Question about Acer Aspire 5315 Notebook
Acer Aspire 5315 keeps turning off, is it a fan or battery problem? Sometimes it doesn't even get that hot and it still turns off, mainly on my husband, doesn't happen that much with me ?????
  • Acer Master
  • 6,993 Answers
Does the power turns off when the laptop adapter is plugged into Electricity? If it turns off while adapter is plugged the I doubt it the fault is from the battery. To be sure, remove the battery, then turn it on with the adapter and observe what happens. If it turns off, then its not a battery fault and if it does not, then the battery is faulty.
Also be sure about the system fan.
Please I will love to have a feedback.
Best wishes.
Posted on Nov 17, 2009
  • 92 Answers
It could be infected under your husbands name. I have known viruses to switch pc on and off. Try a program called spybot search and destroy. Its free and really good. Make sure you get the name right as there are other programs with simaliar names. Set the program up install update and set for indept scan. Be warned it takes ages to do but very good. Let me know how you get on....Hope this helps...
  • Acer Master
  • 32,281 Answers
When a computer shuts down by itself and will not start up again straight away, until it has cooled down. Then this is an overheating problem.
This is caused by a faulty fan and/or the fan and heat-sink assembly is clogged with dust.
If the computer is not on a flat surface then the vents may not have clear for good ventilation.
Check the fan to see if it spins freely, if not replace the fan.
Clean and vacuum the dust from the fan and heat-sink assembly.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 159 Answers
What bios are you running? I have the same laptop, and recently had to update to V1.45.
This fixed mine!
Here is the link: http://support.acer.com/us/en/product/default.aspx?tab=6&modelId=50
Once your there click "BIOS", and then download at the right hand side!
Posted on Feb 29, 2012
Laptop just keeps shutting down and won't turn on
it may be one of the causes, but the main reason for it is the power supply keeps on fluctuating. You may call Acer for a possible replacement for it..
Jun 19, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
Hi, i have an acer aspire 5315 icl 50 - when i turn the power on it just dies for no reason after just a couple of seconds?
Perform a simple test: release its battery pack and try to run on the mains power supply only. If it works, your battery pack has reached its end of life. In this case, buy a new one.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 10, 2011 | Acer Aspire 5315 Notebook
Acer aspire 5315 laptop , will not power up, its completely dead no lights on at all nowhere, any sugestions
try taking out the battery and pluging it in and try turning it on,sometimes a tottally messed up battery will cause that..or mabey your laptop charger is no good,, and the battery is dead so it isnt chargeing ..
Jun 19, 2010 | Acer Aspire 5315 Notebook
I've had my acer aspire (5315) laptop for over 2 years
Sometimes, the CPU heat sink fan might get clogged up or faulty or stop spinning entirely. Make sure that the fan can turn properly.
IF YOU CAN, open the unit when the battery is disconnected and the power is not connected, then reseat the CPU Heat sink and re-apply a eye drop heat sink thermal paste onto the CPU. Reconnect and tighten everything again properly and adhere to the sequence in turning the screws back as per their numbering on the heat-sink
If the FAN has trouble spinning, doesn't turn at all or is noisy and runs irregular please replace the fan. The fan alone should cost about a few US $.
May 16, 2010 | Acer Aspire 5315 Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Aspire 5315 switchs of randomly and over heats
What OS are you using? You may have to update the BIOS.
For Windows XP or Vista you'll want to go here.
http://support.acer-euro.com/drivers/notebook/as_5315.html
Remember to make backups and note your BOIS settings prior to updating. A good generic guide for for updating BIOS can be found here.
http://www.wikihow.com/Update-Your-Computer%27s-BIOS
Hope this helps
Aug 13, 2009 | Acer Computers & Internet
Automatic shutdown without notice
its because CPU get hot. check the cpu fan or
clean that, heatsink of cpu fan must be clean and closed to cpu.
Aug 01, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
1,073 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
