Question about Navman Tracker 5500i GPS Receiver
I have navman tracker 5500 gps and the gps signal not working so there is no signel but all the charter is there
Before you condemn the aeial use a pin to gently squeeze the centre hole in the aerial socket at the back of the gps unit. I've got this unit and that was the fault
Posted on Jul 18, 2010
Yes I have found the same prob with parts - so I am inetested in buying an 5500 or 5600 dispoay for parts! richard at barnesgb dot com
Posted on Feb 20, 2010
I HAVE THE SAME PROBLEM.U WILL FIND THE ANTENNA IS BUGGERED.THERE ARE NO SPARE PARTS AVAILABLE FOR THIS MODEL.LESSON; DON'T BUY NAVMAN OR NORTHSTAR.I HAVE ONE OF EACH. NEVER AGAIN!!!
Posted on Jan 18, 2010
Navman Tracker 5500
I am having same trouble. I contacted Navman NSW and went through all the settings without result. It was suggested that the problem could be the external antenna, if not a fault in the machine. I have seen an after market antenna for about $19 so I might try that. It does seem as though the antenna is not talking to the Tracker.
Dec 10, 2012 | Navman Tracker 5500i GPS Receiver
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
Slow at finding satelites
Most common reasons for this is that your battery level is low. Make sure it is fully charged before use.
Please rate my help++++Thanks for using FIXYA
Jan 12, 2010 | Navman Tracker 5500i GPS Receiver
Navman 5500 gps backlight dim but set to max
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
May 27, 2009 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500 Marine Chartplotter
Yes the screen is replaceable, there are four screws holding it to the PCB and a short ribon and a two wire power lead.
Aug 11, 2008 | Navman Tracker 5500i GPS Receiver
Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Apr 24, 2008 | Navman Tracker 5500i GPS Receiver
I the lost manual
Hi....
I have gone through your problem.Follow this link.
Hope you are searching for the same.
Mar 30, 2008 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500 turns on but locks itself in the entry page
Have the same problem??
Used to take less than a minute to acquire satellites now takes 10-20minutes.
Nov 08, 2007 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500i GPS Receiver Logo
1,235 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
