Question about HP Compaq Evo D310v PC Desktop
Why media accelator driver is not installed in my compuer.if i try to install over frequency as monitors resolution menu
    Champion:
  • 206 Answers
First lower the monitor resolution, and then try to load the drivers
Posted on Nov 19, 2009
My pc is hcl monitor working on windows 7 When I start my Pc the windows comes directly shows that Attention Not Support Out Of Range I.know pressing F8 Key but Nothing is happening help
Sounds like you set the refresh frequency/resolution of your monitor to a value not supported by the monitor. You need to restart in safe mode and reset the resolution.
Keep pressing F8 at boot until the menu appears. Try restoring to a previous point.
Or try
- Boot in Safe Mode with networking and Uninstall your current GPU Drivers.
- Download the current Drivers and install
- Restart the PC in the Low resolution Mode (F8 Safe Mode launch menu)
- Use your Graphics Card Control Panel and Force change your settings back to the original working ones.
Mar 21, 2016 | Computers & Internet
NEC NLT-26HDB3 monitor driver
Maybe the frequency of the monitor is not supported, try changing monitor frequency from 75Hz to 60Hz,
Screen Resolution > Advanced Settings > Monitor Tab > Screen Refresh Rate.
If this doesn't work try installing new drivers,
www.nec.com
Nov 05, 2013 | Computers & Internet
During srcolling my screen (LG W1934ST) is moving very slowly. Should I update a driver for that or what else can I do to make is faster ? Thanks, Axel
It sounds like your video card drivers need updating (or they're not installed) or you you might have it set to the wrong resolution. Try setting the resolution to 1440 x 900 which is the recommend resolution, and make sure you have the frequency set to 60 or 75hz.
Feb 28, 2011 | LG W1934S-BN 19" Monitor
When booting up my windows is loading and then my screen goes black and come up with an error: recomended resolution is 1280x1024... how do I fix this?
Most probably your computer has a higher resolution or refresh frequencies set in Desktop Settings than supported by the monitor. It might be also, that you have previously installed a monitor driver for a different monitor model, and the computer is using resolutions and frequencies supported by that previous monitor, with which your new one can't cope.
The solution would be to boot the computer in safe mode (hit F8 key when the computer is starting, you can hit it a couple of times, until you see a menu; choose "Safe Mode" and hit Enter).
Go to Desktop Properties, change to Settings tab, and click "Advanced" button. In the new window choose "Monitor" tab and change the monitor to "Plug and Play monitor". Click OK to accept the settings and close both windows.
Now reboot the computer - it should start with a rather low resolution, but the picture should be visible. Now you have to go to your Desktop Settings again, Advanced tab, and move the resolution slider to position 1280x1024. Accept and enjoy.
If the computer still doesn't boot, go to safe mode again, go to Control Panel, System, Hardware, Device Manager, drill down to Monitors, and delete all the monitor devices installed. After a reboot, system should start up and find new hardware, and install Plug and Play monitor. Set the optimum resolution of 1280x1024 as written before.
Nov 18, 2009 | Samsung SyncMaster 710VT TFT LCD Monitor
W17e says "input not supported"
Hi - here's what I found about your wide screen monitor:
The HP Pavilion w17e LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Download & install the drivers for the monitor based on the version of Windows you are running from the HP site below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=pe&dlc=es&product=3377546&
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
Sep 29, 2009 | Acer AL1916W 19" LCD Monitor
''out of frequency range'' on crt monitor
Go into your "Device Manager" in Windows and find out if your HDTV monitor is still installed. Delete the settings under the monitor tab and reboot the computer. With any luck the reboot will cause Windows to re-detect your current monitor and install the proper settings. A similar process may need to be followed with your video card driver as well. CAUTION: Make sure you have a disk or some means of installing a copy of your video card driver before you delete out the currently installed one.
Hope this helps!
OpenSource13
Apr 05, 2009 | Compaq Computers & Internet
Monitor Problem
1. Try using a different media player like k-lite windows media player classic or GOM player.
2. Is the lcd set at it's native resolution ? Set it to native resolution.
3. Has the driver for the lcd been installed and does it show up properly in device manager ? Install the lcd driver if applicable.
4. What are your system's specs, especially graphic card ?
5. Has the latest graphic card drivers been installed ? Install latest drivers.
6. Does using VGA or DVI make any difference ?
7. You would've probably already checked windows media player settings.
Hopefully some of these will solve the problem.
Dec 22, 2008 | Samsung T190 19" Widescreen LCD Monitor
Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Jun 13, 2008 | Samsung SyncMaster 510N (Silver) 15 inch...
HP Compaq Evo D310v PC Desktop Logo
47 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
