Question about Lexmark C510 Laser Printer
I have just replaced the colour cartrage's and still the pics are faint with white lines running down, please help
  • Official Brand Answer
  • 3,344 Answers
The problem could be that the Photodeveloper (green Belt) cartridge is either contaminated or damaged. Also try cleaning the brush at the top of the printer the one that cleans the Transfer belt (black Belt) that sometimes is not seated properly causing print quality problems.
Posted on Feb 01, 2010
    President:
  • Lexmark Master
  • 2,022 Answers
Make sure the the toner is not refilled and it is genuine try to change the print mode also give in best mode with higher resolution.
Posted on Nov 17, 2009
I only use black for letter printing, why do colour cartridges run out? Any why do I have to replace colour cartridges so I can print in black?
if you using only black, there is not need to replace colours, but you can not remove color cartrages from it, bacause it will not work without it.
Jun 03, 2011 | HP Color LaserJet 2600n Printer
Have just had printer cartrages refilled the black one is not working theres ink in it but am only getting very faint lines or nothing at all have allinged ok and cleaned cartrage
Unfortunately you may have to get a new cartridge as it sounds as this one is blocked.
I have had lots of problems with refills and try to stay away from them as the ink is not as good.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | HP DeskJet F380 All-In-One Printer
Very horizontal faint white lines running down the screen
hi,
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 key...you would get a Blue screen...check if the lines appear on this screen...if it appears...it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this screen....it is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
regards
Rocky
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
Faint & White Lines in Printer Head Alignment
This sounds like you are using either a refilled cartridge or an after market cartridge and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity, alignment utility. This should clear up the problem with the spotty printout.
Let me know if this solves your problem otherwise we can explore other solutiions.
Please rate this solution. Thanks.
Oct 06, 2009 | Canon BJ I6500 InkJet Printer
When using flash, pics ALL white!! overexposed!!
CCD FAILURE
CALL FUJI for FREE repairs u are eligible i got mine repaired free it is a known problem
Regards
Zohail
May 27, 2009 | Fuji FinePix S5000 Digital Camera
WONT COME OUT OF THE ALIGN CARTRAGE MODE
if the colour cartridge is empty or any of the three colour is not got printed on the allighnment page it will not comple allignment.replace the colour also or get you colour cartridge refilled.
May 06, 2009 | HP PSC 750 All-In-One InkJet Printer
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
When printing photos the images come out with faded colur and lines running throught them. I havre instar\alled new b/w and colour cartidges and still the same. Do I need to clean the 'heads' and if so...
you need to replace the printer head this is easy to do. first take out old ink cartrages. in the ink tray you will see a bulls eye. right above the bulls eye there is a small black tab. push tab to release printerhead.( call kodak at the customer service help line for new printer head they will ship 1 to 2 days) put new printhead in place and gently snap back into place replace with new ink cartrages.
Dec 24, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Then your point is i should buy a new set of color cartrages like the 3 colors before the printing should take place then how can i set my brothers printer mfc-240c into black cartrages only no need to buy...
First - read the manual as regards printing. I notice that you can print in Black and White but I cannot find anything to say that you only need the Black ink to do this (therefore I think that I am right in saying that you need the colour cartridges).
Question - Has it worked with only the black ink before now?
As a final solution - Contact Brother direct and check out their FAQ's and/or send them an email asking if you can run the printer with Black ink only installed (I suspect the answer will be no).
If the answer to the above questions comes back as "Yes you can use Black only" (they may tell you how to set this up in which case ignore my next comments), then please supply some more information as regards what happened immediately before it stopped printing. This will help to drill down to the problem.
May 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Lexmark C510 Laser Printer Logo
160 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
