Wall Mount I want to know which wall mounts I can get to get with this TV: Digital Lifestyles 32" LCD HDTV 3rd Edition with HDMI Cable
  • 1 more comment
  • junk08 Jan 28, 2008
    I can no tfind a wall mount that works with the AKAI LCT3101AD. It is small enough for a swivel but nothing seems to match up to the back of the TV.
  • Anonymous Jun 07, 2008
    I too cannot find an appropriate wall mount for the Akai LCT3201TD. It doesn't appear to be VESA compliant.
  • Anonymous Aug 04, 2008
    I tried a Peerless Universal Wall Mount I purchased at Costco. Even with its various mounting plates it wouldn't configure to my Digital Lifestyle 32" LCD.
    johnm@quinlanmktg.com
I found that the screw holes in the back that should have thread from the top down are threaded only near the bottom of the hole. You will need to purchase longer bolts/screws to attach the mount. Also, if it has the built in DVD player you will need to purchase a few plastic washers to build the mount up over the DVD player and to make the other side even. It is POSSIBLE to mount this TV it is just a large amount of work! I hope this can help!
Posted on Jan 08, 2009
How to attach wall mount to a Sony Bravia 32" TV
You need to be careful here. Unless you are very handy, the TV could come crashing down to the floor if not done correctly. Depending on how much you paid for the TV, I would hire a trained individual to do this.
Oct 20, 2014 | Sony BRAVIA KDL-32BX330 32" LCD TV...
What type of wall mount bracket will I need
Depending on what you want, Just make sure it is made to hold at least a 32 inch LCD TV . If you would like to tilt it, buy a tilt mount. It needs to be mounted to the studs in the wall for best support. I recommend you pre wire the cables before hanging the TV,since they will be hard to get to after the set is mounted.
Aug 07, 2014 | iSymphony 32" LC32iH62 LCD Widescreen...
How much does this TV weigh? Is it considered a 32" when mounting on wall or do you considered the entire diagonal at 38"?
The TDA-03211c weighs 39.5 pounds; however, I'm not sure if that is with or without the base. The shipping weight of the TV is 50.3 pounds. Most wall mounts use the standard screen diagonal measurement to determine what size TV it will support. So the 32" is sufficient information for choosing a wall mount.
I hope this helps.
Nov 28, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Will it fit a universal fit wall mount
Most of these will. You san see the screw mounts on the back of the set and compare them the wall mount spand holes. I have mounted 19" RCA LCD Panels so I have got to believe this 32" should be able to mount on most universal wall mounts.
I hope this helps,
Skyassoc
Dec 11, 2010 | RCA L32HD31 32 in. LCD HDTV
How do i mount tv to wall
What type of wall mount would I need for a 32in Emerson LCD320EM9 HDTV LCD. And how do I mount it to the back of the TV. TV on back only has two holes for screws?
Nov 26, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Samsung tv wall mounting
For a true flush mount installation, you will need to recess your connections (i.e. power, HDMI, S-Vid, etc). Most tvs have the connections coming out of the bottom to allow flush mounting.
If your wall is not drywall, or you really don't want to bother with the expense of recessing your outlets and cable connections, just get a swivel arm mount. It will allow the TV to sit a bit further from the wall and still look ok.
Go to www.monoprice.com for great deals on mounts. I have 3 of them in my house and they are excellent quality.
May 22, 2009 | Samsung LN46A650 46 in. LCD HDTV
Clearence between tv an wall
You need at least 25mm so as to allow the circulation of air around the unit , any less and you risk the unit overheating .usually the mounts protrude this far and don't cause a problem . ... Regards Vortash
Apr 22, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
