Question about Acer Aspire L100 PC Desktop
Acer 3089 how do i do a system restore from startup is there a setting on here for restore without the disk? i forget my password
  • 2,427 Answers
Hmm which password ??? is it the bios password or the windows password.. Any way I will give you solutions for both
THE BIOS PASSWORD
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
TO RESET WINDOWS PASSWORD
1.) dowload hirens boot cd from here
www.phazeddl.com
you will need to search hirens when you go to the site
2.)burn off cd
3.) boot from cd
4.) use the on screen menu to fine windows password reset tools,
5.) choose the appiorate one and follow instructions to change or reset password..
THATS IT WINDOWS PASSWORD RESET..
let me know if you need any more help good luck
Posted on Jan 10, 2008
Reset acer 4810t
You can start the Recovery from outside windows by holding down the ALT key and tapping F10 repeatedly
on startup. When the recovery loads you will be prompted for a password.
This should have been set by the customer if they have been into the Acer Recovery Management software previously.
If they have forgotten the password or you wish to clear the password you need to boot off the recovery disk that should have been created.
More Information
From the Acer toolbar at the top of the desktop click on the disk icon
Setup a password if requested.
After clicking on setup you need to click Create Password to continue.
Create a password and add a password hint (strongly recommended).
You now have the option of restoring from a previous Windows Vista backup or you can start the Acer recovery process.
The recovery is started by clicking Restore at the bottom of the window.
Further types of recovery are now presented.
Choose Restore system to factory default if you wish to run the hard drive based recovery and return your Acer computer back to it's original factory default state.
Note: The factory default recovery will wipe ALL data from the computer so ensure important data has been saved to disk before proceeding.
Enter the password that was previously set.
Confirm you wish to run the recovery process.
After confirming you wish to run the recovery process the computer will restart and restore all the original files
Complete the Out of Box Experience when prompted
After a couple of restarts the computer will run through restoring the preinstalled software that came with your computer and then be ready to use
hope this helps
Jul 27, 2012 | Acer Aspire 3810T 4810T 5810T
When i power on the laptop ask HDD PASSWORD SIR PLZ HOW CAN I REMOVE SIR
How to remove and unlock hard drive password? Is there any software to recover hard drive disk password? Where to download hard drive password cracker? Is it possible to reset the hard drive password?
According to Lenovo and many other manufacturers' website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
Most people are not aware that most hard disk drives have the ability to set a hardware password, just like the Bios password for motherboards, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. Usually these features can only be found in laptops, this is when you set a password on your notebook, the hard drive together with the motherboard becomes locked.
Most experts would say if you forget the original HDD or Bios password, there is no way of restoring it by generic system tools. Unlike the Bios password where there is a master key or with the removal of the bios battery, the password is erased from the flash memory thus the settings is restored to factory settings without the password, however, this does not applies to hard disk.
Jan 21, 2011 | Acer Computers & Internet
On switching on acer aspire one have immediately After first screen screen stating Windows could not start because following file Is missing \windows\system32\config\ system You can attempt to...
Pressing F2 on startup enters the Setup Utility and a password to that has been set up on your netbook. In any case, you can try pressing Alt and F10 at startup to get into Acer eRecovery Management which can then restore the operating system to its original factory condition. Be aware that doing the restore clears the hard disk partition containing the operating system and all user data will be erased.
Jan 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
Reboot my Acer Notebook
Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
Mar 05, 2010 | Acer Aspire 3100-1405 Notebook
Turn computer on the user login screen comes up... enter password and then a blank screen.
Have you removed any virus's or spyware? Windows is either getting stuck on a corrupted driver/loader or a file was deleted. Some virus's do this. If you have a windows disk, run setup from the disk and you will be given the option to repair windows before installing. Select this and when prompted, select startup repair. If this does not work boot to safe mode with networking and try running system restore. If you have system restore enabled and it shows up unavailable or no restore points set, you might have a virus. Forget the free virus/spam removal downlads, they WILL NOT WORK!!! Go to onecare.live.com and use their full scan. It is completely free, runs online, and provided by Microsoft, not some knock-off company. It is the ONLY free removal tool that hes ever worked for me, and I have tried literally every one I have ever found on Google.
Jan 26, 2010 | Acer Aspire 6530-5143 Notebook PC
How 2 factory reset an acer aspire 5315 laptop
There are two basic ways to restore Acer 5315 PC Notebook to the original setting. The first method you can try to pressing the key Alt + F10 for 5 times while startup process appears on the Acer screen. Usually this way will restore the original setting automatically.
And the next method you may need to use system restore at the first time you’ve got your Acer 5315 laptop. Here are steps to follow:
Log on as the Administrator => Start => All Programs => Accessories => System Tools => and click the System Restore. System restore will run and here you should see the Welcome System Restore page appear. Click Restore my computer button to an early time if it’s not already
selected. Click next to continue the steps.
There is on your Acer 5315 laptop screen a Restore Point page appear, you can select it and then click the most recent system checkpoint it, click a restore point list. After you click the Next button, System Restore message may appear that lists configuration changes that
System Restore will create. Click OK.
For the last step click next button on the Confirm Restore Point Selection page. Now the ‘System Restore’ will restore the previous Windows XP configuration on your Acer 5315 OS system. Just finish it by restarts your Acer laptop.
Now log on again to your Acer 5315 PC Notebook as Administrator and watch the System Restore Restoration Complete page appears. Click OK.
Dec 30, 2009 | Acer Aspire 5315 Notebook
ACER 5100 BIOS PASSWORD
If your son used the edata security and used both passwords. you can either ask him for password or change the boot secuence to boot to restore disk and restore back to default..which defaults to NO PASSWORD set.
Dec 04, 2008 | Acer Aspire 5100 Notebook
Forgotten password
Hello:
If you want to restore your laptop to factory setting: You should insert your "recovery disk to the CD/DVD ROM. and then shutdown the laptop.
Now; boot your laptop using the recovery disk(boot the laptop from CD/DVD rom) This will no need to input the password: its either you have to restore the system without deleting the existing files or you have to partition and format the hard drive. formatting hard drive you will end up with fresh copy of system files. same as first day when you purchase the laptop.
be sure to install the driver if there's any.
However; if you tend to do by supplying the password. iguess all factory installation has no password. you have to strike the enter without supplying any password.
may this help,
melnavz
Sep 11, 2008 | Acer Aspire 5720-6661 Notebook PC
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Oct 03, 2007 | Acer Aspire 5100 Notebook
Acer Aspire L100 PC Desktop Logo
273 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
