Question about NetGear WGR614 Wireless Router
Test LED is continously ON, I cannot ping the IP
NetGear WGR614v5 Test LED is continously ON, I cannot ping the IP provided below the instrument .... is it faulty ?
Earlier it was working properly.
  • Manoj Kalekar Nov 17, 2009
    I tried as per your advice, Also pressed reset switch for 30sec-1 min, but LED's did not flash.
    What should I do now ?
  • Chris Hingee
    Chris Hingee May 11, 2010
    Try powering off the router for 30 secs, and then power it up again. You can try to reset the Netgear back to the factory defaults by powering up the Netgear and press the RESET button on the back of the router until the LEDs flash, then release the Reset button (use a sharp point to press the Reset button, it is located in a small hole). You then need to reconfigure the router again and if you don't use the same router wireless settings as before then you also need to configure the wireless cards in the computers with the new wireless router's settings.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 62 Answers
1)If the test light is ON , it means the system is initializing or in the middle of a firmware upgrade and so the ping test will not be successful.
2)If the firmware has not been upgraded then power cycle the router for a min and check which means take the power cable out for a min and then plug it back and if the light status is still the same then go for the soft reset.
3)For soft rest get the tooth pick/paper-clip or a pin and poke it into the reset button located on the rear panel of the router and is a very small tiny circular button , wait for 30-35s and it take it out , wait for 10-15s and then repeat the step2.
4)If this does not work out go for the hard reset[but all the internet connectivity will be lost and the re-configuration has to done from the beginning]
Procedure for hard-resetting:-
a)Use the paper clip or a pin to reset the device and keep holding the reset button for at least 30-35s.
b)Then , While holding the paper clip take the power cable out from the device , wait for 10-15s and then plug the power cable back to the device while holding the paper clip.
c)Wait for another 10-15s and then release the paper clip.
d)Once we have all the lights back on to the device then take the power chord out and plug it back within 30s.
5)Check the light status if it is still the same then router is faulty and has to be replaced if not then login to http://routerlogin.net/ with username as admin and password as password and re-configure the router setting's.
Posted on Nov 19, 2009
I can't connect through network can't connect by pinging
Can you ping your router?
If you can, log into it and see if you have any problems with it. If you have ADSL, you will see the status of the line as well as whether you are connected or not. You may have a diagnostic feature that will test the connection to your provider.
If you have lost DNS with your provider, you will not be able to ping using names, only by IP addresses.
Jul 24, 2011 | Computers & Internet
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
Is Netgear Route WGR614V5 compatible with Windows 7?
Please note that this router is compatible with Windows 7. Please perform the below steps on your Windows 7 computer to connect to the wireless network:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear WGR614 Wireless Router
Change the local IP address of Billion 400G
You need to login to the router page with the IP 10.0.0.2 and the on that and you can change the IP from that page
On login it will ask for username and password it is admin and password is "password" by default if you have any issue in getting user name and password you can reset the router as below
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot.
it will come back to factory settings of 192.168.1.1 and then you need to configure the router as per your internet service provider
you can check the manual at the below link
http://kbserver.netgear.com/pdf/dg834g_dg834gb_ref_manual_03Jun05.pdf
Nov 27, 2009 | NetGear DG834G 802.11G Wireless ADSL...
If a change in my firewall is preventing netgear router, i do i fix?
First, make sure the cables are properly connected, if using xDSL modem, it must be connected to the WAN port, the pc on the ethernet ports (any of the 4 ports available).
Second, check your current IP Address (default 192.168.1.x), then ping from your pc the ip address of the router (default 192.168.1.1). If OK, then your LAN connection works fine.
Third, ping any internet site, i.e. ping www.yahoo.com. if a reply response is received, your internet connection is now working.
If not, reset the router then do the initial set up from the router web page. Go to IE or mozilla browser, type http://192.168.1.1 (default ip add of router), the password or username is admin (default - refer to your manual). If already inside the page, go to the setup folder then proceed to configure the router. After all the configuration, check your internet connection, go to any web site.
Sep 15, 2009 | NetGear WGR614 Wireless Router
Router will not work only the power light is lit up
1. physical connections
2. hard reset
3. check ip. (if 169, assign static ip)
4. assign static ip
5. ping router (if getting replies, access webui, reload firmware. if not getting replies, the router may already be faulty, advise to phone netgear)
Jul 09, 2009 | NetGear WGR614 Wireless Router
Problem with the router
Could you please perform the steps below and mail us the results:
# Connect your computer directly to your modem and perform the following tests.
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here. Also, mail us the same IP configuration.
C. Type ping 4.2.2.2 and hit ‘Enter’. Mail us the text that you see just below this command.
D. Type in ping yahoo.com and hit ‘Enter’. Mail us the text that you see just below this command.
I would be able to provide u a solution, as per the information I get for above.
Jul 07, 2009 | NetGear WGT624 Wireless Router
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
How to test Connections with Ping
Ping is one of the first tools to use to check computer, router and Internet connectivity. It's run at a command prompt, but getting the basic information is quite easy. You can do the whole thing in 30 seconds. 1. To run ping, type Start > Run. 2. Type cmd in the Run window, and click OK. A black and white command line window pops up. 3. Type ping followed by an IP address or a DNS address. 4. Press Enter to execute the command. Three useful examples: 1. ping 127.0.0.1 (This is a "loopback ping" ? your computer trying to talk to itself. This tests whether your computer is able to handle Ethernet traffic. If this has a negative result, the computer has an operating system problem.) 2. ping 192.168.1.1 (If the result is "Request timed out", type ping 192.168.0.1. If that also times out, then the computer is not making a connection to your router.) 3. ping www.netgear.com. (Tests whether your computer can contact Internet computers.) When there is no problem, the ping results look as shown in the following screenshot. Three items of interest in the results are highlighted with arrows. The first arrow shows the computer being contacted is replying. (The DNS address "www.netgear.com" is converted by ping into the equivalent IP address, 10.1.1.86.) This shows both that your network is connnected to the Internet, and that that computer on the Internet is running normally. www.netgear.com is always running, so this is a good test address to use. The second arrow shows that Ethernet packets have "0% loss". This is the best possible result. It means that the network connection is lightly loaded, and that it has not been necessary to transmit any of the same information twice. The third arrow shows the average time it took to answer. "Average = 0ms" is the best possible result. Probably you'll only get responses this quickly from computers on your own network. Interpreting Ping when There's a Problem As far as NETGEAR equipment, the problem you're most likely to run into is "Request Timed Out". This means there is no connection. Read these posts: http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102077 and http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102074 Another error is "Unknown host", which just means that the DNS or IP address you typed doesn't exist. Probably, you made a typo. Other problems are generally outside the scope of NETGEAR support. Often they are problems with your ISP ? contact them with concerns. A controversial situation is when packet loss is not 0%. Sometimes this indicates a severe problem, but in other situations it doesn't indicate any problem whatever. However anything higher than 5% is definitely a problem. If the average round trip time is > 500 ms, there' s possible latency problem. Again, contact your ISP. Limitations of the Ping Tool * Ping is not a good tool for diagnosing intermittent problems. * Good results are reliable, but ?bad results? could be caused by any number of things, and are not necessarily reliable! * Ping uses ICMP, which has low priority, showing speeds that are slower than regular network traffic. Some computers reject ICMP, and therefore pinging, entirely. * When an IP appears between the source and destination in a traceroute command it does *not* mean that that IP must be pingable.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
NetGear WGR614 Wireless Router Logo
95 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
