Question about Samsung SGH-T429 Cellular Phone
Entry empty message
''entry empty'' message when add new phone no. enter
Send picture messege
1. In Idle mode, press <Menu>2. Press <Add> on the Subject 3. Enter the message subject and 4. Press <Add> on the Picture 5. Add an image file. 6. Scroll to the Sound line and 7. Add a sound file. 8. Scroll to the Message line and 9. Enter the message text. 10. Press <Opt.> and select Done.
11. Press <Opt.> and select Send. 12. Select an empty location. 13. Enter a destination. 14. Press <Send> to send the message
Or you can use samsung x640 "code" in my blog
http://pcgadgetdeni.blogspot.com/2013/02/all-phone-samsung-codes.html
Feb 14, 2013 | Samsung SGH-X640 Tri-Band GSM Camera Cell...
I need to change my voice message
1 Call your Motorola voice mail service. Press the "Contacts" or "Address Book" button and select the "Voice Mail" entry. Press the "Call" button.
2 Enter your password. Call the service provider for your Motorola phone if you cannot recall it.
3 Delete all voice mail messages. In order to access the main menu you'll be required to empty your inbox.
4 Select "Change Personal Options," then choose the "Change Voice Message" menu. Disconnect the phone call to save your settings.
Jan 14, 2011 | Motorola Mobility RAZR V3
When I try to save a contact on my palm pixi it just says "error." I can't save new contacts, I can only add to existing. How do I fix this?
You can add a contact that synchronizes one of your online accounts, such as Google or Exchange. You can also add a
contact in the Palm Profile account, which does not synchronize with an online account but is backed up daily to your Palm Profile.
If you are using Contacts for the first time, you go through a few different steps to get or access the contacts on your phone (see Using Contacts for the first time ). Follow this procedure to add contacts directly on your phone after the first time you use Contacts.
1. Open Contacts .
2. Tap .
3. (Optional) Tap the account button to the right of Name to change the account to which the new contact will be added.
4. Tap fields to enter contact details, select a ringtone for that contact, add notes, or add birthday details for the contact. Scroll to see all of the fields available for contact info.
5. In some fields, such as New Phone Number, when you enter the information a label button appears on the right. Tap the button to change the label for your entry-for example, to identify a number as a mobile or work phone.
Tip Use the Reminder field to enter that important message or question you have for this contact. The next time you send or receive a call or a message to or from the contact on your phone, the reminder pops up on the screen. You can also add a reminder later (see Assigning a reminder message to a contact).
Tip To insert a two-second pause in the dialing sequence, enter a T where you want the pause to appear. To insert a stop in the dialing sequence, enter a P where you want the stop to appear; to dial the next set of numbers after the stop, tap the screen.
6. Tap Done.
Oct 24, 2010 | Palm Pixi Cell Phone
Email settings
you must have email account, also the POP address, and the SMTP with your username and password ready
Set up email account
1. Select Menu > Messaging > Email > Settings > New account > Add.
2. Enter a name for the email account, for example, Home or Office. Select OK.
3. Select Connect using > Edit and select the data account you created earlier to use with this email
account.
4. Select Email address > Edit. Enter your email address. Select OK.
5. Select Connection type > Edit. Select POP3 or IMAP4. POP3 is the most common.
6. Select Incoming server > Edit. Enter the name or the IP address for the incoming server. Select OK.
7. Select Username > Edit. Enter the incoming server username. Select OK.
8. Select Password > Edit. Enter the incoming server password and select OK. Leave this blank if you
want to be asked for the password each time you check new mail.
9. Select Outgoing server > Edit. Enter the name or the IP address of the SMTP server you use to send
email messages. Select OK.
10. Select Advanced settings.
11. Select Your name (not mandatory) > Edit. Enter your name and select OK. This will appear in outgoing
email messages.
12. Select Signature (not mandatory) > Edit. Create a signature to add to your email messages and
select OK.
13. Select Download S&R. Choose what to download when receiving new email messages:
• Subjects only – receive information such as sender and subject before downloading the whole email.
• Up to size limit – receive the whole email. Select Size limit to set the maximum size to download
when receiving new email messages.
• Subjects & text – Only for IMAP4 users. Receive the subject and text but not attached files.
14. Select Check interval (not mandatory). Choose how often you want the phone to connect to your
email server and check for incoming email messages.
15. Select Push email. Only for IMAP4 users. Select On for full email notification functionality or Off to
disable the functionality. See Using push email for full email notification functionality on page 7.
16. Select Allow connection > Edit. Select Any network or Home network.
17. Select Copy outgoing (not mandatory) > Edit. Select On if you want email messages sent from your
phone to be sent to an additional email address of your choice. This way your sent messages are
copied and can be saved for future reference.
18. Select Encryption > Edit. Choose whether your email messages should be encrypted.
19. Select Outgoing. username. If requested, select Edit enter the outgoing server username.
20. Select Outgoing. password. If requested, select Edit enter the outgoing server password.
21. Select Incoming port. If needed, change the port for the protocol you are using.
22. Select Outgoing port. If needed, change the port for the SMTP protocol.
and the other is
To write and send an email message
1. Select Menu > Messaging > Email > Write new.
2. Select To: to add recipients and select Add. There are three ways to add an intro sentence:
• Select Enter email address. to enter an email address.
• Select Contacts look-up to retrieve a recipient from Contacts.
• Select an email address from the last used recipients.
3. To add more recipients, select To: > Edit select Cc or Bcc and select recipients to add. When finished
selecting recipients select Done.
4. Select Subject: to write the subject.
5. Select Text: to write the text.
6. Select Attachments: and select the attachment to add. Add more attachments the same way.
7. Select Continue.
8. Select Send to send the message or More to view options.
To receive and read email messages
1. Select Menu > Messaging > Email > Inbox.
• Select Send&rec when the inbox is empty or
• Select More > Send & receive to download new messages.
2. Select a message and select View to read it.
To reply to an email message
1. Select Menu > Messaging > Email > Inbox. Select an email message in the inbox. Select More
> Reply and select:
• Yes – to include the original message in your reply or
• No – to exclude the original message.
2. Write your message select OK > Continue.
3. Select Send to send the message or More to view option
Mar 08, 2010 | Sony Ericsson W350A Cell Phone
How do I add birthdays to my samsung F480T? There is a birthday widget but it says "No birthday. Enter birthdays for your Phonebook." but I don't know how
If you add birthdays for the entries in phone book, you get to see those in the nearby in the front screen.
For this, goto an address book entry, edit and then enter the birthday. thats it. When that birthday falls within next one month, it will be displayed as reminder on the front screen.
Feb 13, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Is it my imagination or is it true my new env3 does not support t9 or preemptive text?
From the front screen and keyboard:
(i.e. with the phone closed)
While entering a message, hit the main "OK" button for "Options".
Item #2 in this menu is "Entry Mode."
T9 is on this list.
Operating from the internal LCD screen and QWERTY keyboard:
Hit OK to get to main menu
Select "Messages"
Once in that menu, the left option key beneath the main LCD screen is "Settings" - hit that
On that menu, item #2 is "Entry Mode" where you can select T9
I have read of difficulties getting the enV3 T9 mode to add new "user" words that you might want to program into the T9 dictionary, so don't be surprised if you have trouble with that.
Oct 03, 2009 | LG enV3 VX9200 Cell Phone
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
How do i set up email
to do this your phone needs the same email settings as used by your computer for email addresses. To use use your computer email address in your phone, do the following:
Enter settings manually
Ask your email provider for settings infomation. An email provider is the person or company who provided your email address
To create email account (this is on your phone)
1-- >Messaging> Email > Settings >New Account > Add
2-- > New Account> Add.
enter a name for the account> hit ok
email provider needs to be entered in. POP3 a user name and password and account
1-- >Messaging > Email> Write new.
2_-->Add to enter the recipient field >Enter email address--- to type an email > ok> contacts look-up
to receive and read email messages
1-->Messaging>Email>Inbox
>Send&rec
select message in the inbox>View to read it
Jan 22, 2009 | Sony Ericsson K800i Cellular Phone
Sending sms to email address
go to your contacts go to new entry select that and you have the option there to enter email add.
Nov 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
I want to program a new number into my old A900 Samsung phone to replace my wife's old phone.
Hi
Surprsingly u never mentioned the name of the network which u r using. Please mention the CDMA server's name.
Thanks.
Supriyo DG
Jun 19, 2008 | Cell Phones
Samsung SGH-T429 Cellular Phone Logo
298 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
