Question about Nokia 6600
Charging time is so fast and so the use., i replaced new battery but still have the same problem
Light flashes fast on dewalt 0245
I believe the battery can no longer be charged.
Aug 31, 2014 | Drills
Battery for Hoover Linx will not charge. Charger blinks very fast.
Jan,
your battery is Shorted. it is time to buy a new vac or a replacement battery.
sorry that is such a short hand answer but that is what the charger is telling you.
Apr 22, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Dell c640 battery not charging
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 02, 2013 | Dell Latitude C640 Notebook
Uniden battery will not charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Feb 04, 2012 | Uniden Cordless Phone
Why its battery quickly drains
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 18, 2011 | Motorola Mobility C168 Cellular Phone
Ok every time my phone says low battery i go and charge it and like in about 45 min it will say charge complete so i grab and take it with me and go take like one 30 sec video it says low battery and i...
Your phone's battery has most likely reached the end of its life. Luckily, replacement batteries for the enV Touch are very inexpensive. Here's a battery that will work with your phone, for $8.00, and free shipping. I am not affiliated with the seller.
http://cgi.ebay.com/NEW-OEM-LG-LGLP-AHLM-EnV-TOUCH-VX11000-VX11k-BATTERY-/260745505647?pt=PDA_Accessories&hash=item3cb5a4ab6f
Mar 06, 2011 | LG enV Touch VX11000 Cell Phone
My nokia e61i charges for a small period of time and full battery
i think you have to replace the battery, and try to buy the original or genuine battery.
Apr 10, 2010 | Nokia E61i Cellular Phone
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Nokia 6600 Logo
19 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
