Question about Toshiba TEC B-472 Thermal Label Printer
Reads rewind full all the time - Toshiba TEC B-472 Thermal Label Printer
After very close inspection a tiny piece of paper was found on the paper sensor causing the problem
john
Posted on Nov 19, 2009
Dear Sir We rely on an external contractor to backup our data. We need to retrieve the data and got this reply: " [...] I have just been down to the computer room and checked. Your data backup is...
these tape cartridges are very slow to read & write. if u r reading a set of data & need to go back for certain data u have to rewind & wait & watch until that data area arrives. it takes a lot of time. in order to save time u need optical disk drives & dvds to backup your data. u can also ask them to convert your tape cartridge data into optical disks.
Sep 13, 2011 | Smead Manufacturing Company Sony AIT5 Tape...
Our zebra zm400 is set to ****-off and everything seems fone for a while, then the backing take up roll (rewind) stops rewinding and the backing starts to hang down the front.
Go into the setup menu and check to see if it is currently in **** mode. Or print config to verify mode. If it changes from (****) to tear or rewind, etc. , then the driver is set wrong. Change the driver to **** mode.
Mar 19, 2011 | Zebra 300DPI W/FULL ROLL REWIND...
My film advance lever is stuck. pushed button under camera didn't work
You may have hit the end of the film. Rewind the film back to the spool until the very end gets back in the shell.
If you think you still have unexposed film do the following. Rewind about 1-2 full rotations. Cover the lens using the cap. We're doing this so that step 2.3 will not spoil your last pictures. Take 2 shots (with the lens cover). This time the button at the button should have popped out.
Feb 28, 2011 | Canon EOS-AE-1 35mm SLR Camera
How to use my ZEBRA 400 AS A REWINDER
Hit the Setup/Exit button to enter into the Menu area Hit the "+" button until you get to the output option (Rewind, peel, tear off, etc)
May 03, 2010 | Zebra Z4Mplus Printer: Peel with Full Roll...
Cord rewinder on a Electrolux model C102J vacum cleaner
Hi there Johnd, SmartAlec from Nelsonvacuums.com.au here. I fix vacuums full time for a living and the first time i had this problem with the australian version of this vacuum it tok me an hour to pull it apart and back together. now i have done a dozen or so it is about a 30minute operation. I dont know what you rate your technical skill level at but i give this machine a 8/10 for hardness. It is most likely that the cord has jumped off the reel and is wedged so it shouldn't require parts but it cant be done without nearly stripping it down. There is no reset or similar for the reel. My advice unless your very confident take it to a repairer. It would be 1/2 - 1hr of labour charge only i would think.
Hope this helps.
SmartAlec
Sep 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
''squeaks'' in reel to reel tape recorder
brakes need adjusting on the reel hubs
Apr 08, 2009 | Audio Players & Recorders
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
Nikon N50 SLR film
Hi: You may want to try changing the aperature setting,or removing the lens,then re-installing the lens. Good luck.
May 29, 2007 | Nikon N50 35mm SLR Camera
Toshiba TEC B-472 Thermal Label Printer Logo
75 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
