Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Wheels won't engage
On my bissell proheat, when I push the pedal down to release the upright handle so I can start to vacuum, it will roll backwards, but not forwards on the carpet. On the bare floor, it rolls just fine forward and back. This is tested with the power button OFF. I have also located a piece of plastic that apparently broke off from the right side (when looking at it from the overview). Is the broken plastic the problem, or is it something else? If it is the broken plastic, how do I replace.
1 When I push the gray lever to let the handle go down, it will not let the handle go down. What is wrong with the handle?
2 The machine will not suck up vary well when I use the hose to vacumn.
Posted on Jan 12, 2008
  • 1 more comment
  • wj jenkns Jan 12, 2008
    My machine says it is a Bissell Proheat Clearview 12 AMP with 5 cleaning rows
    What is an the outer window noozle with the inner window. Were is it?
    Please help with vision if possible.
    President:
  • 1,673 Answers
Sounds like the outer window noozle isn't seated with the inner window. Take out the two screws, one on each side, remove the window, inspect the other half moon window to make sure it is ok, then reinstall the outer window(don't forget the gasket that sits on top of this window)Try to see if you still have a problem.
Posted on Jan 10, 2008
Bissel cleaner won't stop spraying water
Remove the handle and check for continuous spray.
After handle is removed, check to make sure the valve is not stuck in the down position. If the valve is stuck in the down position, push on it manually to get it to come back up. If it is stuck you may need to get a new handle for your unit. This handle is for a variety of the ProHeat models http://www.bissell.com/parts/?sc=part&productid=2775&partid=4449&cid=ccsocial
Check to make sure it will properly fit your model if you need a new handle.
May 08, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell proheat shampoo machine won,t spray solution from the hand wand
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Aug 18, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Proheat 7901 has continual leakage from
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
456wet
Jan 20, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell ProHeat can't get my cleaner to **** any water back up.
heatman101
iup
Jan 06, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
The Bissell 79011 is not releasing cleansing formula
Check the nozzle at the bottom of the soap dispensor, is the seal on it? and can you push the plunger so that it opens up, other wise replace the cap and vavle asm part # 2101795 .
Oct 03, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
