Question about Water Heaters
Swich on heating the pilot lights up then the boiler starts making banging noises the pressure gauge starts fluctuating and the boiler cuts out
    Sergeant:
  • 399 Answers
Hi you could be drawing air into the system try bleeding the system check all seals and if ok tighten all connections
Posted on Nov 17, 2009
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
Glow worm 45-60 standing boiler making banging noises when in operation
The noise you refer to is called Kettling, it is caused by the hot water in your boiler not being able to leave the boiler quick enough, if the problem developed quickly and your system is a "fully pumped " system this would generally point to your pump either has failed or is on its way out, i.e . your radiators would not heat up as the hot water is stuck in the boiler hence the banging......( if you know where the pump is you can generally feel if it is running by a small vibration ) if you have gravity hot water and pumped heating circuit then I would assume that it is noisy when just doing HW, and the banging is a problem that has gradually got worse it can indicate that the boiler is scaling up (are you in a hard water area). if this is correct there are various additives that can be put in the system to help quieten it down, I suggest you really need a heating engineer to diagnose fully.
Feb 07, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
Flashing ch on greenstar 42cdi boiler
ch calling for heat check ignitor or heating element
Oct 18, 2017 | Water Heaters
I have a Worcester Bosch HE system boiler. I am not getting any heating or hot water.The burner ( pilot light) is not on and the pressure gauge is on 0 bar. The boiler is about 7 years old. My decorator...
If a radiator was taken out and put back in I feel you have air built up in your system. There should; be an air relief valve on each radiator. Get your furnace up to heat and open the valve on each radiator till all the air is out of the lines. If there is air in the system there will be no heat. You do this after the heat is on. As far as the pilot not coming on you could have a bad igniter which may need replacing to get heat.
Aug 22, 2017 | Water Heaters
Got a ravenheat ls 1oot combi boiler not working red light on timer on not making any noise works every now and then for short periods
I have a ravenheat 820/20(t) boiler and the pilot will not say alight, I have 20mV from the thermocouple(through the safety switch) and its had a new gas valve fitted(good earth continuity).The heating system is holding pressure at 1.2 bar.
Has anyone got any ideas what could be holding the pilot 'OFF'.
I CANNOT SEE ANYTHING ELSE IN THE PILOT CIRCUIT.
PLEASE HELP !
Dec 20, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Heating pressure gauge goes up
yes tami
there should be a pressure rellief valve fitted.
it also sounds like the heat exchanger is blocked if the hot water is not as good as it used to be and the boiler reaches temperature too quickly then there is scale in the heat exchanger and needs to be cleaned or replaced
Mar 27, 2009 | Water Heaters
Water Heaters Logo
98 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
