Question about Whirlpool 24 in. GU980SCG Built-in Dishwasher
A burning smell and steamy smoke come out when we open the door.
After running a load of dishes we get a burning smell and steamy smoke coming out of the unit when we open the door.
  • 4 Answers
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
Posted on Nov 17, 2009
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
Everytime I start my whirpool dishwasher it smells like smoke. If left on for a while a burning smell and steamy smoke come out when I open the door
I would check your heating element to make sure it is clean of plastic on some label that is against it some type of paper or what have you this element heats just like a oven and can burn objects on it or touching it.If you see a spot clean it very gently until that it all is the same color use a scruff pad sponge to use for removal of the spot in question. Remember to rate my solution and give testimonial this is how i earn achievements here on FixYa Thanks in advance.
Apr 25, 2012 | Whirlpool Dishwashers
Smoke coming through air vents
Is it smoke? Or is it steam? If it's really smoke, it will smell like burning wires and you have an electrical short somewhere. You're going to have a fire unless it's fixed.
My guess is that it's probably not smoke or you would have already had a fire.
With that said I'm going to say that it's steam in which case your heater core (which is a small radiator located under the dash) is leaking coolant and the resulting steam is rising through the vents. The steam will have a sort of sweet and yes, a steamy smell to it. It will also leave a funny film from the radiator coolant coating the inside of the windshield.
The heater core should be replaced if my assumptions are correct.
Dec 27, 2010 | 2000 Dodge Neon
In the last month I have noticed that my dishes aren't getting clean. My dishwasher is less than a year old and has done a great job so far. I tried adjusting the amount of rinse aid and the amount of...
First I would run the hot water until hot. Then start the dishwasher on the longest setting with the dispenser door closed( no detergent). Then after about 10-15 minutes open the door and check to see if the dispenser door opened, it should have. Then pour in about 1 cup of white vinegar and let the dishwasher finish. When the dishwasher reaches the end of the cycle open the door and it should be hot and steamy. If not check the heating element. If it is hot this should have cleaned it out, now try it with a load of dishes.
Dishwasher heating element replacement
Sep 28, 2010 | LG Dishwashers
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
Burning Smell - smoking coming out of it
I believe we tracked it down to the pressure switch mounted on the drain pump. The device had a strong electrical burn smell and is positioned where it could easily have smoked the basket. We're putting the washer back into service and if I have a recurrence I will post the information. BTW ... Replacement was simple and the part was $26 including shipping.
Jul 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool 24 in. GU980SCG Built-in Dishwasher Logo
1,120 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
