Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint fdw60 dishwasher. Eco light (3rd light) flashing. tried the to tip on side to empty excess water. However, same thing happens on ecah cycle. Any advise
  • Hotpoint Master
  • 19,396 Answers
When the eco light comes on , that means that an incorrect water level had been detected.
This may be occasional event, or caused by a fault, like probably in your case.
Try first resetting and troubleshooting the machine.
Trip circuit breaker.
Pull out the appliance.
Check drain hose at the back.
Completely empty water from inside.
Check the drain well and filter carefully and clean the filter.
Put back the machine and run a short cycle.
If you still get the problem, then it is usually the pressure switch located into the drain system or the floater switch located inside the tub. Both devices must be tested.
If both pressure switch and floater switch are OK, and inlet valve is not stuck, then there is usually a faulty control board.
Most commonly the problem is caused by a defective pressure switch or water level.
Try the reset above.
If you want to get a quote, or arrange a repair, call Hotpoint at the number listed on the owners manual.
Please do not forget to leave feedback.
Many thanks.
G.
Posted on Nov 17, 2009
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 Flashing lights 3 and 5
Is it possible that water has gotten inside the controls that could have caused the flashing lights? Kind of like spilling water on a calculator, everything seems to go haywire.
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Mar 24, 2008 | Dishwashers
Hotpoint dishwasher dwf50
i had the same problem and like an idiot paid for hotpoint to come out and all the guy done was tip the dishwasher backwards to empty the water(which he didn't clean) and tell me that im using to much rinse aid and salt coz we use 4 in1 tabs hope this helps smiley
Mar 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
180 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
