:
CAPTURE SCREEN—Select and press checkmark to capture the screen display, the following message appears on the screen.
NOTE: To capture a full image, ensure the input signal that is connected to the projector is 1280 x 800 resolution.
SCREEN—Select Dell to use the Dell logo as wallpaper. Select Captured to set the captured image as wallpaper.
RESET—Select and press to delete the captured picture and set back to the default setting.
More information available on the Manual here: http://support.dell.com/support/edocs/acc/4310WX/en/ug/pdf/4310WX_en.pdf
Posted on Jan 14, 2010
CF-W5 support for win 7?
Add RAM to at least 2 GB. 32 bit only.
Mar 29, 2014 | Intel Panasonic Toughbook CF-W5...
Tip
How to connect a laptop to a projector or external display
1)Plug in either the vga or dvi into both the projector and the laptop.
2)Plug in the power cord to the projector,then turn the projector on.
3)Once it has past its warm-up period,find the function key on your laptop.(Fn)
4)Along the F1,F2,F3 ect keys,press find the one with the picture of the display.
5)When you have found it,hold down Fn and press the display key down until it clones the laptop and projector.
on May 08, 2010 | Computers & Internet
Cant get it to work with laptop
power ON your projector and laptop
connect your laptop and projector with VGA cable and press
if your laptop PANASONIC or NEC (Fn+F3)
ACER, HP,SHARP,TOSHIBA (Fn+F5)
LENOVO, SONY (Fn+F7)
DELL, EPSON (Fn+F8)
FUJITSU (Fn+F10)
APPLE (F7)
If problem exist remove the VGA driver in your laptop and reinstall the correct driver not a standard display driver
Feb 09, 2011 | Panasonic PT L720U Multimedia Projector
Connection with laptop
Jul 02, 2010 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
ViewSonic PJ402D Projector does says searching for source, what does this mean? Laptop does not even notice that projector is connected to it as well.
you need to hold function down and press something like F1 F2 F3 F4 maybe twice to clone the screen display and make sure your projector is on vga and there is a secure connection between your laptop and your projector.
Jan 21, 2010 | ViewSonic PJ402D DLP Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
How to remove the display screen on a Panasonic cf-w5
I think you are suggesting changing background.Try this right click on your desktop,go to properties -click on it.It will take you to display properties,click on desktop select one of them and it will change.You may have to use the position stretch settings.Have fun,hope this is what your looking for,if not re-clarify the question.Thanks
Nov 10, 2009 | Panasonic Toughbook W5 PC Notebook
How to start my projector when connected to laptop? '
Turn on the projector and laptop and connect the vga cord to the projector and the laptop (making sure there is a secure connection so it is tight but not overtight) and hold down function when your operating system has started (windows only mac is different) and press either F1 F2 F3 F4 or which ever one has the picture,icon, of the laptop and the external display.
Jul 05, 2009 | Acer PH530 DLP Projector
Laptop issue
take out the battery out of the laptop then insert it again, then check,
Nov 05, 2008 | Panasonic Toughbook W5 Notebook
Connect my fujitsu siemens v3515 to a nobo s-17e projector
hi
hold down the blue lettered function key "fn" located 2nd left on bottom row....the press the function key F3 / F4 / F5 / F6 whichever one has the small icon that looks like a square/rectangle....it toggles in3 positions so if it dosent work first time press the same keys again...make sure your projector vga cable is connected to the correct vga input socket and select the input device on the projector to computer and not video
Nov 02, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Panasonic Toughbook W5 Notebook Logo
136 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
