Question about Sewing Machines
Steam jets leave dirty marks on clothes - Sewing Machines
  • 95 Answers
The tank has water left in it when put away,it will take some cleaning,it will not clear eaven after running water through it,sugest new iron req
Posted on Nov 18, 2009
Embroidery problem
Hai, 1.You should thick and white or blank cover run a letters embroiderys. 2. After don't remove the frame. 3. Put on the embroidery cloth. 4.Marking. 5.Frame setting with smooth needles. 6.Put the frame. 7.Trace the machine after running and finshed the design.
Mar 23, 2014 | Brother SE400 Computerized Sewing and...
Pattern calls for 3/16 seam allowance. What is that in comparison to the marks in my machine?
Well, the normal seam allowance is 5/8ths. Always has been except on crafts and doll clothes. 3/16ths is 1/3 of the normal 5/8ths so I would think, now wider than the width of your sewing foot.
Aug 06, 2013 | Singer 3116 Simple
Leaving grease on material
you have oiled it and it is leaving oil on your material?
(oil will cause dirt to be fluid, turning a light, clear oil dark)
have you answered your own question?
pass some scrap material through to clean off the oil.
Apr 16, 2012 | Brother LS-2125 Mechanical Sewing Machine
I have a Singer Merrittlock Differemtial Feed 14u244 Serger complete with manuals. However, none of the manuals or brochure have instructions on where to oil the machine. Therefore I need lubrication...
Page 40 of the manual shows three oiling points on the rear of the sewing surface to be oiled: two holes in the surface and the pivot point for the arm. These are marked with "2-3 drops"
It is equally important to regularly remove all lint from the cutting blades, around the loopers and behind the covers as lint will absorb any lubricant present. I also clean my blades with a cloth with a bit on oil on it every so often to remove all lint and leave an oily film on the blades.
Jul 31, 2011 | Sewing Machines
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
Commerical washer leaves too much water in clothes after spin cycle. its a whirlpool
Hi, please try and check the pump.I suspect it is blocked which prevents the flow of water. Sometime small clothes like socks blocks it...
Feb 19, 2010 | Sewing Machines
I have a Huskystar C10. I cannot adjust the tension properly since having a sewing jam-up while I was satin stitching. The top thread leaves loops on the bottom on the fabric and the bobbin (which is a...
There is one way out. Give the sewing m/c a thorough servicing job, Clear all the pieces of cloth/fabric/threads, etc Remove the bobbin and load afresh. Clear out the toothed sliders which pulls the cloth while stitching. the thread being used for stitching passes a sort of loop, the tension being controlled by how much the pressure the spring can exert such that depending on the material being stitched. Specially after stitching satin, which is tricky material to stitch in a sewing m/c since the cloth is slippery. Also clear sewing jam and the metal teeth like rack which pushes the cloth for the next stitch to start. This area if cleaned up properly and a little bit of oiling on the spring loader and the spindle assembly which moves up & down...............................sudeep
Aug 07, 2009 | Sewing Machines
I bought a hand held sewing machine that has no markings on is except for the size and strength of the motor, I don't know how to use it, I need some instructions, or directions on how to use. thank you
Is there a makers name on the machine anywhere? have a really good look underneath, behind the motor(if it's an external motor), if you can easily take any of the covers off have a look inside. All we need is one word then I can point you in the right direction.
Apr 05, 2008 | Steam Fast Handy Mender SP-400 Mechanical...
Eclipse DX
It is important to leave about 3 inches out of the end of the loopers when threading. leave them lie where they come out of the jets. Put fabric under the foot and sew, do not wory about putting the thread under the foot. If it still does not work try changing the needles.
Oct 27, 2007 | Baby Lock Eclipse Serger
Sewing Machines Logo
98 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
